Core Support blackout?????? what areas? #1120596
11/24/11 02:52 PM
11/24/11 02:52 PM
minnarusta
TX9H6E4CUDA Offline OP
minnarusta
Alright so where should I black out my core support?
And what works good for paint?
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
Re: Core Support blackout?????? what areas? [Re: TX9H6E4CUDA] #1120597
11/24/11 03:01 PM
11/24/11 03:01 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
Sorta like....
Re: Core Support blackout?????? what areas? [Re: THESHAKERPROJECT] #1120598
11/24/11 03:06 PM
11/24/11 03:06 PM
NORTHERN VA
NORTHERN VA
and you know that your lowwer rad support is tweeked a bit...I used SEM trim black for the paint but I have used Krylon 1613 semi gloss black as well.
Re: Core Support blackout?????? what areas? [Re: THESHAKERPROJECT] #1120599
11/24/11 03:42 PM
11/24/11 03:42 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
This how it looks on a factory unrestored car.
Re: Core Support blackout?????? what areas? [Re: 67vertman] #1120600
11/24/11 05:09 PM
11/24/11 05:09 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Yeah, that lower tie bar's been hit, you need to get that straight.
Basically the idea on the blackout was to not see body color through the grille. Blackout was applied by a guy in a pit spraying up at the car at an angle. The original cars I've had didn't have blackout on the top surfaces or on the upper tie bar, but the side panels, lower tie bar and center (hood latch) support were sprayed, and to varying degrees the fender areas behind the inboard headlamps. Dark blue or black cars generally didn't get the blackout. The pattern & practice goes as far back as the early '60s from what I've seen, probably '62 or whenever a body line became unit construction. Body/frame cars in the '50s already had black rad supports.
Re: Core Support blackout?????? what areas? [Re: THESHAKERPROJECT] #1120601
11/24/11 06:03 PM
11/24/11 06:03 PM
MG, Brazil
v8punch Offline
v8punch  Offline
MG, Brazil
71 challenger al original paint on disassembling process
Re: Core Support blackout?????? what areas? [Re: v8punch] #1120602
11/25/11 08:30 PM
11/25/11 08:30 PM
minnarusta
minnarusta
Thanks for the help!!!!!!!
yeah I know I have to fix that lower core support (with my size 12 boot ) should be fixed next week before I paint the support.
