what is the over heating temp for a /6?
#111997
08/29/08 03:49 AM
08/29/08 03:49 AM
the temperature gauge has been swapped to an after market thing that only has numbers. at what temperature is it over heating and at what temperature is panic "turn it off now!" mode?
Re: what is the over heating temp for a /6?
[Re: HUSTLESTUFF]
#112000
08/29/08 12:49 PM
08/29/08 12:49 PM
It usually runs under or around 200. usually 180ish? I don't know what thermostat i have.
[Re: Desoto]
#112003
08/29/08 04:23 PM
08/29/08 04:23 PM
I think everyone miss understood my post. I know it's not over heating now. I wanted to know what temps i need to be watching for if it does over heat. and when to turn it off if I have to let it cool and run for a few blocks with only water or while it's leaking.
#112006
08/29/08 07:00 PM
08/29/08 07:00 PM
RapidRobert
"after the next atomic bomb the only things left on earth will be dodge darts & cockroaches, the cockroaches will be driving the dodge darts.(presumeably /6 powered).Quote from comedy central. At the state fair a snake oil salesman added his concotion to the /6 oil on a test stand ran it a bit then drained it & kept the /6 running with no oil & it didn't blow. This post contributed nothing techwise to this thread but it is my cntribution for today.
[Re: RapidRobert]
#112007
08/29/08 07:17 PM
08/29/08 07:17 PM
I have seen slant 6's get so hot the exhaust manifold was glowing red-and still no problems.The slant 6 cannot be killed by lack of water
