Ohio Crankshaft Billet Crank - Flange Question #1119648
11/23/11 09:50 AM
11/23/11 09:50 AM
Portersville, Pa
1badx Offline OP
1badx  Offline OP
Portersville, Pa
I tried posting this in the Q&A section and had limited response so I thought I'd try it here.
I was considering one of the OC Billet cranks but was wonder how folks are mounting their flexplate without the locating flange? Or is everyone running a non-torqueflite trans (JW makes a GM adapter)?
Thanks in advance and Happy Thanksgiving!
Mike
Re: Ohio Crankshaft Billet Crank - Flange Question [Re: 1badx] #1119649
11/23/11 03:24 PM
11/23/11 03:24 PM
Cab_Burge Online work
Cab_Burge  Online Work
Mike
I saw your other posts on this, I bought a adapter ring from Kieth Black Enterprizes, 562-869-1518, not the piston company To use on a old 8 bolt top fuel crank, there the 392 hemi 8 bolt type cranks, not 426 hemi type It presses into the crank and locates the converter hub perfectly, not much money either Don't forgot that the distance from the flywheel mounting flange to the thrust surface of the cranksahft thrust bearing is different on the top fuel cranks like your wanting to use and the stock street hemi cranks,I think the top fuel cranks flanges are 3/8 thick and the 426 stock crank flanges are 1/4 inch thick, or close to that You'll need to make sure the converter to pump hub depth is correct, you may need a spacer plate or have the converter machined to match your crank and block I attached a picture of the adapter ring
Re: Ohio Crankshaft Billet Crank - Flange Question [Re: 1badx] #1119650
11/23/11 03:31 PM
11/23/11 03:31 PM
AndyF Offline
AndyF  Offline
Why would you buy a crank that isn't designed for your application? If you need to run a flexplate then buy a crankshaft with the correct flange on it. There are plenty of cranks available these days, no reason to mix and match the wrong parts.
Re: Ohio Crankshaft Billet Crank - Flange Question [Re: AndyF] #1119651
11/23/11 04:55 PM
11/23/11 04:55 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
Re: Ohio Crankshaft Billet Crank - Flange Question [Re: Diablo] #1119652
11/23/11 05:48 PM
11/23/11 05:48 PM
Portersville, Pa
1badx Offline OP
1badx  Offline OP
Portersville, Pa
In my case there really aren't that many new billet cranks out there for my application (especially in the stock stroke length) for $1800.
I have spoken to some GM guy who have run the Ohio Crankshaft crank without any issues.
I am open to suggestions, I am looking for a stock stroke crank (3.75) capable of handling 1800 crank hp (turbo not N2O) and was leaning towards a billet. We have had customers making that kind of power on the Callies Dragonslayers but I think that is pushing the limits and am hesitant on going that route.
Thoughts?
Re: Ohio Crankshaft Billet Crank - Flange Question [Re: 1badx] #1119653
11/23/11 07:21 PM
11/23/11 07:21 PM
Delray beach, Florida
P
Performance Only Offline
P
Thoughts?
i'd rather sell you a Callies Magnum series over the dragonslayer for your application. it's a little bit more money, but it'll get the job done nicely and much better than the dragonslayer series for the Mopar application.
machine shop owner and engine builder
Re: Ohio Crankshaft Billet Crank - Flange Question [Re: Performance Only] #1119654
11/23/11 08:54 PM
11/23/11 08:54 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Crower made me mine
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Ohio Crankshaft Billet Crank - Flange Question [Re: 1badx] #1119655
11/23/11 10:36 PM
11/23/11 10:36 PM
AndyF Offline
AndyF  Offline
Shouldn't be hard to find a crank that will handle that power level. Call a few of the Mopar engine builders who are familiar with that stuff and get some recommendations. Best Machine, Koffel, Indy, Barton, etc. I doubt that any of those guys will recommend an Ohio crankshaft.
