1976 Fury....what style of power steering pump????? #1119237
11/22/11 03:24 PM
11/22/11 03:24 PM
minnarusta
TX9H6E4CUDA Offline OP
minnarusta
I'm trying to help a friend out, he bought a 1976 Fury Squad and its missing the power steering pump. We are replacing it now and trying to order a correct one. So was it the GM looking style one, the later Saginaw style? We are trying to figure this out so what should we get?
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
Re: 1976 Fury....what style of power steering pump????? [Re: TX9H6E4CUDA] #1119238
11/22/11 05:40 PM
11/22/11 05:40 PM
scratchnfotraction Offline
my 76 charger had the one that looks like a GM one.
same as the one on my 85 truck,same as my 79RC also.
all mounted about the same on the SB and used the same brackets and spacers.
do you have the bracket that goes on 2 of the t-cover bolts for the pivot bolt support?
there is a tri-angle piece that goes with the bracket on the pump with spacers, the slide adjuste peice.
I will take a look and see if it is all there on the spare SB pump I have,may save you a couple bux if you need it
Re: 1976 Fury....what style of power steering pump????? [Re: scratchnfotraction] #1119239
11/22/11 05:49 PM
11/22/11 05:49 PM
minnarusta
minnarusta
The car is a 400 HP motor. Thanks but I don't think a small block will work.
Re: 1976 Fury....what style of power steering pump????? [Re: TX9H6E4CUDA] #1119240
11/22/11 06:02 PM
11/22/11 06:02 PM
well I missed that part,sorry,carry on then
Re: 1976 Fury....what style of power steering pump????? [Re: scratchnfotraction] #1119241
11/22/11 07:24 PM
11/22/11 07:24 PM
minnarusta
minnarusta
No problem sorry I should of said big block car.
Re: 1976 Fury....what style of power steering pump????? [Re: TX9H6E4CUDA] #1119242
11/22/11 07:47 PM
11/22/11 07:47 PM
the last BB cordoba i looked at had the GM looking pump but different brackets for sure.
i would wager it would be the GM looking pump you need for the 75 fury
good luck hunting
Re: 1976 Fury....what style of power steering pump????? [Re: scratchnfotraction] #1119243
11/22/11 09:46 PM
11/22/11 09:46 PM
NJ
69 charger man Offline
NJ
hey garret?
this is ray. i found that pump the other day. heres a pic. i have the cap too, just took it off to dump the fluid out. i may want to keep the cooler for my charger tho. this came from a bb 440 with ac. you can just barley make it out from the lower picture.
-ray
