Setting 440 Lifter Preload
#1119184
11/22/11 02:28 PM
11/22/11 02:28 PM
Posts: 1,880 Out in Left Field, NY
bobs66440
I'm trying to determine if my pushrods are the proper length. What's the proper procedure for checking lifter preload (stock non-adjustable rocker arms). The lifters are bled down. Also, do I need to check all or just one? Thanks!
Re: Setting 440 Lifter Preload
[Re: MoparforLife]
#1119187
11/22/11 06:00 PM
11/22/11 06:00 PM
Posts: 183 Eden, Texas
Strawdawg
Eden, Texas
The most accurate means of checking preload is to use an adjustable pushrod, as John said, and set it to zero preload. Then compare that length to your regular pushrods' length which should be longer. The difference between the two would give you the actual preload of your current set up.
If you don't like the current set up, you can order a set of custom length pushrods made to your specs from Smith, or others, or you can put shims under the rocker arm shafts if you need to reduce the preload amount abit.
A cruder, but, no cost method, of checking pushrod preload is to loosen the rocker shafts with the lifter on the base side of the cam lobe that you are going to check, and then gradually (and evenly) tighten the shaft hold down bolts until you feel a little resistance to turning the pushrod with your fingers.
That would the zero preload point. Lay a straight edge across the lifter bosses and with a very fine marker, make a mark on the pushrod.
Then tighten the shaft all the way down and make a second mark on the pushrod. Be careful to maintain the position of the straight edge so your second mark is truly relevant to the first mark.
Release the tension on the shaft, pull the push rod out and measure the distance between the two marks to get the approximate preload. This will be close enuf for government work.
Then you either shim the rockers or order a new set of pushrods made to your desired length.
It is always good to check more than one location on both sides of the engine to find a good average that reflects the depth of the valve seats, etc...particularly if you are trying to be exact on a high output engine....
In most cases, it is not that sensitive an issue as mentioned above.
I recently decided to check the preload on my 440 as the intake fit so badly that I suspected that either the heads or block had been decked excessively. Average was about 0.120" which is probably way too much in anyone's book.
Steve
[Re: RapidRobert]
#1119191
11/22/11 11:36 PM
11/22/11 11:36 PM
bobs66440
Post how much (preload) you come up w
Okay, I measured the current lifter preload on all the right side push rods and they all average .170" except one oddball was .100". That would be .110"-.150" too much preload! Yikes!
I have the left side head off, so I didn't measure that, but I would imagine it to be about the same.
As stated, they are 9.31" stock rods, so I assume the block/heads must have been milled? Am I wrong in assuming this? Could there be another cause?
[Re: bobs66440]
#1119192
11/23/11 02:12 AM
11/23/11 02:12 AM
RapidRobert
there's a stackup of tolerances on block deck height/head dimentions. I'd measure the other bank then buy or make an adj pushrod measure twice & get the correct length you need. Measure geometry & Hughes' engines & others has some procedures for length/wipe pattern checks.
[Re: MoparforLife]
#1119194
11/23/11 10:34 AM
11/23/11 10:34 AM
bobs66440
Are you sure that you had the lifters on the base circle of the cam. If this is a stock engine in a street driven application and the plunger aren't bottoming out in the lifter drive it.
Yes, I made sure all the lifters were at the base of each lobe. I really don't know if the plungers were bottoming as I don't know the total travel they have.
Also, I noticed that the exhaust valves sit about .070" higher than the intake valves. This may complicate finding final pushrod length?
[Re: bobs66440]
#1119195
11/23/11 10:58 AM
11/23/11 10:58 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
I myself would be concerned with the amount of preload you have because if the lifter pumps up it can hang the valve open, open valve equals no compression.
First you can try to push on the rocker when the lifter is on the base circle to see if the plunger goes down more.
This is a problem that sometimes doesn't get addressed when a head is being rebuilt. Vavle seats at different depths cause this .
You need to fix this one of 2 ways ... SHIMS UNDER THE SHAFT IS NOT ONE OF THEM .... adjustable rockers or adjustable pushrods. I had a set of adjustable pushrods made by Smith, they weren't cheap, get a couple extras to have on hand.
