tti thermal barrier headers: coating worth it? #1119081
11/22/11 12:13 PM
11/22/11 12:13 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Is the coating worth it? is it durable? how does it live in a humid envoroment?
does it really put some of the heat at bay?
Or should I just get the plain steel ones?
Re: tti thermal barrier headers: coating worth it? [Re: domingo] #1119082
11/22/11 12:20 PM
11/22/11 12:20 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yes it is worth it big time. Huge difference with it. Both my cars have it inside the headers and vapor lock is no more with them. Makes em last longer too.
Re: tti thermal barrier headers: coating worth it? [Re: Challenger 1] #1119083
11/22/11 12:21 PM
11/22/11 12:21 PM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
YES DO IT !
1969 Dodge Charger 1969 Dodge Superbee
Re: tti thermal barrier headers: coating worth it? [Re: Challenger 1] #1119084
11/22/11 12:35 PM
11/22/11 12:35 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
awesome. Thanks for the advice!
Re: tti thermal barrier headers: coating worth it? [Re: Challenger 1] #1119085
11/22/11 12:38 PM
11/22/11 12:38 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
x2
Re: tti thermal barrier headers: coating worth it? [Re: domingo] #1119086
11/22/11 01:08 PM
11/22/11 01:08 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
its worth it..
Re: tti thermal barrier headers: coating worth it? [Re: 70blackfish] #1119087
11/22/11 06:48 PM
11/22/11 06:48 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
My tubes run at 280 instead of 700 degrees
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: tti thermal barrier headers: coating worth it? [Re: domingo] #1119088
11/22/11 07:14 PM
11/22/11 07:14 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
yes it is. i would follow their directions on winter time storage. w-d where the tubes merge to the collector. i didn't do that to mine & they rusted. they also mention to put plastic down on the floor to keep moisture off them. stay safe, seeya.
Re: tti thermal barrier headers: coating worth it? [Re: 65signet] #1119089
11/22/11 08:52 PM
11/22/11 08:52 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Re: tti thermal barrier headers: coating worth it? [Re: domingo] #1119090
11/23/11 09:25 AM
11/23/11 09:25 AM
an8sec70cuda Offline
Definitely worth it. You will not regret spending the extra money for it. I have 2 sets of coated TTI headers. One set bought in 2003, the other set bought in 2006. Both still look good. Not new, but good.
CHIP
'06 GMC 2500HD LBZ Duramax
