EFI pumps #1119039
11/22/11 10:23 AM
11/22/11 10:23 AM
Auburn Mich.
5.7bob Offline OP
5.7bob  Offline OP
Auburn Mich.
What are people with stock gas tanks using for there efi motor swaps? I realy dont like the looks of the welded up tanks.
Re: EFI pumps [Re: 5.7bob] #1119040
11/22/11 10:51 AM
11/22/11 10:51 AM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
I am in the process of finalizing an in tank pump on my 56 using a setup from Tanks Inc.
It's a lot of work but not has hard or scary as it looks.
The worst part was flattening the ridges and humps on the top of the tank. I had to heat and shrink the metal to create a flat spot for the flange. NOTE this tank has NOT had any fuel in it for over 15 Years, there were Zero fumes present, and no chance of combustion when using the torch to work the metal!!!!! If your tank has ever had fuel in it STAY AWAT FROM IT WITH A TORCH. I was cautioned that even flushing it with water would not be safe.
http://www.tanksinc.com/index.cfm/page/p...=prod/prd84.htm
Re: EFI pumps [Re: finadk] #1119041
11/22/11 11:10 AM
11/22/11 11:10 AM
Auburn Mich.
5.7bob Offline OP
5.7bob  Offline OP
Auburn Mich.
Looks like a nice kit thanks.
Re: EFI pumps [Re: 5.7bob] #1119042
11/22/11 11:13 AM
11/22/11 11:13 AM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
exactly what i did with my tank too
Re: EFI pumps [Re: Wedgeman] #1119043
11/22/11 11:20 AM
11/22/11 11:20 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
I installed a 5.7 in to an old carburated Jaguar XJ6, it has dual tanks so a conventional set up with a return line doesn't work. So, I left the stock electric small pressure pumps in to the stock tanks and installed an auxilar 1 quart auxiliar tank in to the engine bay. After that is an MSD EFI pump, Aeromotive regulator with a return line to the auxiliar tank. Seems to work just fine the little I have driven it so far.
Plynouth VIP '67 TT IC EFI
Re: EFI pumps [Re: jyrki] #1119044
11/22/11 12:34 PM
11/22/11 12:34 PM
Andrewh Offline
Andrewh  Offline
depending on your car, they now make the pickups with return lines already on them, or you take the vent line and use it as a return.
I used a walbro 255 and I have also used the msd generic pump from summit and the aeromotive regulator.
both are able to auto prime themselves and work well for an efi 5.9.
Re: EFI pumps [Re: Andrewh] #1119045
11/22/11 02:12 PM
11/22/11 02:12 PM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
i like the kits from rock valley. you can buy the kit and install it yourself or buy a new tank with it already installed. can't see it in the pics but inside the tank there is a circular thing around the pump to hold fuel around the pump so it isn't starved for fuel when going around corners at say a quarter tank of gas..
http://www.rockvalleyantiqueautoparts.com/ndex.htm
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: EFI pumps [Re: abodyjoe] #1119046
11/22/11 02:23 PM
11/22/11 02:23 PM
East Tennessee
Burkenator Offline
Burkenator  Offline
East Tennessee
Here's mine....E-body
Re: EFI pumps [Re: abodyjoe] #1119047
11/22/11 02:26 PM
11/22/11 02:26 PM
Beaverton, OR, USA
Alikazam Offline
super gas
Alikazam  Offline
super gas
Beaverton, OR, USA
I like the looks of the kit from rock valley also, but plan to put my own pump on it (new walbro 400 lph pump) with a new stock tank for my van myself. New replacement tank = no chance of kaboom from welding! At least that's the plan so far... to feed the Viper V10 she'll be getting
Re: EFI pumps [Re: Alikazam] #1119048
11/22/11 02:35 PM
11/22/11 02:35 PM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
the rock valley kit uses a off the shelf GM pump i believe. thats good if it craps out on ya somewhere. easy replacement.
Re: EFI pumps [Re: Alikazam] #1119049
11/22/11 02:44 PM
11/22/11 02:44 PM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
Believe me I wish there was a replacement tank for my car. It seems that 56 Dodge Custom Royal Lancer's are no where near as popular as Challengers, Chargers, or even Tri 5 Chubbies........Go Figure.
I searched high and low for something that I could adopt or retrofit before I settled on this Tanks Inc. pump.
Now I just have to get the tank cleaned out and i will be good to go.
Scott 1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed) 2002 Dodge Ram 1500 Quad Cab 1976 Corvette
Re: EFI pumps [Re: abodyjoe] #1119050
11/22/11 09:44 PM
11/22/11 09:44 PM
Beaverton, OR, USA
Alikazam Offline
super gas
Alikazam  Offline
super gas
Beaverton, OR, USA
Yeah I emailed them a while back said I could order their kit minus the pump so I could use my own.
That is a sweet car there!! I'd look into custom making a tank for it myself, but that's just me
Re: EFI pumps [Re: Alikazam] #1119051
11/23/11 12:08 AM
11/23/11 12:08 AM
Auburn Mich.
5.7bob Offline OP
5.7bob  Offline OP
Auburn Mich.
I dont think you will see many as you drive around. very nice
