Re: crinkle paint on big block air cleaner???
[Re: missu34]
#111887
08/29/08 08:21 PM
08/29/08 08:21 PM
Posts: 7,052 Madera, CA.
MowP4rsn
Madera, CA.
A little over 10 years ago, while I was a student at a community college in their auto tech program, I had a dual snorkel aircleaner I blasted and then put the wrinkle finish paint on. I thought it looked real sharp Do what you want that makes you happy.
[Re: GODSCOUNTRY340]
#111889
08/31/08 07:47 PM
08/31/08 07:47 PM
moparpollack
Lil Herman
Lil Herman
85086
It can be done with a rattle can but you need a heat gun. It takes some practice to not overheat the paint in one area.
[Re: Devil]
#111891
09/02/08 03:29 PM
09/02/08 03:29 PM
Posts: 3,288 Stroudsburg, PA
Erik
Stroudsburg, PA
I did mine w/ a rattle can & heat gun. Only hit it w/ the heat gun a little bit. I then left it out in the sun to dry. Here are pics of before and after. It's not hard at all. Just take your time.
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
[Re: missu34]
#111892
09/03/08 08:24 AM
09/03/08 08:24 AM
Posts: 91 Outing, MN
beesuperA12
Outing, MN
I just did my un-silenced 340 air cleaner. After two attemps with Plasticote Wrinkle paint and miserable results, I ordered Wrinkle Black from Eastwood and had fantastic results. Apply two wet coats and let dry...no heat required...finish will wrinkle in 2-12 hours.
69.5 Super Bee A12
[Re: cudaize]
#111894
09/04/08 08:43 AM
09/04/08 08:43 AM
Erik
Stroudsburg, PA
What I did for my air cleaner was clean it up and remove all of the dirt/rust etc. I did not go so far as to bead blast it. I then shot it w/ semi gloss black Rustoleum as a base. I then shot it w/ black wrinkle paint (not the cheap Plastikote stuff). I picked up the trick of the heat gun here on Moparts. It causes the paint to start wrinkling quickly and if done slowly and evenly will get a uniform wrinkling over the entire air cleaner. I then let it dry in the sun for several hours. I thought it came out pretty nice as this was my first ever attempt at it.
[Re: Erik]
#111895
09/04/08 10:02 AM
09/04/08 10:02 AM
Posts: 1,101 Retired now in Tennessee
Chi_Town_Runner
Erik, I know you said you used Rustoleum for the base coat but what brand rattle can for the wrinkle?? Looks great Frank
Remember - 2 wrongs don't make a right - but 3 rights make a left!
[Re: Erik]
#111897
09/09/08 08:30 AM
09/09/08 08:30 AM
Erik
Stroudsburg, PA
Sorry - I forgot to look at this until last night!
I used a brand called VHT. I don't remember where I got it, but I think it was Jack's.
[Re: cudaize]
#111900
08/19/09 05:47 AM
08/19/09 05:47 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
Some people talk about a heat gun. Was this part of the instructions for your particular paint or a trick that you learned long the way to kick it before it runs.
Mike Afflerbach
Was a trick I learned by myself, if you practice you can control the amount of wrinkle too.
