Re: horsepower guesses?
[Re: jensenguy]
#111875
08/31/08 11:16 PM
08/31/08 11:16 PM
Posts: 16,479 Canada
CrAzYMoPaRGuY
Canada
Block huggers are the only headers you will find that will fit without making a set yourself I bet.... Even some of the more compact headers won't fit on an Interceptor, the floor at the front is in the way. Hedman (I think) makes a header that looks close, but I have never tried them so I'm guessing they wouldn't fit if I had to guess.....
I think alot of people think the Interceptors are over 4000 pounds, but I think even the MIII Interceptors are just shy of 4000 pounds..?
An HONEST 9 to 1 compression is pretty good IMO.
Any pics??!?!
CrAzYMoPaRGuY
[Re: jensenguy]
#111880
06/18/09 09:38 PM
06/18/09 09:38 PM
CrAzYMoPaRGuY
Canada
I had to drag this post up. LOL I ended up going with Delta Motorsport headers made specifically for an Interceptor. They fit like a glove, but the steering support bracket needs a modification that isn't too hard. I am going to try dual Edelbrock 500s. I went with a 270H Comp Cam, I have a measured 9.35 to 1 compression 446 (.030" over) and I ported my heads and did a bit of bowl work. I did quite a bit of weight savings with the intake, headers, removing the AC (I'll convert to a Sanden later) an aluminum waterpump housing, etc... Any pics of your engine bay?!?!
CrAzYMoPaRGuY
