Page 3 of 4 1 2 3 4
Re: Orig trim tag MIA. How to get the orig layout to redo. [Re: THESHAKERPROJECT] #1118634
11/24/11 01:17 PM
11/24/11 01:17 PM
In the 8's
FY1TA Offline
FY1TA  Offline
In the 8's
Jeff Bangert has alot of SIAC info .
Re: Orig trim tag MIA. How to get the orig layout to redo. [Re: FY1TA] #1118635
11/24/11 01:35 PM
11/24/11 01:35 PM
NORTHERN VA
THESHAKERPROJECT Offline OP
NORTHERN VA
Any contact info for him ?? Is he a member here ?
Re: Orig trim tag MIA. How to get the orig layout to redo. [Re: THESHAKERPROJECT] #1118636
11/24/11 03:21 PM
11/24/11 03:21 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I have copies of all the SIAC info Jeff got from Tom Quadrini except for the AAR Cuda's.
You can search http://www.hamtramck-historical.com/found.shtml for your VIN to see if I have anything for it here.
Re: Orig trim tag MIA. How to get the orig layout to redo. [Re: JohnRR] #1118637
11/24/11 03:41 PM
11/24/11 03:41 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Ok ..From A to Y B41 B51 C16 D34 D53 E87 G11 J46 J81 N96 R33 R36 S77 VX1 V6X W23 Y14 T86 There are no A (group) codes. The sticker price for this 71 Challenger was $4752.05 Funny thing about this car is the OPEN 323 rear .It must have been a handful on a rainy day.
If that's what GG gave you for codes you need to ask for your money back
D34 would not be correct. Yikes...my typin is no good actually the codes are B41 B51 C19 C55 C93 F25 F96 G11 G41 J11 J15 J21 J25 J31 J46 J81 L76 M21 M26 N41 N42 N85 N96 R36 R33S15 S25S77 S81 W23...
Also there are codes that would have to be there that you don't have listed. Are you holding out? I see on the left side of the printout E87 D32 D53 T86 V01 V1X GY3 V6X TX8 Those are all the 3 letter codes
If you can email me a copy of your broadcast sheet I can probably help you.
Mike
Based on the info you provided your tag would look like this. However I still think you are holding back a code or two that might make people question the tag. All the lower case stuff are things you have not provided.
PS: I know all you "experts" can ID a repo tag.
That one will stick out like a sore thumb ...
Please enlighten us
I could tell you the two things that "might" be wrong with it, but let's see your knowledge of 71 tags.
Re: Orig trim tag MIA. How to get the orig layout to redo. [Re: Morty426] #1118638
11/24/11 04:27 PM
11/24/11 04:27 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Why does it have M21 twice?
Re: Orig trim tag MIA. How to get the orig layout to redo. [Re: autoxcuda] #1118639
11/24/11 05:03 PM
11/24/11 05:03 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Obviously this isn't something you should be doing while enjoying an adult beverage
That would be a mistake
Re: Orig trim tag MIA. How to get the orig layout to redo. [Re: Morty426] #1118640
11/24/11 10:42 PM
11/24/11 10:42 PM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
In my opinion, a reproduction tag can cast doubt on an otherwise honest car down the road. If you have a lot of other documentation, the repro tag adds nothing to the value. It might make you feel warm and fuzzy as the current owner, but it will be spotted a mile away.
Re: Orig trim tag MIA. How to get the orig layout to redo. [Re: Aero426] #1118641
11/27/11 10:48 AM
11/27/11 10:48 AM
Germany
fc7_plumcrazy Offline
Germany
@theshakerproject: If you really want to have a tag in your enginebay:
Let the fake tag being produced but instead of the last six digits of your VIN in the lower right bottom let there be "repro" stamped in. In that case everyone knows it is not original, including the novices. And you have told it the spectator without waking doubts of your car or intentions.
Carsten
Re: Orig trim tag MIA. How to get the orig layout to redo. [Re: THESHAKERPROJECT] #1118642
11/27/11 09:46 PM
11/27/11 09:46 PM
Strathroy, Ontario
BS27R1B Offline
BS27R1B  Offline
Strathroy, Ontario
.........thats not good. I will wait to here back from GG to see if he ever got a copy of the orig tag befor I have a new one made. I do know that one of the prev owner, Hank Bowers was a SIAC member back in the 80s. I wonder if any of that info still exsist today.
Don't hold your breath!
'.. it was long ago and it was far away, and it was so much better than it is today..'
Jim Steinman
Re: Orig trim tag MIA. How to get the orig layout to redo. [Re: fc7_plumcrazy] #1118643
12/02/11 02:35 PM
12/02/11 02:35 PM
Minnesota
69Y2RT Offline
69Y2RT  Offline
Minnesota
Carsten
Whenever I see a reproduction tag on a car that the owner is trying to pass off as the original tag, I assume that the block and trans have also been restamped and are not original.
1969 Coronet R/T Y2 Y2 P6X X9 V8X 1967 Satellite 383 4speed
Re: Orig trim tag MIA. How to get the orig layout to redo. [Re: 69Y2RT] #1118644
12/02/11 03:12 PM
12/02/11 03:12 PM
Kirkland, Washington
Pacnorthcuda Offline
Carsten
From a Seller's perspective I disagree--here's why: Lack of a tag on a car is an immediate turn off to a LOT of potential buyers, in terms of a V-Code E-body easily the MAJORITY of potential buyers. You've just severely restricted the demand right there.
Now put on well-made FAKE/REPRO whatever tag and you've just satisfied SOME of the above turn-off buyers. Not everyone will spot a fake tag, and in fact I would venture that only a minority of people will.
As far as someone who MAY have been interested in a no-tag car, but not interested in a Fake/Repro tag car--they are miniscule in percentage. If you care that much about the tag (and I do) then the fact its gone is a deal-killer already.
Re: Orig trim tag MIA. How to get the orig layout to redo. [Re: Pacnorthcuda] #1118645
12/02/11 04:05 PM
12/02/11 04:05 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
A missing FT is only a deal killer to me if there is no BS; with a sheet, the missing tag is less of a big deal....to me anyway. I've always said that despite the fact the FT has less info on it, it is part of the car and the BS isn't....given the choice, I'll take the original FT/no BS car over it's inverse.....but either is acceptable to me.
This thread has made me think: I've always said that despite my dislike for fake and fraudulent documentation that I'd consider a repop FT *IF* there was enough original documentation to back it up...but I'm finding myself leaning towards some that have expressed the opinion that a repop tag raises too many questions and taints the car without adding much to the car.....
I guess it's about "lines in the sand" and where your comfort level is. For me:
- no original tag or BS = no repop tag
- have BS, missing FT = maybe repop tag
- have a rusty but legible FT or pics of original tag = yep, i'd do it
I have dozens of pics of my original FT as well as a couple pencil rubbings.....if my original went AWOL, I'd get a duplicate made.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Orig trim tag MIA. How to get the orig layout to redo. [Re: DPelletier] #1118646
12/02/11 07:05 PM
12/02/11 07:05 PM
Winnipeg
O
OneOfMany Offline
OneOfMany  Offline
O
Winnipeg
Interesting.. I'd take a BS over a fendertag any day.
Re: Orig trim tag MIA. How to get the orig layout to redo. [Re: OneOfMany] #1118647
12/02/11 08:02 PM
12/02/11 08:02 PM
DPelletier Offline
DPelletier  Offline
Yep, you're not alone but I stand by my preference.
On one hand It'd be nice to know which tires my car came with and whether or not it had full wheelcovers, but the FT covers the bulk of the important stuff.
OTOH, I don't have a blank spot where the FT is supposed to live or a repop that makes people question whether or not the car is fake....
....so I'll take the FT any day.....though either is good enough and both is great!
Re: Orig trim tag MIA. How to get the orig layout to redo. [Re: DPelletier] #1118648
12/03/11 09:12 AM
12/03/11 09:12 AM
the house on the left.
cogen80 Offline
cogen80  Offline
if a repo fender tag is going to cast so much doubt about the car shouldn't anything other then an original paint car be in question also? i mean come on now. its pretty damn easy to swap the numbers on a car before its painted. god knows how many "rare" high dollar well known cars out there have had numbers swapped on them back in the day before anyone really cared. i'll bet its a lot more then any would believe.
To put it bluntly, most people with the knowledge to properly lay out a tag aren't going to be offering (detailed) assistance as most of them do not want you in on their game of making fake tags.
fixed.
Re: Orig trim tag MIA. How to get the orig layout to redo. [Re: DPelletier] #1118649
12/03/11 11:33 AM
12/03/11 11:33 AM
Buffalo, NY U.S.A.
MrNormsTA Offline
Happy Birthday MrNormsTA  Offline
Buffalo, NY U.S.A.
I thought I wrote this myself. My thoughts completely. I am a numbers geek and love broadcast sheets, but if I had a choice over the two, would take an original fender tag for all the reasons above. Also the reason I hold original documentation so highly. I wonder what the masses would prefer if we had a poll?
Rick.
Re: Orig trim tag MIA. How to get the orig layout to redo. [Re: cogen80] #1118650
12/03/11 01:03 PM
12/03/11 01:03 PM
NORTHERN VA
NORTHERN VA
...................................................................... Very True... Im reall not in the game of flipping and selling ANY mopars. I have never sold one. I keep them for me and I build them how I want too. I like my cars to look correct and run better than stock using as many correct parts as possable . I think is funny when people say there OPINION could hurt or taint the value of any car. Thats just plain B.S. !!! Im not trying to add any value or fool anybody by reproducing a fender tag . I just want one on my car. These day, with all the social media aviliable to check out a fender tag or other documentation, I think it would be difficult to still get fooled. EVERY high end restored collecter car these day should be suspect and should be checked out using all avail resources befor purchase. BTW, most of the info I needed to format a tag for my Hamtrack car was in the 70-71 parts book. I thank everybody for there opinion, positive or negitive, its all good.
Re: Orig trim tag MIA. How to get the orig layout to redo. [Re: THESHAKERPROJECT] #1118651
12/03/11 04:36 PM
12/03/11 04:36 PM
DPelletier Offline
DPelletier  Offline
BTW, most of the info I needed to format a tag for my Lynch RD car was in the 70-71 parts book.
I'm confused; you said in the first post that your car was a Hamtrack built car...you talking about two different cars now?
I think a Lynch Rd tag would be the hardest to "duplicate" seeing as how (IIRC) the gate, line and sequence numbers at the top of the tag appear nowhere else. You'd have to make them up completely
Anyhow,
Re: Orig trim tag MIA. How to get the orig layout to redo. [Re: THESHAKERPROJECT] #1118652
12/03/11 04:39 PM
12/03/11 04:39 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
I think is funny when people say their OPINION could hurt or taint the value of any car. Thats just plain B.S. !!! The value of most anything, cars included, is based on opinion. Some people's opinion on the value of an item carries more weight than others. One person's negative opinion on the value of a car can hurt it.
Im not trying to add any value or fool anybody by reproducing a fender tag . At least be honest. Of course you are fooling someone. You want to put one on your car to make think people it's the original.
These day, with all the social media aviliable to check out a fender tag or other documentation, I think it would be difficult to still get fooled. EVERY high end restored collecter car these day should be suspect and should be checked out using all avail resources befor purchase. High end collectors sure....the average Joe. No. the average Joe believes it's the original.
BTW, most of the info I needed to format a tag for my Lynch RD car was in the 70-71 parts book. Page 6 only shows a generic layout. It's not specific to LR. Is there another page in the parts book I'm missing?
What was coded, when it was coded and where it was coded on the tag changed during the year. From what I can tell, there are at least three different code change layouts to the 70 LR tag.
Re: Orig trim tag MIA. How to get the orig layout to redo. [Re: DPelletier] #1118653
12/03/11 10:54 PM
12/03/11 10:54 PM
NORTHERN VA
NORTHERN VA
Anyhow,
Sorry, my mistake ...it is a Hamtrack car. My Charger R/T was built at Lynch rd and has its orig tag. The basic layout of the tag for a Hamtrack car is in the parts book. Yes the Lynch rd tags are different as seen on the 71 superbee site.
Page 3 of 4 1 2 3 4
