Should I go to manual brakes or keep power? #111830
08/28/08 08:31 PM
08/28/08 08:31 PM
Eugene, OR
FuryBoy Offline OP
FuryBoy  Offline OP
Eugene, OR
So, I am getting ready to install a scarebird disk brake swap w/ 11.75 cordoba rotors and chevy calipers.
I need to do something with the master cylinder, so I was thinking the lightweight aluminum master cylinder but from what I've read it's a manual swap only.
Currently I have power 11 inch drums. So, should I got for the manual brake swap? I really would like to drop a few pounds off, but my experiences with manual disk brakes have not been good.
would an adjustable prop valve and a smaller master cylinder help?
Re: Should I go to manual brakes or keep power? [Re: FuryBoy] #111831
08/29/08 11:54 AM
08/29/08 11:54 AM
Summit, NJ
W
whiplash Offline
whiplash  Offline
W
Summit, NJ
I have changed the 2 b bodies I've owned over to manual from power. First was a 70 charger, loved the manual discs. ended up being a racecar.
The currently owned 67 coroent eis still my daily driver, 4000#, manual steering and manual brakes, loves them both. I like the road feel in the brake pedal. I have the 12" rotors and caliper adapters on 76 a body spindles. Will never go back to power brakes.
On the other hand I seem to be the only one, all my friends hate my brakes, but they all drive chevys......
  • 67 coronet 4dr, 383/727/GVOD, blown, EFI, daily driver
  • 230/238, 114°LSA cam, 1.6 rollers, 9:1 comp, 8 psi boost
  • NEW BEST ET - 12.40@110mph...
Re: Should I go to manual brakes or keep power? [Re: whiplash] #111832
08/29/08 12:41 PM
08/29/08 12:41 PM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
I have manual front discs on my 68 and they work great. I just used the mopar parts swap from the tech section.
Re: Should I go to manual brakes or keep power? [Re: Joshs68] #111833
08/29/08 01:33 PM
08/29/08 01:33 PM
roanoke va
kbcuda Offline
kbcuda  Offline
roanoke va
I love manual discs...too cushy with power...contact dr. diff for a master cylinder....
Re: Should I go to manual brakes or keep power? [Re: kbcuda] #111834
08/30/08 05:10 AM
08/30/08 05:10 AM
places
79powerwagon Offline
places
Yes, no need for power disks on a car, really. And I have an extra brand new aluminum MC with billet adapter that I'm not going to use.
Re: Should I go to manual brakes or keep power? [Re: FuryBoy] #111835
08/30/08 07:42 AM
08/30/08 07:42 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Years ago I swapped the power brakes out and put in the Mopar aluminum master. The car is an original disk brake b-body. The braking left a lot to be desired - took a lot of effort to stop. However that was long before the internet and this website and from what I've since read I'm thinking the problem is probably the rod is using the wrong pedal hole. The car hasn't been driven in 24 years but before it goes on th road again I plan to take a look at that.
Re: Should I go to manual brakes or keep power? [Re: FuryBoy] #111836
08/30/08 08:01 AM
08/30/08 08:01 AM
Montana
FuryUs Offline
FuryUs  Offline
Montana
Manual.
Re: Should I go to manual brakes or keep power? [Re: FuryUs] #111837
08/30/08 08:18 AM
08/30/08 08:18 AM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Changed to manual brakes AND steering in my 470" Challenger. Less clutter in the engine well! Works great. Parallel parking is a bear but I always hated parallel parking and always park at the end of the lot anyway.
Go manual. Less clutter. Less problems. No wories about cam duration or vacuum signal.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Should I go to manual brakes or keep power? [Re: FuryBoy] #111838
08/30/08 09:18 AM
08/30/08 09:18 AM
Pizza Bucket
snuggles Offline
snuggles  Offline
Pizza Bucket
manual steering and brakes and collecting parts for a 4 speed
Re: Should I go to manual brakes or keep power? [Re: FuryBoy] #111839
08/30/08 09:53 AM
08/30/08 09:53 AM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
keep in mind the bore size of the MC, bigger isnt always better..
http://www.mpbrakes.com/technical-support/troubleshooting-disc-drum-06.cfm
Re: Should I go to manual brakes or keep power? [Re: Dakota_Don] #111840
08/30/08 12:14 PM
08/30/08 12:14 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
My son has manual disc on his Dart and it stops fine even from his 117 mph runs it stops with ease. My 63 has stock power drums and I left them on the car. Even with the MP .557 cam my power brakes work fine and it also stops fine from 116 mph runs. I drive it all over on the street and they work fine for normal street driving. Ron
Re: Should I go to manual brakes or keep power? [Re: 383man] #111841
08/30/08 05:38 PM
08/30/08 05:38 PM
Hightstown, NJ
njdevil2 Offline
njdevil2  Offline
Hightstown, NJ
So, if I read this right, I need a new master cylinder if I take the power booster off. Do I need a different push rod for the pedal to the master cylinder? And can I use the aluminum master that Ehrenberg sells?
1970 road runner Convertible
1 of 179
Re: Should I go to manual brakes or keep power? [Re: njdevil2] #111842
08/31/08 01:03 PM
08/31/08 01:03 PM
Hightstown, NJ
njdevil2 Offline
njdevil2  Offline
Hightstown, NJ
1 of 179
Re: Should I go to manual brakes or keep power? [Re: njdevil2] #111843
08/31/08 01:33 PM
08/31/08 01:33 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
I got manual disc brakes. You can get a manual disc brake cylinder for a 70 barracuda at car quest for like 35 bucks, then you need a manual brake rod, and the firewall plate for manual brakes. I have no stopping issues since I dont run in the traffic jams with my muscle car and dont drive like im on a road corse either
Re: Should I go to manual brakes or keep power? [Re: FuryBoy] #111844
08/31/08 01:40 PM
08/31/08 01:40 PM
North Texas
O
oleman Offline
oleman  Offline
O
North Texas
I have all stock parts manual disk brakes on our 73 440 727 dart.
I like the manual disks. When you mash the pedal you actually have brake feel.
Stops fine but the pedal is always full, ie not much freeplay.
Re: Should I go to manual brakes or keep power? [Re: oleman] #111845
08/31/08 01:52 PM
08/31/08 01:52 PM
Hightstown, NJ
njdevil2 Offline
njdevil2  Offline
Hightstown, NJ
I'm really considering removing the power booster from my '73 Satellite. I need to remove it for painting anyway, I just never liked power brakes.
So, I just need to find the rod and an adapter to the master cylinder. I don't want to butcher it, though. That's why I was wondering about the aluminum cylinder. I'm putting the car on a diet....
1 of 179
Re: Should I go to manual brakes or keep power? [Re: njdevil2] #111846
08/31/08 03:34 PM
08/31/08 03:34 PM
Montana
FuryUs Offline
FuryUs  Offline
Montana
If you go with the aluminum MC, I think you need an adaptor plate to go from 4 bolt mounting to 2 bolt.
Re: Should I go to manual brakes or keep power? [Re: whiplash] #111847
08/31/08 03:53 PM
08/31/08 03:53 PM
On the other hand I seem to be the only one,ll my friends hate my brakes, but they all drive chevys......
Friends do not let friends drive chebbies. If you've been convinced to switch all you need is a 7/8" bore 2 bolt alum MC with the recess in the back for the rubber retainer, the rubber retainer(I've used a piece of vac line) & the manual pushrod. If there's a proportioning problem you can sort that out later & good chance you'll be fine as is.
Re: Should I go to manual brakes or keep power? [Re: RapidRobert] #111848
08/31/08 09:16 PM
08/31/08 09:16 PM
Eugene, OR
FuryBoy Offline OP
FuryBoy  Offline OP
Eugene, OR
So, I ordered all my parts from Zippy...
I got the master cylinder, adapter and adjustable prop valve from him... All I need to order is the manual brake pushrod from Master Power brakes...
Re: Should I go to manual brakes or keep power? [Re: FuryBoy] #111849
09/01/08 10:39 AM
09/01/08 10:39 AM
Hightstown, NJ
njdevil2 Offline
njdevil2  Offline
Hightstown, NJ
MP has a convertion kit for $160, with the iron master cylinder. I wonder if they sell it without the master? Unless Zippy PM's me. I'll call MP 2morrow!
1 of 179
