Re: 16.5 volts at the battery??? VR fail
[Re: 471Magnum]
#1118001
05/06/12 10:31 PM
05/06/12 10:31 PM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
It's wiggin' out again.
Hooked up an O2 sensor and gauge. Getting some really erratic readings. Off the scale lean at idle. Off the scale rich under power. Motor is running way too good to be that far out out of whack. Tech says to check the supply voltage.
Sure enough, at the alternator, I'm getting ~15V. At the Battery I'm showing ~13.5-14. That's with what should be a fully charged battery.
Flipped the DMM over to AC volts and I'm seeing 25-30 VAC. Bad diode(s)?
Everything else seems to be working fine though. No problems with charging, other than the normal dim lights at idle. Weird.
Going to take the alternator in tomorrow to be tested. Probably swap it for piece of mine.
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
[Re: hooziewhatsit]
#1118003
05/07/12 09:34 PM
05/07/12 09:34 PM
471Magnum
Space Station #5
New alternator, same problem. New VR too.
Still getting about 15 V at the alternator and 13.5+ at the battery.
30 VAC too.
-Jim
[Re: 471Magnum]
#1118004
05/10/12 02:59 PM
05/10/12 02:59 PM
Posts: 25 Glendora, CA
MYBD318
Glendora, CA
Check the voltage at the blue wire feeding the VR, probably too much of a voltage drop from the ignition circuit making the VR command more field current causing more voltage drop in the blue sense wire. $.02 Mike
Still a teen just a 416
[Re: MYBD318]
#1118005
05/10/12 03:22 PM
05/10/12 03:22 PM
471Magnum
Space Station #5
Maybe.
I went back and checked the VR ground to body. I cleaned some more paint off the VR and the body as well as improved the mechanical connection (the hole in the firewall was stripped). Haven't had a chance to recheck the voltage yet, but it ohms out with good continuity now. Tonight I'll fire it up to check the voltage.
-Jim
[Re: 471Magnum]
#1118006
05/10/12 04:03 PM
05/10/12 04:03 PM
Posts: 434 sweden
cuda-sweden
sweden
30 VAC too.
so what readings are you looking for,at the alt and the battery,what would be a good reading ?
