67 coronet fender tag decode.. #1117973
11/20/11 07:02 PM
11/20/11 07:02 PM
Pittsfield, Mass.
Russ_Davis Offline OP
Pittsfield, Mass.
Can anyone decode this tag?
Re: 67 coronet fender tag decode.. [Re: Russ_Davis] #1117974
11/20/11 07:21 PM
11/20/11 07:21 PM
FL
HelleOnWheels Offline
FL
http://www.dodgecharger.org/cgi/f67.cgi
This is what I used for my 67
Re: 67 coronet fender tag decode.. [Re: HelleOnWheels] #1117975
11/20/11 07:26 PM
11/20/11 07:26 PM
FL
FL
I would do it for you, but the pic was a little hard to read. I could only run a few of the codes. If you give me better detail pics I could figure it out for you.
I have done lots of detail work on fender tags when doing my RT
Re: 67 coronet fender tag decode.. [Re: Russ_Davis] #1117976
11/20/11 10:04 PM
11/20/11 10:04 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
(1967) WS23 = Coronet R/T
83= 440-4bbl HP
5 = Automatic transmission
485 = 48 = 7.75x14 red wall tires 5 = five tires. Four on the road and one spare
913 = scheduled production date of September 13th, 1966
08304 = Sales Order Number
A/4 = 8.75 axle with 3.23 gears
X/8 = Sure Grip
P6B = interior trim: P = premium level, 6 = vinyl bucket seats B = blue
881= exterior paint = roof and bottom of car painted Bright Blue metallic 1 = car is all one color
U/E = inner upper door frame color = dark blue
S/8 = stripe code = stripe deleted
A/1 = 26" radiator
F/3 = 363 = Coronet R/T
R/1 = 421 = AM radio
X/2 = 522 = tinted windshield
b/4 = 564 = bucket seats
j/5 = 535 = drip trough molding.
67 Coronet R/T. 440 with automatic. 3.23 gears with Sure Grip. Bright blue exterior, blue interior with bucket seats an AM radio. Stripe delete. By the look of the tag, it appears to have been built at the ST. Louis plant.
Re: 67 coronet fender tag decode.. [Re: 69CoronetRT] #2722860
12/10/19 12:12 AM
12/10/19 12:12 AM
Spokane, WA
FastbackJon Offline
FastbackJon  Offline
Spokane, WA
Anyone else find it odd that this tag lists a j5 (top row) which I believe is body side moldings per Galen's white book - code 545?
Most of the 1967 Coronet R/T cars have a '4' here for the standard sill moldings - code 544.
Re: 67 coronet fender tag decode.. [Re: FastbackJon] #2723295
12/11/19 04:37 PM
12/11/19 04:37 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
This is the only car, I ever regret selling.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
