engine starts but then dies help #1117898
11/20/11 06:32 PM
11/20/11 06:32 PM
NC
rc68rr Offline OP
rc68rr  Offline OP
NC
68 RR 383 finally got the engine in it cranks an starts but when you let off the key it dies anyone know what the problem may be ?Thanks to alll
Re: engine starts but then dies help [Re: rc68rr] #1117899
11/20/11 06:55 PM
11/20/11 06:55 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Key switch or ballast resistor.....
Likely losing power to the ignition system.
Or its a wiring issue.
Usually the start circuit provides a full 12 volts to the ignition system during cranking, then after the key is let off, it runs throught he ballast resistor.
Turn the key to on without the engine running, likely there is no power to the coil.
Course, I dont know what your ignition system is like, oem aftermarket...ect..
Re: engine starts but then dies help [Re: NTOLERANCE] #1117900
11/20/11 07:30 PM
11/20/11 07:30 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
99.9% of the time it will be the ballast. Classic symptom and good info in the 'tech' section.
Re: engine starts but then dies help [Re: mikemee1331] #1117901
11/20/11 07:59 PM
11/20/11 07:59 PM
NC
rc68rr Offline OP
rc68rr  Offline OP
NC
It has a stock ingition system in it. Thanks
Re: engine starts but then dies help [Re: rc68rr] #1117902
11/20/11 08:05 PM
11/20/11 08:05 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
TEMPORARILY by pass the ballast and see if it runs.
Re: engine starts but then dies help [Re: NTOLERANCE] #1117903
11/20/11 09:57 PM
11/20/11 09:57 PM
(1) pull the yellow "sol" wire off of the starter relay to disable the starter. (2) key "on" (3) jump starter at the starter relay (large batt stud to brown wire next to it) to crank it & see if it fires
Re: engine starts but then dies help [Re: RapidRobert] #1117904
11/22/11 11:03 PM
11/22/11 11:03 PM
NC
rc68rr Offline OP
rc68rr  Offline OP
NC
Got it running. Had it 15 years & it finally starts & runs. Now its time to work on the body & interior. It was the ingition switch. Thanks for everyones help.
