Hemi car production question.. #1117729
11/20/11 03:57 PM
11/20/11 03:57 PM
NJ-USA
HPMike Offline OP
HPMike  Offline OP
NJ-USA
I always wondered this...
Were Hemi cars produced in "batches", like some other package cars(A12's)? I always thought that maybe because there were so few made(relative to other engine options), that there might have been orders taken, then a line was set up to produce a set amount of Hemi cars on dedicated days or production lines? If you think about it, it does make sense because there is so much about the cars mechanicals that aren't shared with any other powertrain, but??
This thought crossed my mind when I looked at the ad for the 71 Hemi Challenger that is on eBay. The VIN is very close to my 71 Hemi R/T and the SPD are the same. Also, I bought the car from the family of the original owner who had died in the 70's. The brother had a very vivid memory of the circumstances surrounding the purchase of the car. He(orig owner), placed the order and there were several delays from the dealer(factory). Was this because they had to take orders and build them in batches?
Anyone have any insight??
MB
Re: Hemi car production question.. [Re: HPMike] #1117730
11/20/11 04:12 PM
11/20/11 04:12 PM
Kirkland, Washington
Pacnorthcuda Offline
I don't know, but I can say there is logic in doing the exact opposite. We purposefully mix things up on the Kenworth production line in order to balance out the workflow. Even fleets of exact trucks (all identical options/colors etc) are spread out.
Re: Hemi car production question.. [Re: Pacnorthcuda] #1117731
11/20/11 04:18 PM
11/20/11 04:18 PM
Hamtramck, PA
Alaskan_TA Online content
Fluffy Balladeer
Alaskan_TA  Online Content
Fluffy Balladeer
Hamtramck, PA
Cars were not built in batches of the same VIN prefix. They occasionally have the same VIN prefix & sheduled production date, but they may have been actually been built thousands of cars apart.
See https://board.moparts.org/ubbthreads/show...e=0&fpart=1 for more information.
Re: Hemi car production question.. [Re: Pacnorthcuda] #1117732
11/20/11 04:25 PM
11/20/11 04:25 PM
NJ-USA
HPMike Offline OP
HPMike  Offline OP
NJ-USA
While I believe you. It seems counterproductive?? I would think that any factory that has a "non conventional" project would be better off doing them at the same time, to not upset the daily production of the "bread and butter" stuff? But hey, what do I know?
MB
Re: Hemi car production question.. [Re: Alaskan_TA] #1117733
11/20/11 04:27 PM
11/20/11 04:27 PM
NJ-USA
HPMike Offline OP
HPMike  Offline OP
NJ-USA
Interesting....
Then can we assume(as in the case of the two 71 Hemi Cars in the original post), that it was purely a coincidence?.
Great info, as always..
MB
Re: Hemi car production question.. [Re: HPMike] #1117734
11/20/11 04:29 PM
11/20/11 04:29 PM
MB
Well, another reason is when each car is the same people start to make assumptions. Thats dangerous, you want the assemblers referencing the build sheet (we call it build paper) on EVERY car. Few mistakes are made that way.
I agree that it seems counter-intuitive.
Re: Hemi car production question.. [Re: Pacnorthcuda] #1117735
11/20/11 04:44 PM
11/20/11 04:44 PM
Hamtramck, PA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
An example.
Say that you had ten high option Challenger SEs. Due to the extra trim & equipment, these cars took more time to build.
So.....
If you slip in few plain jane Valiants or Dusters in between the higher end cars, they take less time. This allowed the lines to keep moving at a nice, even rate instead of getting bogged down with the builds that took more time.
Re: Hemi car production question.. [Re: Alaskan_TA] #1117736
11/20/11 04:56 PM
11/20/11 04:56 PM
NJ-USA
HPMike Offline OP
HPMike  Offline OP
NJ-USA
An example.
So.....
True...
I was just thinking that the "jigging" had to be all different for the Hemi cars. K frames, wiring, exhaust, just about everything different. Rather than switch everything around in between, then they can run a bunch at the same time...But, I am saying this with NO experience whatsoever with automobile production assembly lines, so I may be just
MB
Re: Hemi car production question.. [Re: HPMike] #1117737
11/20/11 07:55 PM
11/20/11 07:55 PM
Strathroy, Ontario
BS27R1B Offline
BS27R1B  Offline
Strathroy, Ontario
Engine sub assemblies all bolt into the same four holes so as long as the pieces arrived at the right time there should be no delay to the assembly line.
The body arrived with the appropriate'differences' already in place.
If they tried to do them in batches it would throw a real wrench into things if there was a shortage of say the exhaust components, brake boost etc. It would be easier to pull one aside for these problems than a batch of them
I would think the only time we would see batches of similar vehicles was on the first and second day of model year production when company show cars etc were built and there wasn't the same committment to maintaining assembly quotas for the day.
'.. it was long ago and it was far away, and it was so much better than it is today..'
Jim Steinman
Re: Hemi car production question.. [Re: BS27R1B] #1117738
11/20/11 10:42 PM
11/20/11 10:42 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I don't think their was a set rule. It depended on what was ordered and if the parts were available to build.
My 71 Charger R/T Hemi was the first in a series of 6 consecutive serial # Hemi cars ordered by the same dealer. The cars were all low option other than the Hemi engine, they were ordered at the same time and were built in series.
I have the NHOA list of known serial #'s and there is no set pattern.
Sheldon
Re: Hemi car production question.. [Re: RUNCHARGER] #1117739
11/21/11 12:34 AM
11/21/11 12:34 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Looking at several of Tim Wellborn's 71 Charger Hemi cars this weekend at the MCACN show, and talking with him, he says he has 5 consecutive number cars, and all of them that he owns are very close together.
JB Rhinehart, Realist
A-Body's RULE!
Re: Hemi car production question.. [Re: BS27R1B] #1117740
11/21/11 12:36 AM
11/21/11 12:36 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
The "promo" cars were built later than their typical "801" SPDs. Their paperwork may have been in the "pipeline" prior to the start of production, but the cars were built after the initial slow paced model year break-in period.
Re: Hemi car production question.. [Re: Rhinodart] #1117741
11/21/11 12:41 AM
11/21/11 12:41 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I'll "assume" those are all 911 SPD cars from Mr. Norm's. A good percentage of the '71 HEMI Chargers were early model year dealer stock spec'd out for Grand-Spaulding Dodge.
Re: Hemi car production question.. [Re: 6bblgt] #1117742
11/21/11 10:53 AM
11/21/11 10:53 AM
NJ-USA
HPMike Offline OP
HPMike  Offline OP
NJ-USA
All good responses and valid points..
It does make you wonder, though. Why was my car delayed in production? It wasn't a new model,so?? Also, I remember vaguely a converstaion I had with Galen G. regarding hemi car production. The subject of the "SPECIAL HANDLING CAR" (on the broadcast sheet)came up and what was the significance of this. He gave me some answer to the effect that all hemi cars were "priority" type vehicles where a bit more attention to detail was paid. To what extent is anyones guess. My car also has the Y code checked off for "Show car finish".. GG said many hemi cars had this and it didnt really mean anything other than maybe a supervisor needed to pay closer attention...These are the situations where it would be cool to have a Moparts member that was actually in the Hamtramck facility ar the time to give a clear explanation...
Any other input?
MB
Re: Hemi car production question.. [Re: HPMike] #1117743
11/21/11 07:16 PM
11/21/11 07:16 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
It has always been my theory that Hemi cars were built in groupings. They would build a few dozen one day and then wait for a few weeks before making a run of some more. I think if you had all the VINS of the 10k hemi cars built you'd start to see clusters of them. Why I can only speculate... special drivetrain with a lot of special parts?? All the other powertrain cars were commonly built everyday. Kind of gets back to the known fact of how they cast hemi blocks in batches. Maybe they had to wait for a truckload of completed Hemi motors to come in from Marysville.
Re: Hemi car production question.. [Re: hemi70se] #1117744
11/21/11 07:28 PM
11/21/11 07:28 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Not hemis, but an interesting overview...
http://wwnboa.org/patik.htm
Re: Hemi car production question.. [Re: Pacnorthcuda] #1117745
11/21/11 08:45 PM
11/21/11 08:45 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
and yet at the Western Star plant, identically ordered trucks were always built together.....
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Hemi car production question.. [Re: DPelletier] #1117746
11/21/11 09:21 PM
11/21/11 09:21 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
From everything I've read over the years the '66-'71 street Hemis were considered normal production cars built on the line along side everything else. These weren't specialty cars like the Hemi Darts, Superbirds, Daytona Chargers, or Charger 500's. When you think of it, there are really very few parts that were Hemi only.
Re: Hemi car production question.. [Re: 6PakBee] #1117747
11/21/11 09:34 PM
11/21/11 09:34 PM
And a Convertible was probably a BIGGER change to deal with than hemi vs other engines, maybe even A/C too.
Re: Hemi car production question.. [Re: Pacnorthcuda] #1117748
11/22/11 10:54 PM
11/22/11 10:54 PM
ILLinois
DartGTS Offline
super street
DartGTS  Offline
super street
ILLinois
Hello:
FYI
All 68 Hemi A-Body Super Stock Package cars were built at Hamtramack. Instruction were given for items that were to be deleted or special order items that were to be installed differing from standard regular 383 V8 cars. The cars were then sent to Hurst Performance Research. For final assembly and modifications then they usually were trucked back to Chryslers U drive lot for delivery.
Build dates on all 1968 A-Body Hemi cars were Feburary 18,1968(Dart and Barracuda)...May 19,1968(Barracuda)or May 21,1968(Dart) Actual dates may have been different,and may be between Feb.23 and May 23 1968 due to a strike. on may 14,1968 additional 10 Darts were ordered, and on April 2 1968, another 20 Darts and Barracudas were ordered. Final project total was 150 cars. 80 Darts and 70 Barracudas. (From "Authenticity Guide 1968 Dart & Barracuda Hemi Super Stock" by Jim Schild & Larry Griffith)
Maynard
