1933 Plymouth grille insert. #1117722
11/20/11 03:01 PM
11/20/11 03:01 PM
yarnell,az
mopacltd Offline OP
mopacltd  Offline OP
yarnell,az
I am in need of a'33 Plymouth grille insert. Does not have to be perfect as I will be cutting it to fit my altered grille shell. I have a rusted one, so don't need another one of those.
Re: 1933 Plymouth grille insert. [Re: mopacltd] #1117723
11/20/11 11:56 PM
11/20/11 11:56 PM
Minn
SportF Offline
SportF  Offline
Minn
I use to make brushed aluminm ones. But what you may not know is there is two different inserts. I don't remember the models, but about 15% of the cars have a rather flat insert compared to the others which is more rounded at the top and out at the bottom. I believe, but its been a long time, but I think if you don't have a radiator cap hole in your shell you have the "odd" one, which is more flat. I still have the jigs and at least one set of bars already bent, you interested in making your own?
Re: 1933 Plymouth grille insert. [Re: SportF] #1117724
11/21/11 02:13 PM
11/21/11 02:13 PM
yarnell,az
mopacltd Offline OP
mopacltd  Offline OP
yarnell,az
Making my own is what I hav done for most of the mods on my "A". What's ya got to continue with this next step?
