Re: What size of fan do I need?
[Re: ahy]
#1117605
11/20/11 12:57 PM
11/20/11 12:57 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
no fan is going to cure 'hot on the highway' the air being jammed through the radiator from driving at 65mph will be WAY more air than any fan can pull, electric OR mechanical.
sounds more like a water flow problem somewhere. bottom hose getting sucked shut at all? old radiator that's plugged up?
**Photobucket sucks**
[Re: 70Cuda383]
#1117606
11/20/11 03:23 PM
11/20/11 03:23 PM
Posts: 4,924 Tri-Cities, Washington
VITC_GTX
You're correct about the fan not helping at highway speeds. I believe my problem is the restrictions caused by the shroud. It covers the entire radiator except where the two small fans are at. I thought about just removing the shroud as stated above but am looking at options. Also, the lower hose has a spring and is not collapsing.
[Re: VITC_GTX]
#1117607
11/20/11 04:40 PM
11/20/11 04:40 PM
70Cuda383
Marysville, O-H-I-O
I would think that if it's not overheating in traffic, then highway would be the same though.
if the fans pull enough air at slower speeds, then they ought to be pulling the same amount of air while driving.
maybe not though. could be you're making enough heat at freeway speeds the fans couldn't keep up.
go ahead and give it a shot though, remove the shroud and see what happens.
[Re: 70Cuda383]
#1117608
11/20/11 04:49 PM
11/20/11 04:49 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
I have one of those dual electric fans with a shroud & while it's not installed & I don't know that it will be a problem I already plan to modify it & you may want to do the same... I plan to cut 1" x 3" slots in all the flat areas to open up the air flow.. But then I plan to attach rubber flaps to the engine side of the shroud... Now when the electric fans are running at low speeds the flaps will be pulled shut & air will be drawn through the radiator but at higher speed the flaps will open up & allow air the pass at a higher volume than would get past the fan...
[Re: 1_WILD_RT]
#1117609
11/20/11 05:04 PM
11/20/11 05:04 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
BTW I can't believe I typed out the above post, I originally clicked on the thread to post a smartassed comment about how this fan should do the job...
[Re: VITC_GTX]
#1117611
11/22/11 01:05 AM
11/22/11 01:05 AM
Posts: 1,607 Western Washington
Sixgun
Western Washington
Wild RT you are outta control!!! YOU should be a Mod! I never had much luck with the clutch fans, run an 18" stainless flexfan, at least 1/3 into the shroud. Rule of thumb, after about 35MPH the fan don't do nothing.Air flow from grille takes over. A smart fellow once told me to think of air as a fluid, one needs to direct it and dam it to where it's wanted.See if there's anywhere you can put in some easy sheetmetal or plastic 'dams' in front of the core to channel and/or block off any air from spilling around the front outside of the core, and force it to got THROUGH the core. MrG makes a large window 180'harris type thermostat for about 10.00 too.
