MT ET streets do they go bad just sitting? #1117251
11/19/11 11:08 PM
11/19/11 11:08 PM
El Dorado Ca
65signet Offline OP
65signet  Offline OP
El Dorado Ca
I bought a pair in 08 and never use them, i went out to the track and my car just blows them off like i was in the water box, i know that i may need to upgrade my suspension some, but i would think they should hook a little.
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: MT ET streets do they go bad just sitting? [Re: 65signet] #1117252
11/20/11 12:05 AM
11/20/11 12:05 AM
Oak Harbor, WA
W
Wicked49670dart Offline
W
Oak Harbor, WA
Mine have been on for 10 years and no problems, run 10 to 12 psi depending on track conditions with a 1.40 60ft. I do raise them off of the ground if the car is going to sit for an extended amount of time...Matt
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: MT ET streets do they go bad just sitting? [Re: 65signet] #1117253
11/20/11 12:11 AM
11/20/11 12:11 AM
Are you using M/T ET Street bias plys or ET Street Radails and what size? Also what pressure are you using and what width rims are they on now? I bought a used set(2/3 rds. worn out) of 12.50x30x15 ET Sreet bias plys last year from another memember on here that where pretty old, they wouldn't hold air when mounted tubeless I soaped the inside and ran them tubeless for the rest of the year, 1.43 60 ft. times on them
Re: MT ET streets do they go bad just sitting? [Re: Cab_Burge] #1117254
11/20/11 02:36 AM
11/20/11 02:36 AM
baldwinsville new york
a493demon Offline
a493demon  Offline
my 28x11.5x15 where on my car for 10 to 15 years in the sun in n.c then in the snow in n.y and i went 10.69 on them. brad p.s 14 psi e/t street's
Re: MT ET streets do they go bad just sitting? [Re: a493demon] #1117255
11/20/11 04:19 PM
11/20/11 04:19 PM
El Dorado Ca
65signet Offline OP
65signet  Offline OP
El Dorado Ca
They are the ET street radials, i made 8 easy passes on them and then added the Carvert shocks made adjustment with the pinion snubber and got the same results.
So now i don't know if i should get the Hoosier DOTs or Caltracs
PSI in tires was 20
thanks
Re: MT ET streets do they go bad just sitting? [Re: 65signet] #1117256
11/20/11 05:06 PM
11/20/11 05:06 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
My guess would be that you are not getting the weight transfer on the initial hit.
The front suspension needs to be loose and able to move upward about 5 inches before the suspension stops hit. This may require lowering the torsion bar settings and trimming on the front suspension stops. An inexpensive set of 90/10 front shock will help a lot as well (about $100 for the pair).
20psi sounds a little high for you car, I would suggest starting around 16psi (get a GOOD tire gauge! - 1-2 psi make a big change)
If you can, get a friend to take a video of the launch so you can analyze what is really happening. I use a digital camera with video mode, so I can upload to my computer for viewing.
With older tires, you may want to do a little longer burnout on the first burnout of the day to heat the tires up and bring the oils closer to the surface. From then on, short burnouts to keep them from getting too "greasy".
Pay attention to # 4 in the guide below!!!!!
Direct quote from M/T site
BURNOUTS- FOR MOST APPLICATIONS
The length of your burnout will be dictated primarily by the ambient and track conditions. The hotter the temperatures, the shorter the burnout. When the temps get cool, a longer burnout will be necessary. Ideally you want the tire temp to be within 15 degrees of the track temperature on the launch. When the track temps exceed 120 degrees, it is always best to keep your tire temps on the lower side. Here are some additional tips for maximizing the performance of your M/T racing tires.
1. First pass of the day will be your longest. After that follow the guidelines of #2 and #3 stated below.
2. Automatic transmissions and Bias tires with Softer compounds: First pass or two, fairly hard burnout relative to ambient conditions. After that a light burnout should be sufficient.
3. Standard transmission and Radial tires: Typically shorter burnouts are better. A light burnout, enough to haze the tires, then stage immediately.
4. No dry hops. This does nothing to improve traction, and in some cases can have a negative effect.
Good luck and have fun!
Scott
Re: MT ET streets do they go bad just sitting? [Re: ProStDodge] #1117257
11/20/11 05:11 PM
11/20/11 05:11 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Some people use their tires for years, I never had that luck. My cars have always sat inside my cold Ohio garage, and they seem to dry rot or harden the rubber over the winter. It helped to store them in my basement but not much.
Re: MT ET streets do they go bad just sitting? [Re: ProSport] #1117258
11/20/11 05:37 PM
11/20/11 05:37 PM
El Dorado Ca
65signet Offline OP
65signet  Offline OP
El Dorado Ca
I have 90/10 on the front with limit stops, and it goes up about 4 inches or so before it hits, i will try the lower pressure, but the car does not even try to move as soon as i hit the throttle they are spinning.
Re: MT ET streets do they go bad just sitting? [Re: 65signet] #1117259
11/20/11 06:36 PM
11/20/11 06:36 PM
upstate, New York
jvcuda Offline
jvcuda  Offline
upstate, New York
I got the ET Street radials 295/55/15 on 8" wide Weld draglites at 16 psi.My '73 cuda weighs 3500lbs.
440 3500stall convertor, 727 tranny, 3.91 gears on stock leaf springs. I found that I need a pretty good burnout to get any decent 60ft times, 1.62 to 1.65 is normal if I leave the line at 1500 rpm.
john
Re: MT ET streets do they go bad just sitting? [Re: 65signet] #1117260
11/20/11 08:11 PM
11/20/11 08:11 PM
The radials are sensitive to track prep, they don't hook worth a hoot on a bad track is what I have found And they don't recover once they start to spin I have the same size tire in both the radials and bias ply M/T on the same size rims, the radials are about a 1/10 to 2/10 faster on a good track than the bias plys are but not on bad to moderate track. The bias plys will spin a liilte on a bad track and then grab and go, not so on the radials IHTHs BTW, I've gone as quick as 1.43 60 ft on the radials and 1.49 on the bias plys, no spinning on either one of those runs. I have also gone high 1.50 when spinning on the bias plys and slower than that on the radials on a bad track Life is a challenge, it is up to us to overcome the things that make us unhappy
