Re: max effort 59* deg sb? LONG
[Re: fishy340]
#1116787
11/19/11 01:08 PM
11/19/11 01:08 PM
Posts: 2,091 Delray beach, Florida
Performance Only
it al depends on a couple of things. do you have the heads needed for a true max effort n/a combo? if not are you willing to step up? (edelbrock and indy don't fall into this catagory) if not, the No2 will make up the difference. i won't bother with all of the extra costs and issues of either, your probably already aware of them.
machine shop owner and engine builder
[Re: fasthawk6]
#1116794
11/19/11 06:47 PM
11/19/11 06:47 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
it would cost a gazillion dollars to max effort the 59 degree for maybe 100hp
or $500 for a cheater plate kit and it would still be streetable and run on pump gas
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: S/ST 3040]
#1116796
11/19/11 09:23 PM
11/19/11 09:23 PM
Guitar Jones
I have just one word for you, turbocharged.
[Re: hemi-itis]
#1116800
11/19/11 10:28 PM
11/19/11 10:28 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I vote for max 59* 14 to 1 compression with tons of nos!!
Brett Miller W9 cnc'd heads STR Chassis fabraction
