Re: max effort 59* deg sb? LONG
[Re: fishy340]
#1116787
11/19/11 01:08 PM
11/19/11 01:08 PM
Posts: 2,091 Delray beach, Florida
Performance Only
it al depends on a couple of things. do you have the heads needed for a true max effort n/a combo? if not are you willing to step up? (edelbrock and indy don't fall into this catagory) if not, the No2 will make up the difference. i won't bother with all of the extra costs and issues of either, your probably already aware of them.
machine shop owner and engine builder
[Re: fasthawk6]
#1116794
11/19/11 06:47 PM
11/19/11 06:47 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
it would cost a gazillion dollars to max effort the 59 degree for maybe 100hp
or $500 for a cheater plate kit and it would still be streetable and run on pump gas
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: S/ST 3040]
#1116796
11/19/11 09:23 PM
11/19/11 09:23 PM
Posts: 20,627 in a cattle trailer down by th...
Guitar Jones
I have just one word for you, turbocharged.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: hemi-itis]
#1116800
11/19/11 10:28 PM
11/19/11 10:28 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I vote for max 59* 14 to 1 compression with tons of nos!!
Brett Miller W9 cnc'd heads STR Chassis fabraction
