Re: 1970 duster, w5 418, 4 spd e85
[Re: NV69B7RR]
#1116430
12/13/11 12:33 AM
12/13/11 12:33 AM
Posts: 155 Post falls, Idaho
rgreule
Post falls, Idaho
little update.. since i will be putting in a fuel cell i cut the tire sump out.. all the glass is out.. almost ready for blasting. got the rotted out floor out.. used floor i picked up.. car is going to be completly blasted.. underneath and all of the inside so it will be nice to work with clean bare metal every where.. after blasting is mini tub, chromoly cage, and fuel cell mounting and ttrunk sheet metal before it goes to get every square inch painted..
Re: update
[Re: rgreule]
#1116444
09/30/12 11:41 AM
09/30/12 11:41 AM
Nice build, I really like the custom builds. The factory stuff is nice but once you've seen one you've seen them all. Keep up the great work.
