Why can't i mount a msd blaster 2 horizontal? #1116144
11/18/11 01:10 PM
11/18/11 01:10 PM
IL . usa
cjs69mope Offline OP
IL . usa
Hey all, Who says you can't mount a oil filled blaster 2 coil horizontal? Hard to believe that this is true. Is a stock coil not oil filled?
Has any body run the msd blaster 2 on the stock intake mount and how long has it worked for you any problems ?
Thanks for the help Cj.
1969 Dodge Charger 1969 Dodge Superbee
Re: Why can't i mount a msd blaster 2 horizontal? [Re: cjs69mope] #1116145
11/18/11 01:15 PM
11/18/11 01:15 PM
Seaford Delaware
JSR1485 Offline
JSR1485  Offline
Seaford Delaware
PER MSD it depends on which part number you have.
The Blaster Coil is designed to mount in most factory canister coil mounts. MSD also offers a Chrome
Coil Bracket, PN 8213. It is recommended to mount the PN 8202 and 8223 coils in an upright position.
The High Vibration Coil, PN 8222, can be mounted in any position due to its epoxy potting compound
Key words -It is recommended -does not say you have to
Switched to the dark side...
Re: Why can't i mount a msd blaster 2 horizontal? [Re: JSR1485] #1116146
11/18/11 01:19 PM
11/18/11 01:19 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Got a call from a buddy just theother day about his new coil leaking oil....
Yes OE coils are oil filled but apparently the technology to seal the coil has beed lost...
Re: Why can't i mount a msd blaster 2 horizontal? [Re: JSR1485] #1116147
11/18/11 01:21 PM
11/18/11 01:21 PM
IL . usa
IL . usa
Ok thank you. I guess i will have to get the epoxy one and save the other for differant time .
Re: Why can't i mount a msd blaster 2 horizontal? [Re: 1_WILD_RT] #1116148
11/18/11 01:21 PM
11/18/11 01:21 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Yes OE coils are oil filled but apparently the technology to seal the coil is not cost effective for the manufacturer...
Fixed.
- Stu Harmon
Re: Why can't i mount a msd blaster 2 horizontal? [Re: feets] #1116149
11/18/11 01:30 PM
11/18/11 01:30 PM
IL . usa
IL . usa
So are you saying that this is bs and i should try it?
i would like to save the 47 dollars cuz i alerady have the oil filled one .
Re: Why can't i mount a msd blaster 2 horizontal? [Re: cjs69mope] #1116150
11/18/11 01:37 PM
11/18/11 01:37 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
No don't mount the oil filled coil horizontal it will leak... What's BS is the fact that it isn't sealed, if they could seal a coil in the 50's there is no excuse to the low quality stuff they pawn off on us these days...
Re: Why can't i mount a msd blaster 2 horizontal? [Re: 1_WILD_RT] #1116151
11/18/11 01:40 PM
11/18/11 01:40 PM
IL . usa
IL . usa
Ten 4 i got it now .
Re: Why can't i mount a msd blaster 2 horizontal? [Re: cjs69mope] #1116152
11/18/11 02:13 PM
11/18/11 02:13 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
I had a blaster 2 mounted horizontally on a CH4B and never had an issue, I bought it maybe 6 years ago. I did paint it black, I doubt the paint acted as a sealant but who knows.
Re: Why can't i mount a msd blaster 2 horizontal? [Re: Montclaire] #1116153
11/18/11 02:53 PM
11/18/11 02:53 PM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
I have had the blaster 2 coil mounted horizontally on my cuda for over 10 years. No problem at all.
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: Why can't i mount a msd blaster 2 horizontal? [Re: Prodart440] #1116154
11/18/11 03:03 PM
11/18/11 03:03 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Mine is mounted Horizontal and was fine for 18 years then screw down in the tower came lose and it leaked some oil. tighten screw and it is a spare new is still horizontal better check that screw! LOL! :-)
Re: Why can't i mount a msd blaster 2 horizontal? [Re: Prodart440] #1116155
11/18/11 03:06 PM
11/18/11 03:06 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Mounted mine horizontally....I was driving to Vegas from LA 4 years ago...guess when it decided to start leaking, overheat and fail on me?
I was stuck in Victorville at 4am...waiting in front of Pep Boys for 4 hours waiting for them to open to buy a new coil....Don't mount it sideways...
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Why can't i mount a msd blaster 2 horizontal? [Re: cjs69mope] #1116156
11/18/11 03:20 PM
11/18/11 03:20 PM
Ma got by w it. You're financially strapped, I'd do it (horizontle) & carry a spare & not give it a seconds thought
Re: Why can't i mount a msd blaster 2 horizontal? [Re: RapidRobert] #1116157
11/18/11 03:22 PM
11/18/11 03:22 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The older MSD coils were sealed.. They have cheapened the product..
Re: Why can't i mount a msd blaster 2 horizontal? [Re: 1_WILD_RT] #1116158
11/18/11 03:43 PM
11/18/11 03:43 PM
Several years back in a conversation w Don at FBO he was telling me that since (some I'm assuming) of MSD's stuff is made overseas now that there was a very subtle change in the MSD sticker/logo on the coil I believe. I have an 8202 I think & I should give it a good visual & see if I can tell
Re: Why can't i mount a msd blaster 2 horizontal? [Re: RapidRobert] #1116159
11/18/11 04:28 PM
11/18/11 04:28 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
What are the alternatives? Does a hotter coil really make any difference with the mopar ECU? What would be the best parts jobber unit out there?
Re: Why can't i mount a msd blaster 2 horizontal? [Re: cjs69mope] #1116160
11/18/11 06:07 PM
11/18/11 06:07 PM
Alaska
73rrak Offline
73rrak  Offline
Alaska
Vertical and in the wind for me !!!!!
Re: Why can't i mount a msd blaster 2 horizontal? [Re: Montclaire] #1116161
11/18/11 10:18 PM
11/18/11 10:18 PM
Actually the ECU is pretty much just a (coil pri) switch and keeps a constant 42 degrees of dwell. the real power is in coil/ballast selection and the best is an no ballast full 12V E coil and a common parts house 4 pin Mopar replacement ECU or better is a '75 350 chebby HEI OE module or an aftermarket HEI module if OK w non Mopar stuff and can mount the HEI on an alum plate w dielectric grease under the dist hidden as all cheby parts should be. Then dial the dist initial (vac ga method)/total/springs/vac adv IN ORDER and you'll have a killer setup & note "initial" and "total" set w vac adv disconnected/plugged
Re: Why can't i mount a msd blaster 2 horizontal? [Re: 1_WILD_RT] #1116162
11/18/11 10:32 PM
11/18/11 10:32 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
So is there a warning on the MSD package for the store display, shipping, storage, etc., ???
I have one older MSD Blaster that's been on a CHB4 intake manifold horizontal for 7 years now with no problem but as you said the older ones were not a problem.....I have a new one in the "blister" pack that's been laying on its side for five months now in the shop ........yikes gotta run and check it out and see if the oil is leaking
How do we know which ones might leak?
MikeR
Re: Why can't i mount a msd blaster 2 horizontal? [Re: cjs69mope] #1116163
11/18/11 10:35 PM
11/18/11 10:35 PM
AndyF Offline
AndyF  Offline
Hughes has a little L bracket that mounts the coil vertically.
http://www.hughesengines.com/Index/produ...mp;partid=25486
