Why can't i mount a msd blaster 2 horizontal?
#1116144
11/18/11 01:10 PM
11/18/11 01:10 PM
Posts: 587 IL . usa
cjs69mope
IL . usa
Hey all, Who says you can't mount a oil filled blaster 2 coil horizontal? Hard to believe that this is true. Is a stock coil not oil filled? Has any body run the msd blaster 2 on the stock intake mount and how long has it worked for you any problems ? Thanks for the help Cj.
1969 Dodge Charger
1969 Dodge Superbee
Re: Why can't i mount a msd blaster 2 horizontal?
[Re: cjs69mope]
#1116145
11/18/11 01:15 PM
11/18/11 01:15 PM
Posts: 1,123 Seaford Delaware
JSR1485
Seaford Delaware
PER MSD it depends on which part number you have.
The Blaster Coil is designed to mount in most factory canister coil mounts. MSD also offers a Chrome Coil Bracket, PN 8213. It is recommended to mount the PN 8202 and 8223 coils in an upright position. The High Vibration Coil, PN 8222, can be mounted in any position due to its epoxy potting compound
Key words -It is recommended -does not say you have to
Switched to the dark side...
[Re: JSR1485]
#1116146
11/18/11 01:19 PM
11/18/11 01:19 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Got a call from a buddy just theother day about his new coil leaking oil.... Yes OE coils are oil filled but apparently the technology to seal the coil has beed lost...
[Re: JSR1485]
#1116147
11/18/11 01:21 PM
11/18/11 01:21 PM
Posts: 587 IL . usa
cjs69mope
IL . usa
Ok thank you. I guess i will have to get the epoxy one and save the other for differant time .
1969 Dodge Charger
1969 Dodge Superbee
[Re: feets]
#1116149
11/18/11 01:30 PM
11/18/11 01:30 PM
Posts: 587 IL . usa
cjs69mope
IL . usa
So are you saying that this is bs and i should try it? i would like to save the 47 dollars cuz i alerady have the oil filled one .
1969 Dodge Charger
1969 Dodge Superbee
[Re: cjs69mope]
#1116150
11/18/11 01:37 PM
11/18/11 01:37 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
No don't mount the oil filled coil horizontal it will leak... What's BS is the fact that it isn't sealed, if they could seal a coil in the 50's there is no excuse to the low quality stuff they pawn off on us these days...
[Re: 1_WILD_RT]
#1116151
11/18/11 01:40 PM
11/18/11 01:40 PM
Posts: 587 IL . usa
cjs69mope
IL . usa
Ten 4 i got it now . Thanks
1969 Dodge Charger
1969 Dodge Superbee
[Re: Montclaire]
#1116153
11/18/11 02:53 PM
11/18/11 02:53 PM
Posts: 848 Avondale AZ
Prodart440
Avondale AZ
I have had the blaster 2 coil mounted horizontally on my cuda for over 10 years. No problem at all.
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
[Re: Prodart440]
#1116155
11/18/11 03:06 PM
11/18/11 03:06 PM
Posts: 5,890 Athens, Greece
Pyper70
Athens, Greece
Mounted mine horizontally....I was driving to Vegas from LA 4 years ago...guess when it decided to start leaking, overheat and fail on me?
I was stuck in Victorville at 4am...waiting in front of Pep Boys for 4 hours waiting for them to open to buy a new coil....Don't mount it sideways...
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: RapidRobert]
#1116157
11/18/11 03:22 PM
11/18/11 03:22 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
The older MSD coils were sealed.. They have cheapened the product..
[Re: 1_WILD_RT]
#1116162
11/18/11 10:32 PM
11/18/11 10:32 PM
Posts: 21,499 N.E. OHIO, USA
A12
N.E. OHIO, USA
So is there a warning on the MSD package for the store display, shipping, storage, etc., ???
I have one older MSD Blaster that's been on a CHB4 intake manifold horizontal for 7 years now with no problem but as you said the older ones were not a problem.....I have a new one in the "blister" pack that's been laying on its side for five months now in the shop ........yikes gotta run and check it out and see if the oil is leaking
How do we know which ones might leak?
MikeR
