Benefits of MSD Ignition with a 440-6 setup? #111613
08/28/08 11:43 AM
08/28/08 11:43 AM
California
dg_dodge Offline OP
dg_dodge  Offline OP
California
Hello,
I'm slowly starting to go through my relatively stock 440-6 setup in a '70 Super Bee. The only modification I know that it has the "silver box" Mopar electronic ignition. I am not too familiar with all of this, but am learning.
A mechanic I know told me that I should think about adding a MSD ignition box to this setup. He said that without it, getting the proper distributor timing (or curve??) to run the six-pack well would be a lot harder.
I'm not familiar with MSD systems. Can anyone shed some light on whether they would be beneficial to a 440-6 setup like mine? Any downsides to them or special tuning requirements when using one?
Also, if not using MSD, are there improvement suggestions to the distributor itself for a 440-6 with Mopar electronic ignition?
Thanks very much!
Re: Benefits of MSD Ignition with a 440-6 setup? [Re: dg_dodge] #111614
08/28/08 12:02 PM
08/28/08 12:02 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Find a new mechanic.
Contact Don at FBO Systems re: ignition tuning and upgrades for your car: http://www.4secondsflat.com
Re: Benefits of MSD Ignition with a 440-6 setup? [Re: BradH] #111615
08/28/08 01:02 PM
08/28/08 01:02 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i have an FBO sytem on one car and a mopar performance on the other, with no intentions of switching either one out.
Re: Benefits of MSD Ignition with a 440-6 setup? [Re: dg_dodge] #111616
08/28/08 01:11 PM
08/28/08 01:11 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
Anybody can tune an MSD distributer, they are a very nice piece. I would not use FBO, they did a distributer for me and it came wrong, when I sent it back it took them three weeks to get me another one and it has loose parts and a broken pickup.
Re: Benefits of MSD Ignition with a 440-6 setup? [Re: GTXKen] #111617
08/28/08 01:20 PM
08/28/08 01:20 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
I would not use FBO
I know a few people that were using FBO and they had problems with them. I am using MSD dist. and MSD box on my 500hp 6-pack and love it.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Benefits of MSD Ignition with a 440-6 setup? [Re: 70sixpkrt] #111618
08/28/08 01:25 PM
08/28/08 01:25 PM
California
dg_dodge Offline OP
dg_dodge  Offline OP
California
Thanks everyone for the great ideas.
If using MSD, it sounds like you need to add the red box + the MSD distributor ? (or is the new distributor optional?).
And do these work with the Mopar electronic ignition ECU boxes or do they replace them? I currently have the silver one.
Thanks again all for the help.
Re: Benefits of MSD Ignition with a 440-6 setup? [Re: dg_dodge] #111619
08/28/08 02:34 PM
08/28/08 02:34 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
You may have the older MP distributor in your car that would require you to weld up the slots to remove timing from your distributor. The newer MP distributors are supposed to be adjustable. If all you are looking to do is get the right curve just get the newer MP distributor. I believe your mechanic is correct if this is the case.
Re: Benefits of MSD Ignition with a 440-6 setup? [Re: dg_dodge] #111620
08/28/08 02:35 PM
08/28/08 02:35 PM
GTXKen Offline
super gas
GTXKen  Offline
super gas
The ignition box and distributer can be used independently and either will work with other stock parts. If you want to change the curve start with the distributer, it will work with the mopar ignition. The MSD ignition box will replace the mopar ignition.
Re: Benefits of MSD Ignition with a 440-6 setup? [Re: GTXKen] #111621
08/28/08 09:15 PM
08/28/08 09:15 PM
California
dg_dodge Offline OP
dg_dodge  Offline OP
California
Thanks all for the tips.
If I was to use MSD ignition, is timing set the same way as with Mopar electronic ignition? Would I be better off going with an MSD distributor to match the MSD ignition?
Anyone had any bad experiences with MSD??
Re: Benefits of MSD Ignition with a 440-6 setup? [Re: dg_dodge] #111622
08/28/08 09:36 PM
08/28/08 09:36 PM
70sixpkrt Offline
70sixpkrt  Offline
With a MSD dist. your able to adjust the power curve by changing the different color springs and bushings.
http://static.summitracing.com/global/images/instructions/msd-8464_instructions.pdf
4-speed
3:54 Dana
Re: Benefits of MSD Ignition with a 440-6 setup? [Re: 70sixpkrt] #111623
08/28/08 10:57 PM
08/28/08 10:57 PM
Niwot, CO Formerly denn...
dynorad Offline
dynorad  Offline
The main benefit of an MSD over a properly functioning conventional electronic ignition is better idle quality. I did back to back dyno testing between a junkyard blue box and a Crane multispark ignition and there was zero power difference. If your engine has super high cylinder pressure then the higher spark currents may help you, but it didn't help me.
The total timing and ignition curve are set by adjusting the distributor. The MSD box doesn't affect that. The MSD distributor is easier to adjust the curve.
Re: Benefits of MSD Ignition with a 440-6 setup? [Re: dynorad] #111624
08/28/08 11:12 PM
08/28/08 11:12 PM
So which one would you recommend to me to pick for just the dist itself,the newer MP one or the MSD? thank you for your time.
Re: Benefits of MSD Ignition with a 440-6 setup? [Re: RapidRobert] #111625
08/28/08 11:25 PM
08/28/08 11:25 PM
dynorad Offline
dynorad  Offline
I don't know about the new MP distributor or how it compares to the MSD. I welded up and filed the slots in my stock distributor to shorten the mechanical advance (more initial timing to make it idle better). It was a lot of work. But my setup has a low static compression ratio and a relatively long cam duration. Your setup may not need that kind of adjustment.
Re: Benefits of MSD Ignition with a 440-6 setup? [Re: dynorad] #111626
08/28/08 11:33 PM
08/28/08 11:33 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I curved a stock dist that is in my sons Dart and he had the MP orange box on it. He has run 11.40's with that stock dist I worked. His friend gave him an MSD 6A box so I installed it and still use the stock dist. His car ran the same and was no quiker with the MSD box and blaster coil we added to it. I do agree the MSD dist is very easy to work with and adjust and is a great piece but you dont have to use it. I got my hands on a Mallory dist I use in my 63 with the same MP orange box my son used to use and the Mallory dist is a nice piece with easy adjustments also. Ron
Re: Benefits of MSD Ignition with a 440-6 setup? [Re: 383man] #111627
08/30/08 10:28 AM
08/30/08 10:28 AM
I know this is a basic question ... but could someone explain what "curving" the distributor does? And how this will affect timing/performance of the carb?
Thanks much.
Re: Benefits of MSD Ignition with a 440-6 setup? [Re: dg_dodge] #111628
08/30/08 10:55 AM
08/30/08 10:55 AM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
DP--I just recently bought the MP distributor and installed on a 440 MSD 6AL setup. Works great. The latest MP distributors are now made by Mallory and they use a very easy to adjust base plate for setting the amount of centrifugal advance and acess to the springs. The older ones you had to weld and file the slots to adjust amount of advance--it was a pain.
I discovered if you take out the heavy spring and just run it with one light spring the advance in all in by about 2500. You also easily adjust the amount so if you want 18 centrifigal (say, so you can have 18 intitial plus 18 in the dist for a total of 36) its all done by easy trial and error.
You get to making these adjustments in about 5 minutes after doing it the first time.
Its not a bad distributor, and a whole lot less than the MSD.
Re: Benefits of MSD Ignition with a 440-6 setup? [Re: Pacnorthcuda] #111629
08/30/08 11:25 AM
08/30/08 11:25 AM
We've run engineering research dyno tests with MSD distributor vs. regular ignition on all different engines. No power increase.
Re: Benefits of MSD Ignition with a 440-6 setup? #111630
08/30/08 11:57 AM
08/30/08 11:57 AM
I was wondering about quality of construction with the newer MP dist vs MSD?. On the regular ones I've went in & welded slots & then went in again & no mas.
Re: Benefits of MSD Ignition with a 440-6 setup? #111631
08/30/08 12:06 PM
08/30/08 12:06 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Thanks much.
Curving the dist is working the mech timing advance in the dist. You can control how much mech advance the dist has and how fast it comes in by the springs you use. The advantage of the newer MSD dist and the newer Mallory I run is you can control how much advance the dist has with a simple adjustment where on a stock dist in order to change how much total advance the dist has you have to weld up the slots or open them up. You can do a spring change on a stock dist to control how fast the advance comes in but to change the total in a stock dist you need to weld or open the slots depending on how you want to change it. And alot of race cars will lock the dist in one timing setting with no advance as they control all the timing in the ign box they use. Hope this helps some , Ron
