Lunati cams #1116098
11/18/11 10:46 AM
11/18/11 10:46 AM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
..a lot of guys find the fast ramp extreme energy cams a little noisy.
..are the Voodoo cams similar?
Re: Lunati cams [Re: can.al] #1116099
11/18/11 11:35 AM
11/18/11 11:35 AM
scratchnfotraction Offline
i run a voodoo 60710 roller with stock roller gear and comp 901-16 springs no noise(which work with all the lunati voodoo cams,drop on with stock seals and no machine work,unlike the lunati doubles they recomend)
I run a 230/230 @ .050 lunati in a truck with comp 901-16 no noise
i run the lunati bracket master 292/292 in a 360 truck with the comp 901-16 no noise on any of mine.
read a lot of the comps are just noisy and have a bad rap of lobe failures
no comps for me
Re: Lunati cams [Re: scratchnfotraction] #1116100
11/18/11 12:22 PM
11/18/11 12:22 PM
Eden, Texas
Strawdawg Offline
Strawdawg  Offline
Eden, Texas
My 303 hydraulic flat tappet Lunati makes no noise.
Steve
Re: Lunati cams [Re: Strawdawg] #1116101
11/18/11 12:30 PM
11/18/11 12:30 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I run the voodoo 60303 hydraulic cam. Valvetrain runs as quietly as it did with the stock cam.
Re: Lunati cams [Re: can.al] #1116102
11/18/11 01:04 PM
11/18/11 01:04 PM
The Great White North
RAMM Offline
RAMM  Offline
The Comp's Extreme's are somewhat noisy. I have used several Lunati Voodoo's--they are great I use them whenever I can. Oh yeah--no noises either. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Lunati cams [Re: RAMM] #1116103
11/18/11 05:22 PM
11/18/11 05:22 PM
Windsor ,Ca.
K
Keith Richards Offline
K
Windsor ,Ca.
I am running the 303 as well in my stroked 400 (451) '72 4 speed RR. Love the power it has with the 4 speed but it makes clatter between 2000 - 2500 rpm, before and after it is quiet as stock. I talked to the Lunati Tech and was suggested to break in some stock lifters and see how that works. Right now I have the intake and lifters out taking each apart in hopes of finding something but so far all looks good. The tech also said my stock eddy springs should be fine with that cam.
What springs are you other 303 users using?
More info here on my earlier post : https://board.moparts.org/ubbthreads/show...rue#Post6902940
Re: Lunati cams [Re: Keith Richards] #1116104
11/18/11 10:17 PM
11/18/11 10:17 PM
People's Republic of Kali
70runner Offline
70runner  Offline
Another 60303 (440-6) user. Little valvetrain noise, some chop at idle.
Re: Lunati cams [Re: 70runner] #1116105
11/18/11 11:26 PM
11/18/11 11:26 PM
Baltimore, MD
MadMax58 Offline
MadMax58  Offline
Baltimore, MD
I have the lunati 60303 in my 383. There is no valve train noise.
Re: Lunati cams [Re: can.al] #1116106
11/19/11 12:01 AM
11/19/11 12:01 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Lunati Voodoo camshafts have a slower closing ramp than the Comp Thumpers do. It keeps the lifters happier.
I have almost always used Comp cams in everything I built,but lately have been playing with some of the Lunati stuff.
So far I like Lunati better.
Keith
Re: Lunati cams [Re: Dunnuck Racing] #1116107
11/19/11 08:53 PM
11/19/11 08:53 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
Lunati all the way for me too ! don't look anywhere else.......
Dan
