Re: HP for 200mph
[Re: Big B]
#1115653
11/17/11 08:06 PM
11/17/11 08:06 PM
Posts: 99 Tuscaloosa, Alabama
speedfreak440
Tuscaloosa, Alabama
How much power would it take to put a 3500lb car over 200mph?
Over what distance? 1/4, full mile, absolute?? As stated before, bodystyle means alot here too.
Re: HP for 200mph
[Re: Big B]
#1115654
11/17/11 08:30 PM
11/17/11 08:30 PM
Posts: 5,080 organ
maximum entropy
organ
top speed has less to do with weight and power than it has to do with coefficient of drag. a drop tank at bonneville could prolly hit 200 with maybe 300 rwhp? as an added complication, traction usually becomes the limiting factor when you have a lot of power in a brick. you're up against an aerodynamic "brick wall". spinning your wheels trying to push the car through the air. the salt doesn't have real good traction, relatively speaking, so minimizing aerodynamic drag is job one. then move on to the other stuff. weight is often times your friend when going for all out speed. weight can improve traction. i would love to take my scamp to the salt and see if it will do 200, but i know that as it sits, though it may have enough power, it's a box on a box, and there is no way that's gonna happen. it would have to be MUCH slipperier.
Re: HP for 200mph
[Re: Big B]
#1115657
11/17/11 09:07 PM
11/17/11 09:07 PM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
Sorry. 200mph in the 1/4 with a 69 roadrunner. I was guessing 2000+ hp.
Lotsa ways to make that kinda power these days.
Re: HP for 200mph
[Re: Big B]
#1115661
11/17/11 09:58 PM
11/17/11 09:58 PM
jim sciortino
Trumbull,CT.
My car currently has 730hp and runs 10's. Car feels really slow to me now. Thinking about really stepping it up to bring back the fun. Thinking big turbo motor.
730hp @ 3500# should be well into the 9s. I'd square away the car with the current engine before I'd make a big jump.
Although, twins on a bigblock will certainly get rid of the "feels really slow" issue.
Re: HP for 200mph
[Re: Big B]
#1115662
11/17/11 10:02 PM
11/17/11 10:02 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
you should be well into the 9's w/ that kind of power. To hit 200 you might need to do a few things. Lighten the car up. Block off the grill, use a front spoiler lower the car.... I used an online calculator and a 3650 lb car would need about 1400 hp to hit 200 in the 1/4. Not saying that's too much or not enough, just what the computer spit out. As mentioned a wedged shaped car is going to do it easier than a brick.
Re: HP for 200mph
[Re: Mr.Yuck]
#1115665
11/17/11 11:34 PM
11/17/11 11:34 PM
Posts: 174 Oklahoma
hemiiroc
Oklahoma
1400 in a 3650lb car won't get anywhere close to 200
Re: HP for 200mph
[Re: hemiiroc]
#1115666
11/17/11 11:54 PM
11/17/11 11:54 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
No Problem call these guys for engine details.. http://www.prolineracing.net/What about the chassis?? Set another $50K+ aside for that too. You are at dang near Pro Mod levels with that setup. Just look at Jimmy's Dart, not sure what it ended up running, but your over 1000 lbs more too Id say $150K could get you out for half a season...maybe...
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
Re: HP for 200mph
[Re: hemiiroc]
#1115667
11/18/11 12:58 AM
11/18/11 12:58 AM
Posts: 6,566 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
My calculator says about double will do the deed.
Kevin
Re: HP for 200mph
[Re: Bob_Coomer]
#1115668
11/18/11 04:25 AM
11/18/11 04:25 AM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
No Problem call these guys for engine details.. http://www.prolineracing.net/ What about the chassis?? Set another $50K+ aside for that too. You are at dang near Pro Mod levels with that setup. Just look at Jimmy's Dart, not sure what it ended up running, but your over 1000 lbs more too Id say $150K could get you out for half a season...maybe...
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
