opinions needed for race heads #1115605
11/17/11 04:57 PM
11/17/11 04:57 PM
Seaford, Va
Kindafast Offline OP
Seaford, Va
Hey guy's I am in the process of tearing my car back down this year and while I have it apart I figured I would bump the performance up a little. My question is what would be the best suited head for my engine ? 318 X block 4 bolt mains , 422 cubic inches Eagle rods and Steel crank. Ross pistons. I am leaning toward another matched roller cam when I change things also. The engine has about 11.5 compression with my open Eddy heads now. M1 intake and a 950 HP carb. Bang for the buck which heads would get me the most performance ?
6.50 @105.26
Re: opinions needed for race heads [Re: Kindafast] #1115606
11/17/11 05:00 PM
11/17/11 05:00 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Indy 360-1...But what is your hp or performance goal, and where are you at now? Streeted, or strickly race?
Re: opinions needed for race heads [Re: Dragula] #1115607
11/17/11 05:04 PM
11/17/11 05:04 PM
Seaford, Va
Seaford, Va
Streeted a little but mostly race. I am looking for about 700 Hp. Right now we are just shy of 600. I figure keep throwing Hp in my heavy azz car to make up for the creature comforts.
6.50 @105.26
Re: opinions needed for race heads [Re: Kindafast] #1115608
11/17/11 05:36 PM
11/17/11 05:36 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Indy 360s either the 230 0r 245 cnc. I had a set(245) on a 421 sb and made just shy of 700hp with 11.8 to compression.I would think this would really pick up your program.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: opinions needed for race heads [Re: 1967dartgt] #1115609
11/17/11 05:42 PM
11/17/11 05:42 PM
Seaford, Va
Seaford, Va
What rocker , intake and exhaust do the 360s need ?
6.50 @105.26
Re: opinions needed for race heads [Re: Kindafast] #1115610
11/19/11 12:53 AM
11/19/11 12:53 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
If you were changing pistons I'd suggest W9's or B1 BA MC's, but since you're doing a freshen, I agree, the Indy's are the way to go.
I would order up a set of T&D rockers right from the start. The stock Indy stuff is garbage.
Re: opinions needed for race heads [Re: Kindafast] #1115611
11/19/11 09:56 AM
11/19/11 09:56 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
being u have a 59deg blk,i'd also agree w indy's but for the cubic inch u have the 230's version might work better if in the future u go bigger ci then i would go for the 245's be prepared even used indy's are gonna cost well over 3 g's...but you'll dig the power they make. YA DIG?
Re: opinions needed for race heads [Re: Kindafast] #1115612
11/19/11 10:23 AM
11/19/11 10:23 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
INDY 360-1/-2 use standard W-2 manifolds and headers.
The rockers are particular to thse heads. Definitely opt for the T&D set-up.
Re: opinions needed for race heads [Re: S/ST 3040] #1115613
11/19/11 11:05 AM
11/19/11 11:05 AM
Seaford, Va
Seaford, Va
Thanks guy's I may be doing a little shopping soon.
6.50 @105.26
