Indentifying factory A/C boxes - HELP
#1115128
11/16/11 05:14 PM
11/16/11 05:14 PM
Posts: 21,452 It's a dry heat
gtx6970
It's a dry heat
I need some help. I have 3 A/C boxes in the loft.
one is marked MODEL 955 - this one I am reasonably sure is 66-67 B-body
2nd one is marked MODEL 959 - supposed to be B-body when I bought them ???
last one is marked 2877?44 ?? can't make out the missing digit , and it has a 1957 below that which I believe is the date code on the bottom of the case half.
All are / were supposed to B-body A/C boxes
Any owners with unrestored factory A/C boxes wanna ck yours? Please?
by my research the B-body boxes - 1969 Box is 29364?7 ? But the parts book calls out pt # 2936466
1970 Box is 2936892
Every one I have,, the Yellow print is stamped on the end right above where the gas pedal would be
Re: Indentifying factory A/C boxes - HELP
[Re: BTTG]
#1115130
11/16/11 06:44 PM
11/16/11 06:44 PM
Posts: 21,525 N.E. OHIO, USA
A12
N.E. OHIO, USA
I just pulled mine (69 R/T w/ AC SPD Dec 1968) and it was stamped in the same location on the end near the gas pedal as yours and was stamped 2936467 (top line) and 3058 second line.
This doesn't help you ID the one's in question, but suggests there was more than 1 number available on b-bodies for 69.
Kevin, what's the actual SPD of your R/T? My GTX is C16 (and I thought they made a mistake and put the console on the tag twice) or December 16, 1968 and it's an LA assembly car? Which assembly plant for your R/T?
Is the the 3058 for 305th day of 1968?
MikeR
[Re: NicksGarage]
#1115134
11/16/11 10:04 PM
11/16/11 10:04 PM
gtx6970
It's a dry heat
Does the '67 B-body A/C system use the dual heater cores like '68-70? That might give you a clue if they don't.
Yes, 1966 thru 1970 B-bodies with factory air have the dual core heater.
And I think even some of the C-bodies also use a similar dual core heater as well
[Re: BTTG]
#1115137
11/17/11 09:45 AM
11/17/11 09:45 AM
Posts: 582 PA
BTTG
PA
[Re: gtx6970]
#1115142
11/17/11 04:00 PM
11/17/11 04:00 PM
gtx6970
It's a dry heat
did some junkyard rumaging this morning. Found out Model 959 is 1967 C-body But, still have no idea what this one is though
