rear brake backing plates #1115074
11/16/11 02:51 PM
11/16/11 02:51 PM
SE Pa.
LimeliteAero Offline OP
SE Pa.
Anyone know if anyone sells good quality new/reproduction backing plates for a 1970 B-body? my originals are pitted worse than I thought and would like to go with new if possible.
TIA
Re: rear brake backing plates [Re: LimeliteAero] #1115075
11/17/11 10:52 PM
11/17/11 10:52 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I think your stuck with getting a used set and refurbished..
I am truckless..
Re: rear brake backing plates [Re: 340SHORTY] #1115076
11/18/11 12:23 AM
11/18/11 12:23 AM
SE Pa.
SE Pa.
I ended up calling Steves Parts in Arizona and picked up a really sweet looking pair (from the pics anyway, we'll see when they get here)
I found out Y.O. sells them aftermarket but I didnt want to do that because Im sure they fit and work but arent going to look right.
Re: rear brake backing plates [Re: LimeliteAero] #1115077
11/18/11 02:19 AM
11/18/11 02:19 AM
At a gas station near you
badblack68 Offline
badblack68  Offline
If they are 11" I believe the rears are still available through Chrysler.
Nobody gets in to see the wizard!
Ain`t no way!
Ain`t no how!
Re: rear brake backing plates [Re: badblack68] #1115078
11/18/11 09:17 AM
11/18/11 09:17 AM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
But, I think they are no longer side specific. meaning they have 2 holes in them for the park brake cable. ( at least the last time I saw a set they did, but thats been a while)
Rehrenberg has a set on the bay now, and it specifies they are a right and a left, so maybe they've changed since I seen them .
