What combos have you run with a four speed ?
I'm buying more stuff to get the basic 500 hp 446" together. Aftermarket H-beams, forged slugs, stock forged crank, stealth heads, Victor intake and a decent sized hyd roller cam. Stock 1970 833, Lakewood bell, Ram 3500lb pressure plate and HD clutch disc in front of a 489 case with a solid pinion sleeve and 3.91's with a cone-grip. Will prob drop a set of Dr. Diff's stronger axles in, but I'm never going to try and hook it.
What can I expect aside from lots of tire smoke and a broken 8 3/4 ?
I've been ridding around in a 475-500-ish HP 70 Dart Swinger with a basic E-headed 440, RVMB and a 4.10 Spooled 8 3/4" with 26" tires. Dear lord what a violent experience that makes me want a 440 so badly. I will have a little more weight, less gear, a little more power and the stick of course.
Sound bueno ?
