5.9 Magnum and 904 Flexplate Problem #1114794
11/16/11 12:50 AM
11/16/11 12:50 AM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
There was another thread that talked about options for a flexplate used with the 5.9 Magnum and a 904.
Link:
https://board.moparts.org/ubbthreads/show...rue#Post6890292
I ordered a stock 5.9 flexplate and bought a PTC 9.5" converter for my 5.9 magnum but it's not working. The circumference of the flex plate hits the torque converter before the mounting holes on the flexplate touches the converter. There is about a .030" gap there. I believe I could tighten the bolts up and make it contact but didn't know what type of stress this would cause and the consequences of it.
Here are a couple of pictures. Please offer your opinions. Do I need to find another type of flexplate?
Re: 5.9 Magnum and 904 Flexplate Problem [Re: VITC_GTX] #1114795
11/16/11 01:14 AM
11/16/11 01:14 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
I don't remember mine hitting, I ran a PTC converter also, that is strange. After looking over those pix, are the weights clearing, & also see those welded nipples on the ring gear, is the flexplate up against those?
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: 5.9 Magnum and 904 Flexplate Problem [Re: joedust451] #1114796
11/16/11 01:36 AM
11/16/11 01:36 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
The weights don't seem to be touching. The flexplate isn't hitting the welds on the ring gear. The flexplate hits all along its circumference.
Re: 5.9 Magnum and 904 Flexplate Problem [Re: VITC_GTX] #1114797
11/16/11 12:29 PM
11/16/11 12:29 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I ran accross a similar problem once before, had to get a B&M plate. The one I did it was hitting the lugs before it would go down over them. Mabey you could chuck yours in a lathe and trim the ring back, should work fine unless you are runnning EFI.
Re: 5.9 Magnum and 904 Flexplate Problem [Re: VITC_GTX] #1114798
11/16/11 02:34 PM
11/16/11 02:34 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I thought about having the flexplate turned on a lathe as that shouldn't change the balance. I also considered thin shims (washers) between the two pieces to seperate them. Thoughts...
Re: 5.9 Magnum and 904 Flexplate Problem [Re: VITC_GTX] #1114799
11/16/11 02:54 PM
11/16/11 02:54 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
If you shim it you may push the converter too far into the trans and cause other issues, but mabey not I would not try that
Re: 5.9 Magnum and 904 Flexplate Problem [Re: VITC_GTX] #1114800
11/16/11 03:16 PM
11/16/11 03:16 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I think the problem is the design of the PTC ring gear mount, the previous advice was based on the use of a factory converter.
Removing material in that area on a lathe shouldn't affect the balance.
Re: 5.9 Magnum and 904 Flexplate Problem [Re: John_Kunkel] #1114801
11/16/11 09:08 PM
11/16/11 09:08 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
, Now my PTC 11" didn't have any issues, I'd call Kenny & see whats up, explain the problem, If anything i would just put it on a lathe & trim it down, It shouldn't hurt the balance, your not triming much weight off, plus its a total circle, should not affect anything, If it is the ring placement then you might have starter problems too.
Are you shure the weights aren't bottoming out? If you look i see that it not landing flush on the bace above the ring gear, Can you take a few close-up shots?
Re: 5.9 Magnum and 904 Flexplate Problem [Re: joedust451] #1114802
11/17/11 12:26 AM
11/17/11 12:26 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I am pretty sure (98%) that the weights are not hitting. I spent a few minutes checking that out. There is a shoulder on the converter that the plate is resting on. I'm confident that cutting the flexplate down would work just fine but around here it's going to cost $60 or more to do that.
From memory, when I've installed other autos the converter and flexplate were ~3/16" apart when I prepare to bolt them together. I was hoping that the .030" shims wouldn't hurt but I would hate to cause a problem.
I'll get some additional close ups tomorrow.
Re: 5.9 Magnum and 904 Flexplate Problem [Re: VITC_GTX] #1114803
11/17/11 02:33 AM
11/17/11 02:33 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
I wouldn't run shims , you chance running the converter too far in its hub & it could damage it, plus you won't have the support of the whole circumference, just little round washers & risk too much flexing which could crack the flexplate, now if you used a shim "ring" to go around the whole area that might work, but you still risk what i said earlier in this post. I'm shure the ring gear is in the right location, you can run a straight edge across the bolt pads & measure the distance down to the top of the ring gear & varify it with PTC, If its good, Then i would just spend the 60.00 & have it done, But i would call PTC & see what they say, something ain't koshure.
Did you get the 7/16" bolt holes, I never get an aftermarket mopar converter with the stock chinsy bolt holes anymore, they tend to come loose, the 7/16" most likely never will.
Re: 5.9 Magnum and 904 Flexplate Problem [Re: joedust451] #1114804
11/17/11 02:46 AM
11/17/11 02:46 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
The converter does have 7/16" holes. I guess I will starting looking around for a shop that will cut it down.
Re: 5.9 Magnum and 904 Flexplate Problem [Re: VITC_GTX] #1114805
11/17/11 03:58 AM
11/17/11 03:58 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I installed a PTC 9.5" converter with a Magnum style flexplate and didn't have that issue. I'd call Kenny and see if he can help. If not I'd swap in a non magnum style flex plate before I'd spend any $$$ on that one.
Re: 5.9 Magnum and 904 Flexplate Problem [Re: goldmember] #1114806
11/17/11 09:06 AM
11/17/11 09:06 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Van, After studying it for awhile i might see the problem, the plate is resting on the belly of the converter right? And its still a good .030" away from the bolt pads right so far? If this is the cause the mounting pads for the plate are not tall enough, might be a screw up from there end.
Re: 5.9 Magnum and 904 Flexplate Problem [Re: VITC_GTX] #1114807
11/17/11 11:03 PM
11/17/11 11:03 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
OK, went out and verified some things tonight.
1. The weights are not hitting the converter.
2. The flexplate isn't hitting the belly of the conveter.
3. The distance from the mounting lugs to the ring gear is the same on the PTC converter as a stock conveter (~ .640").
4. The outside diameter of the flexplate is 11 7/16"
5. The lip of the flexplate where the windows for the crank sensor are is what is hitting the conveter.
6. The flexplate isn't hitting the welded on ring gear or the weld itself.
Here are some pics showing where it is hitting. Essentially it's hitting the shoulder where the ring gear butts up against. It is part of the face of the converter.
Re: 5.9 Magnum and 904 Flexplate Problem [Re: VITC_GTX] #1114808
11/17/11 11:07 PM
11/17/11 11:07 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Looks like that it's not the right converter. Instead of trying to cobble it together find the right combo. Call the place you got the converter and see what they say about it.
Re: 5.9 Magnum and 904 Flexplate Problem [Re: stumpy] #1114809
11/18/11 06:42 AM
11/18/11 06:42 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Something isn't right, call PTC & see whats up, my flexplate looked just like yours & it didn't rest on that shoulder, I still think the mounting pads are not high enough.
Re: 5.9 Magnum and 904 Flexplate Problem [Re: joedust451] #1114810
11/18/11 10:29 PM
11/18/11 10:29 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I called and talked to Kenny at PTC today. He was very shocked that there was a problem. This was the first issue he had heard of with a Mopar converter not fitting a flexplate. He said the front cover was a "billet" piece and therefore should have no variation from other converters.
He asked for some pictures so I sent them to him this afternoon. I haven't heard anything back yet.
Any possibility that my flexplate isn't correct? I bought it from a junkyard and I was told it came out of a 2001 Dodge 1500 with a 5.9.
Re: 5.9 Magnum and 904 Flexplate Problem [Re: VITC_GTX] #1114811
11/19/11 01:20 AM
11/19/11 01:20 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Perhaps the problem lies with the flange on the flexplate. It won't affect the balance if you take a grinder to the lip. Just tape a line around the edge and remove the amount you need evenly all the way around. It won't take much and you'll save yourself the money and time of taking it to a shop.
Re: 5.9 Magnum and 904 Flexplate Problem [Re: dodgeboy11] #1114812
11/19/11 03:42 AM
11/19/11 03:42 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
I agree, if you have a grinder, I myself (having a steady hand) would use a cut-off disc on it, heck even a dremel, just buy a couple cups of the thin cut-off disc & have at it, may take an hour or so, run tape around it & cut off about .40"-.050" & your set. If you have a table vice, just snug it up so its steady & go to town .
Re: 5.9 Magnum and 904 Flexplate Problem [Re: joedust451] #1114813
11/19/11 01:25 PM
11/19/11 01:25 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I definitely think I have the tools/skills to do this but I didn't know how close I had to be to keep it in balance. I would hate to have a vibration or to do damage to the bearings.
