Can someone ID these 440 engine parts-pics.
#111466
08/28/08 12:38 AM
08/28/08 12:38 AM
Posts: 21,681 San Jose,CA
migsBIG
YouTube is my go-to news source
San Jose,CA
Normally I can do the basic ID thing, but all my stuff is at my friends house while remodeling, thus my need for some info. I bought this 440 block, fly wheel, truck 4brr aircleaner and crankshaft for like $80 (I figured with the price so low, what do I have to loose?). FLywheel number is #3705410 unsure if it's to the 440. block is a motorhome block or truck, figure 8 passages and looks to have been bored over .030 and still has the cross hatching in the cylinders. Though the water passages have some powered dust, the block is pretty clean for something sitting outside in a puddle in a plastic bag for over a year. Here are some numbers off it: Pad 4T 440 HP 2 2 1 vin pad 4A225160 casting numbers on side 1-24-74 date 3698880-440-7 core shift number Her is the crankshaft, which has no numbers on it, just a cast '5' in the front throw and a 'R'in the throw. I would almost swear it's forged, as when I banged it, it had the crispest sound I ever hear in a crank, not the thicker sound of a cast unit. Now if you look at the crank, it's grey in color. I figured the guy might have just painted it. I come to find out after I bought it, it was sitting in a puddle of water with no pertection and it has no rust on it? Comes to find out the stuff came from a machine shop that went out of business and the parts were sold as property adandons. Never seen a crankshaft that could sit in a water soaked bag outside and not rust, weird. Here is a link to more pictures: http://s198.photobucket.com/albums/aa253/moparkillers/?special_track=nav_tab_my_albumsanybody has any info?
Re: Can someone ID these 440 engine parts-pics.
[Re: 6bblgt]
#111470
08/28/08 10:33 AM
08/28/08 10:33 AM
dogdays
The -7 is NOT a core shift number, it is a number telling how many repairs have been made to the core. Think about it, core shift happens during the pour. Any numbers cast onto the block have to be in the mold before the pour. The easiest way to tell the 440 cast crank is to look on the first crank counterweight. There will be the number "440" cast onto the edge of the counterweight. Also the counterweights are very square. A forged crank could be either a 383/400 or a 440, it will have counterweights that have a more rounded shapes. to me they look like lima beans. A crank with lima-bean-shaped counterweights and 2.71 - 2.75" main diameters is a 413 or 440 forged crank. Most 413 cranks have a couple of tangs at the rod throws, they stick out and I think they were intended to throw oil around. Notice that they disappeared at some point when the engineers decided they weren't necessary. Also there are early 413 forged cranks with 8-bolt flat flywheel flanges, these aren't useful without modifiction. Or check the pictures at www.440Source.comR.
[Re: dogdays]
#111471
08/28/08 10:47 AM
08/28/08 10:47 AM
Posts: 4,366 Cleveland, Ohio
northcoastmopar
Cleveland, Ohio
?? How does one know this? Cores are not repaired as a normal case. A corebox, used to create cores, can be repaired or altered.
The "-7" number would have to be labeled on the pattern used to make that particular casting. Probably just a designation on the pattern revision or an identifier for the particular pattern if had more than one pattern (most likely) to make the castings.
[Re: AndyF]
#111472
08/28/08 11:03 AM
08/28/08 11:03 AM
Posts: 75,094 A Banana Republic near you.
JohnRR
1974 440 with a forged crank.
what he and dog days said .
more info ??? like what , the name of the guy that screwed the oil pan on ???
[Re: migsBIG]
#111474
08/28/08 03:04 PM
08/28/08 03:04 PM
migsBIG
San Jose,CA
And john, I was looking for more info on the crank and flywheel, so maybe you can help next time.
Ok let me see here, the block could be a cop car or muscle car block, nothing special just a nice block. Still has cross-hatching marks from when it was rebuilt.
Nobody has info on the crank, as it has NO NUMBERS on it what so ever or that is has a grey coating on it that has no signs of rust though it was being stored outside and exsposed for over a year plus part-way submerged in water? Also, it looks to have been machined, so the counter weight look to have been cut for balancing, hard to tell. That's why I'm having trouble figuring it out.
Thank you for clearing up the core shift number thing, I was up late and posting while I was tired.
Nobody knows what the flywheel goes to?
[Re: migsBIG]
#111476
08/28/08 04:23 PM
08/28/08 04:23 PM
JohnRR
you didn't ask for anything specific just for MORE info ??
anyway that engine would have had 6pk rods in it , so 6pk balancer and external balance flywheel if it were in front of a 4 speed. and numbers , I haven't seen any numbers on forged cranks other than a single digit here or there , is this the first forged 440 crank you have seen ???
as to why it's not a rusted piece of crap , it was probably coated with something to prevent that and it was cleaned off ? the color who knows , have you miced it to see what size journals they are ???
as far as the rest , what Andy said ...
[Re: migsBIG]
#111478
08/28/08 05:20 PM
08/28/08 05:20 PM
Posts: 5,140 East Aurora (Buffalo) NY
RoadRunner
Just a thought, if its a special coating, don't let the machine shop remove it from the journals. Have them try on one of the cast areas first to identify it. A hardened surface can be ground. This sounds really far fetched, but it looks like a Tungsten Carbide coating that we spray on our turbine shafts. We then have it ground to final dimension leaving a very hard and smooth journal surface. In fact, its so hard that we have yet to replace a shaft due to catastophic bearing failure. Needs special grinding wheels though.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
