Page 3 of 4 1 2 3 4
Re: Why is a turbo 400 better than a 727? [Re: Kam*Kuda] #1114256
11/16/11 11:47 AM
11/16/11 11:47 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
I have a CRT built 727...it has the billet steel drum and all the other goodies..I believe its John's Super pro II trans with a trans brake..he built it for me about 6 or so years ago...
I think it goes for $3,500.. and then add in the converter that will range anywhere from $850-$1,000 or have a custom built 2 piece one built for $2,500..
https://www.coperacingtrans.com/product_...e93e95960793c60
and he has another one..super pro III thats about $4,000...
all good stuff
Re: Why is a turbo 400 better than a 727? [Re: maximum entropy] #1114257
11/16/11 12:17 PM
11/16/11 12:17 PM
gregsdart Online content
gregsdart  Online Content
if you say you will NEVER put a GM trans in your mopar, than you are never going to have a fast mopar...
"fast" must mean in the low sevens.
Re: Why is a turbo 400 better than a 727? [Re: gregsdart] #1114258
11/16/11 02:31 PM
11/16/11 02:31 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Years ago, the 727 never held up well on a trans brake. Guys who ran weekly and made as many as 6 or more passes a night on it needed it to last on the trans brake, and the T400 does that. Now with that said, jump ahead to present day, and there are some good parts out there for the 727 these days. No trans will be maintenance free at those Hp levels, and not with the kind of torque and weight your talking about. I would still go Lenco, and seems your in the ball park...
Re: Why is a turbo 400 better than a 727? [Re: gregsdart] #1114259
11/16/11 02:40 PM
11/16/11 02:40 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Fast means low 8s or better....and lets not forget we all fight the same issue that tears up our stuff...weight.....my car is 3675....thats hard on everything
Re: Why is a turbo 400 better than a 727? [Re: Dragula] #1114260
11/16/11 02:44 PM
11/16/11 02:44 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
how about the turbo 400 has better converter choices? I couldn't even get a converter for my car with the 727 unless i made some concessions.
As for the intermediate aluminum drum your not going to see it in the et but it will put less strain on the clutch pack on the 1-2 shift when that drum has to stop spinning. I don't know how much power your car makes but a pretty much stock pre 1968 turbo 400 will live thru 1200 hp no problems (as long as its a quality rebuild with the correct clearences and clutches). All of the *built* ones just have the bigger sprag and drum the earlir ones had. Also if your going to use a ultra bell on the front of it you need to find a 8 bolt pump case/core to build your trans.
After 12-1500 hp you can buy the good shafts and drums but you still will be cheaper than a lenco anything except the cool factor.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Why is a turbo 400 better than a 727? [Re: joshking440] #1114261
11/16/11 03:06 PM
11/16/11 03:06 PM
organ
maximum entropy Offline
organ
thanks for the clarification.
Re: Why is a turbo 400 better than a 727? [Re: bigtimeauto] #1114262
11/16/11 03:13 PM
11/16/11 03:13 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
For converter choices I here that is true. I think it has something to do with the space in the bellhousing limiting the choices on cores.
The factory early sprag will not live reliably anywhere near the power levels you mention. 750 HP is about the limit. There is a "Super sprag" available.
Also, the later 6 bolt pumps can be drilled to 8.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: Why is a turbo 400 better than a 727? [Re: turbobitt] #1114263
11/16/11 03:54 PM
11/16/11 03:54 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Allan G.
correct....I should have said with a 34 element sprag installed.
Re: Why is a turbo 400 better than a 727? [Re: bigtimeauto] #1114264
11/16/11 04:21 PM
11/16/11 04:21 PM
Arkansas
Adrielp Offline
Adrielp  Offline
Arkansas
My question is, how do they get the chrysler transmissions to hold good power in comp eliminator? Lots of engines over there are in 1000-1200HP range. Also, in that same case, they perfect their converters so why are they not limited? Lots of them are being used in gm and chrysler applications
Adriel Paradise
Substation Design Engineer III
Re: Why is a turbo 400 better than a 727? [Re: Adrielp] #1114265
11/16/11 04:53 PM
11/16/11 04:53 PM
Guitar Jones Offline
With a thick midplate you could probably get any converter you want to fit in there. Those Comp trannies use a thick spacer for an adapter.
Re: Why is a turbo 400 better than a 727? [Re: bigtimeauto] #1114266
11/16/11 05:26 PM
11/16/11 05:26 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
Allan G.
No, the 34 element sprag is just a factory upgrade sprag over the factory 16 element. Outer race remains the same and eventually becomes the weak spot. Case lugs for intermediate clutch also have a tendancy to blow out.
The Super sprag is a Cady front drive 36 element sprag machined into a 4L80E drum. Cost for this bad boy is at least $680 from my supplier.
Allan G.
Re: Why is a turbo 400 better than a 727? [Re: Guitar Jones] #1114267
11/16/11 05:28 PM
11/16/11 05:28 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
Good point, also heard of this being done.
Allan G.
Re: Why is a turbo 400 better than a 727? [Re: turbobitt] #1114268
11/16/11 06:08 PM
11/16/11 06:08 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Allan G.
Allan G.
well i guess a lot of cars tha leave my shop only make 750hp then.
Re: Why is a turbo 400 better than a 727? [Re: bigtimeauto] #1114269
11/16/11 08:59 PM
11/16/11 08:59 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
Allan G.
Allan G.
And I guess I havn't proven anything with "only" 928 HP heavy street car using a TH400 either...
I have no fight here. I did use the word "reliably", didn't I ??
Allan G.
Re: WHy is a turbo 4oo better than a 727? [Re: Dragula] #1114270
11/16/11 10:19 PM
11/16/11 10:19 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
IF I had a 1000 hp street car ,.. it would have a Lenco in it.
X2, but mine would be the Lenco drive version...If money allows someday, I just might put one in my +700hp street car!
yesterday's news or should we say racing transmisson
now it's as P/G with a lock up converter is replacing Lenco and Bruno drives.
Huges and ATI both have a version
can hold 3,000 hp snd much lighter than Lenco
home of the
Sox and Martin Hemi Duster
Re: Why is a turbo 400 better than a 727? [Re: Adrielp] #1114271
11/16/11 10:36 PM
11/16/11 10:36 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
3 words; Dave Smith Protrans.
I am about ready to start a 2300HP TF with him. Why? because the last trans I bought from him has 600 runs on it, one rebuilt, clutches only. This is with 1000 ft-lbs of torque, going in. I can tell when its time to rebuild by the 1/2 shift data trace.
Putting it another way, how many of you guys get your 10 inch superduty converter stall speed to 7500 rpm?
8.30's @3400 lbs
Re: Why is a turbo 400 better than a 727? [Re: turbobitt] #1114272
11/20/11 01:21 PM
11/20/11 01:21 PM
mi
dirty magnum Offline
mi
To bullet prof a TH400, your looking at a direct drum with super sprag $680, plus billet input shaft $300, plus all the other normal expense.
Almost forgot about billet intermediate shaft $230. Just as expensive I think...
Allan G.
you only need to change the sprag in a turbo 400 and it will handle 1000hp and live on the street.
Re: Why is a turbo 400 better than a 727? [Re: Kam*Kuda] #1114273
11/20/11 01:54 PM
11/20/11 01:54 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
I see many high horsepower cars using a turbo 400 with lots of luck.
What are the internal workings that allow a 400 to be upgraded and work well.
Where are the weak points in the 727 or 400?
looking at 850-1000hp street strip car.
seams like the new hot setup is powerglide with gear vendors overdrive,many fox body and newer mustangs run then with out fail, with sick 8-9 second 1/4 miles passes on real street cars with turbos or chargers 800-1200 hp
MOPAR OR NO CAR
Re: WHy is a turbo 4oo better than a 727? [Re: HEMIFRED] #1114274
11/20/11 02:37 PM
11/20/11 02:37 PM
Alberta Canada
E
Edge Offline
Edge  Offline
E
Alberta Canada
Not so sure the Lenco is yesterdays racing transmission quite yet. True the new PG's are lighter (my 4 speed lencodrive is very heavy) and have recently been upgraded to handle more Hp, but in my opinion it is not Hp that breaks transmissions it is torque and tire shake, While some of the nitrous car are changing I am not aware of that the supercharged cars have made the move away from the Lenco atleast at this point in time. But I could be wrong. Regardless it is impressive how much power these new generation glides/400's can handle.
Back to the main subject regarding the 727, as stated above a good strong transmission can be built but the availability of different gear sets is real limitation for higher hp applications.
76 Duster work in progress
Re: Why is a turbo 400 better than a 727? [Re: dirty magnum] #1114275
11/20/11 03:09 PM
11/20/11 03:09 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
Allan G.
Intermediate shaft will break at 1000HP. It is not that expensive to replace with a 4340 piece. Front drive hub will most likley fail as well. Another inexpensive piece. The Input would by on the edge of stripping out of the drum.
Page 3 of 4 1 2 3 4
