Why is a turbo 400 better than a 727?
#1114216
11/15/11 01:56 PM
11/15/11 01:56 PM
Posts: 4,243 Canada
Kam*Kuda
Canada
I see many high horsepower cars using a turbo 400 with lots of luck. What are the internal workings that allow a 400 to be upgraded and work well.
Where are the weak points in the 727 or 400?
looking at 850-1000hp street strip car.
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
Re: WHy is a turbo 4oo better than a 727?
[Re: dOrk !]
#1114218
11/15/11 02:15 PM
11/15/11 02:15 PM
Posts: 12,387 Taxes & Virus's R-US, NY
Dragula
IF I had a 1000 hp street car ,.. it would have a Lenco in it.
X2, but mine would be the Lenco drive version...If money allows someday, I just might put one in my +700hp street car!
Re: Why is a turbo 400 better than a 727?
[Re: JohnRR]
#1114220
11/15/11 02:19 PM
11/15/11 02:19 PM
Posts: 12,339 somwhere
smokinwoody
somwhere
I think it's because the 400 doesn't have that ticking bomb of a front drum to worry about , also it's cheaper to build one than a 727.
not really....
[Re: smokinwoody]
#1114221
11/15/11 02:33 PM
11/15/11 02:33 PM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
not really....
Not really what , the ticking bomb or the cost ?
[Re: JohnRR]
#1114222
11/15/11 02:37 PM
11/15/11 02:37 PM
smokinwoody
somwhere
not really....
cost....my 400 was just as much if not more than my CRT built 727...and add the 2 piece converter...over the top...Im selling mine for half of what I have in it and its never been in a car...
[Re: smokinwoody]
#1114223
11/15/11 03:12 PM
11/15/11 03:12 PM
Guitar Jones
TH 400 can blow up too. It's just that it's a Chevrolet and there are more companies willing to produce good parts for them.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: dOrk !]
#1114227
11/15/11 04:27 PM
11/15/11 04:27 PM
Posts: 417 reynoldsburg,ohio
poppaj
reynoldsburg,ohio
more power loss with a 400
AA/NSS 65'Coronet "Whompin Wedge" Pop & Son Performance 557" B-1 power John Holt Chassis
[Re: 65dragnet]
#1114229
11/15/11 06:10 PM
11/15/11 06:10 PM
JohnRR
U.S.S.A.
A 727 is a TIME BOMB ?
With a aftermarket drum in it .... it is perfectly safe.
Absolutely safe with steel front drum , lowband apply valvebody and 16 roller sprag
With all those parts it is , but it's not cheap and most mopar guys are tightwads ...
[Re: JohnRR]
#1114230
11/15/11 06:12 PM
11/15/11 06:12 PM
Guitar Jones
So the 400 and the conversion is cheaper?
[Re: Guitar Jones]
#1114231
11/15/11 06:14 PM
11/15/11 06:14 PM
JohnRR
U.S.S.A.
You'll notice I said MOST ... I don't think it would be, but there is something that draws people away from the 727.
[Re: Guitar Jones]
#1114232
11/15/11 06:15 PM
11/15/11 06:15 PM
Posts: 760 Southington Ct.
turbobitt
Southington Ct.
To bullet prof a TH400, your looking at a direct drum with super sprag $680, plus billet input shaft $300, plus all the other normal expense. Almost forgot about billet intermediate shaft $230. Just as expensive I think... Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: Kam*Kuda]
#1114234
11/15/11 06:53 PM
11/15/11 06:53 PM
Posts: 25,791 Rio Linda, CA
John_Kunkel
Rio Linda, CA
There are a couple of things that make the TH400 "better" especially for drag racing.
When modified with a manual valve body you don't have the shift overlap problems inherent with the Torqueflite design, in the TH400 you just add clutches to upshift...no release/apply overlap.
Also, the "wrap around" case design of the Th400 is stronger than the open bottom design of the TF...less case flex.
As far as the "time bomb" argument...ALL automatic transmissions can explode; that's why NHRA requires diapers/shields on all of them.
