How Do I connect Steering Wheel Center #111412
08/27/08 10:28 PM
08/27/08 10:28 PM
Anonymous OP
Anonymous OP
Can any one tell me how to connect the inner part of the steering to the part that is connected to the steering shaft. I need the part that couples the two - see photos of what I have.
http://usera.imagecave.com/pavell/DSC00001.JPG
http://usera.imagecave.com/pavell/DSC00002.JPG
http://usera.imagecave.com/pavell/DSC00003.JPG
Re: How Do I connect Steering Wheel Center #111413
08/28/08 09:27 AM
08/28/08 09:27 AM
Anonymous OP
Anonymous OP
Re: How Do I connect Steering Wheel Center #111414
08/28/08 10:58 AM
08/28/08 10:58 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The horn switch needs to be screwed to the steering wheel with three small screws. There is a tab on it so it will only fit one way. The black part goes against the wheel just like the last pic.
Re: How Do I connect Steering Wheel Center [Re: stumpy] #111415
08/28/08 01:25 PM
08/28/08 01:25 PM
Anonymous OP
Anonymous OP
I understand how the horn switch is mounted- but how does the three spoked horn apply part affix itself to the switch- it seems there must be an intermediate part that is missing.
Re: How Do I connect Steering Wheel Center #111416
08/28/08 03:05 PM
08/28/08 03:05 PM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
I see 3 shiny metal spots on the horn ring. Looks like the hooks are broke off.
Re: How Do I connect Steering Wheel Center #111417
08/28/08 03:06 PM
08/28/08 03:06 PM
Seminole County FL to Plymouth...
Barry70GTX Offline
Barry70GTX  Offline
It looks like the horn switch has three taped holes for the center horn ring to bolt to.
Do you have a picture of the horn center with out the horn switch on it?
NMCA NSS 67 Coronet
Re: How Do I connect Steering Wheel Center [Re: Barry70GTX] #111418
08/29/08 10:53 PM
08/29/08 10:53 PM
WOODGRAINWHEELS.COM Indiana
plumbeeper Offline
plumbeeper  Offline
You need this piece that bolts to the top of the aluminum piece that is on your horn switch. Then you can attach the steering wheel center pad to this piece with one bolt through the center of the pad. You could make one of these pieces fairly easily.
