A-arm or Strut front stub in an A Body???? #1113931
11/14/11 11:37 PM
11/14/11 11:37 PM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
I didn't want to hijack the QA1 thread...
What have you guys used? I was looking at the Alston front strut weld in stub. I priced out about 3200 for the strut stub kit. Is this about right?
What are the pros/cons from a-arm to strut?
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: A-arm or Strut front stub in an A Body???? [Re: DemonDust] #1113932
11/15/11 12:24 AM
11/15/11 12:24 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
strut front ends will limit you to never racing in any of the small tire classes
that 3200 can be better spend elsewhere
like a bobs profab front end
Or just leave it alone.... SS/AH cars do ok
Re: A-arm or Strut front stub in an A Body???? [Re: joshking440] #1113933
11/15/11 02:14 AM
11/15/11 02:14 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: A-arm or Strut front stub in an A Body???? [Re: DemonDust] #1113934
11/15/11 03:30 AM
11/15/11 03:30 AM
Guitar Jones Offline
Strut front ends are lighter, simpler and provide more room in the engine area for headers and such. Less moving parts than an a arm system and easy to adjust.
Re: A-arm or Strut front stub in an A Body???? [Re: Guitar Jones] #1113935
11/15/11 11:42 AM
11/15/11 11:42 AM
gregsdart Offline
gregsdart  Offline
Struts are great for classes or projects that they will fit into. With the bottom rail or tube lower than any other system, you can't beat the amount of options you have for what goes where. But like said, certain classes don't allow it. One thing that comes to mind for me is the ease of working on the car. A little tougher with a A arm deal due to the frame rail locations, etc.
