ATF 7176 #1113894
11/14/11 10:39 PM
11/14/11 10:39 PM
Oahu, Hawaii
P
ParadiseCuda Offline OP
P
Oahu, Hawaii
I have a 1994 grand caravan with a 4 speed automatic that needs some transmission fluid. The owners manual says to use ATF 7176 that is no longer available. ATF 3 is also not available. I have seen info on the internet that states the new ATF+4 is good to use for the older transmissions fluids. Is it ok to use ATF+4 in this 1994 dodge 4 speed automatic?
Re: ATF 7176 [Re: ParadiseCuda] #1113895
11/14/11 10:40 PM
11/14/11 10:40 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
yes ATF +4 is the replacement for ATF +3
Re: ATF 7176 [Re: JohnRR] #1113896
11/15/11 10:23 PM
11/15/11 10:23 PM
Oahu, Hawaii
P
P
Oahu, Hawaii
Thanks John
