Page 1 of 4 1 2 3 4
A-833 4 speed racers...Setup? #1113628
11/14/11 04:38 PM
11/14/11 04:38 PM
...gently down the stream
LAR_414 Offline OP
LAR_414  Offline OP
Due to the extremely small group that race 4 speeds, I just want to see what your setup is.
Looking for setups that have a A-833 4 speed
Stock Syncros (not a crash box).
Are you powershifting each gear? What RPM? 23 or 18 spline
What fluid are you using? How much fluid?
What type of clutch?
What weight?
What RPM are you launching at?
Tires spinning at the line or clutch slipping?
I'm leaving around 6,000 with a 23 spline 2.65 1st gear.
Shift around 6,200
Traps around 6,400
Tires spin, clutch is a dual disc McLeod RST (doesn't slip)
Weight about 3400 with me in it
Powershift all gears
Fluid is currently Passon Lube 4 quarts plus a little more to get it up just below the fill plug
Re: A-833 4 speed racers...Setup? [Re: LAR_414] #1113629
11/14/11 05:36 PM
11/14/11 05:36 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Larry, what tires ? 6000rpm launch ... yikes ...
Re: A-833 4 speed racers...Setup? [Re: JohnRR] #1113630
11/14/11 05:54 PM
11/14/11 05:54 PM
LAR_414 Offline OP
LAR_414  Offline OP
MT ET streets 28x10.5
Yeah, but 6,000rpm makes for quite a fun ride!
Seriously, the car kept 60' better and better the higher I went. I've played with the shock settings a bit, tire pressure, and spring clampings along with launch rpm. I normally launch between 5,600 and 6,000rpm right now.
Re: A-833 4 speed racers...Setup? [Re: LAR_414] #1113631
11/14/11 08:25 PM
11/14/11 08:25 PM
St. Croix, US Virgin Islands
David_in_St_Croi Offline
We have a 70 RR currently with a Performance Only 452. 23 spline 833, no mods. 4.3 S60 with a true trac. Tim Hyatt built Mcleod based Soft-Lock clutch. Still playing around with clutch settings, have been dropping base pressure to as low as 3 turns.
Original 383 rear leaf springs, have been clamping them and breaking 3/8" Grade 8 bolts on the clamps so clamping must be doing something. Shocks are stock from Advance Auto (I think, bought them when on a trip up to Babylon a few years back). Tires are Hoosier 9x29x15, D07 compound. Just getting used to those. Before were 9x28x15 D06 compound.
Typically I launch 5000, 5500 hundred (no two step or anything) Generally if anything have wheelspin issues.
Plan to add frame connectors when the engine comes out to fix the roller lifter that got lunched.
Best time is 11.67 at around 120. 60 ft's down in the 1.61 range,although it claimed 1.45 once but I have to believe that was a timing light glitch.
Car could really use cal-tracs and I am sure new springs and adjustable shocks.
The front suspension is the same stock shocks and I have 1" torsion bars for our streets down here. I do drop the front end down until the bump stops are maybe 1/2" off the frame
Tranny oil is 80-90 gear oil, Coastal brand I think.
It is a blast, no way am I going auto.
How long that 23 spline will continue to last in a 3800 pound RR time will tell. I am sure the Tim Hyatt clutch is a big factor in the tranny living. A Jerico or Nash would be nice eventually. I have no problem with non-synchro transmissions, either on the street or the track (actually would prefer it, but currently own the 833).
On the street I just tighten up the clutch and put the street tires on. Sometimes I even put the mufflers back on.
https://www.facebook.com/THENEWCDRA
Proud member of the liberal scientific elite
Re: A-833 4 speed racers...Setup? [Re: LAR_414] #1113632
11/14/11 08:48 PM
11/14/11 08:48 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
A synchro'd 833 is going to be one big PITA on a real racecar. You will have NO consistency. Even though they are strong, they were the worst shifting 4 speeds of all musclecars back in the day... They were slick shifting these things almost from their inception...
MB
Re: A-833 4 speed racers...Setup? [Re: David_in_St_Croi] #1113633
11/14/11 08:52 PM
11/14/11 08:52 PM
Cincinnati Oh
fasthawk6 Offline
fasthawk6  Offline
Cincinnati Oh
23 Spline , center force clutch.Leave off a 2 step at 3500 rpm and runs 60 fts in the low to mid 1.6s on a 27/10 et street with caltracs and factory leafsprings.Has qa1 adj shocks all the way around. I shift at 7200 to 7400 with 4.10s and run 126 mph at 3470.Still a factory setup trans .
Re: A-833 4 speed racers...Setup? [Re: LAR_414] #1113634
11/14/11 08:55 PM
11/14/11 08:55 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Power level and e/t may be good ones to add in here as well...This past years setup is in my sig- junkyard bottom end 360 making maybe 320 to the wheels at the most based on e/t and mph calcs.
23 spline, powershifting every gear at the track
Launching at 5k (didnt like 5500, so i went back down) shifting around 6-6100 (light is set at 5900)
Trapping at about 5500 (needs more gear)
3400lb car with me in it
Using a Centerforce Dual Friction
28x12.5 et streets, stock 6cyl springs and the full caltrac setup, not spinning much (maybe 1 turn?)
For fluid I tried a bunch...right now running Castrol Type F in it, but im thinking of running heavy gear oil in it this upcoming season...
transmission was always popping out of 2nd on decel and sometimes crunching on the 2-3 powershift towards the end of the season...picking a backup transmission up soon, and im going to refresh both over the winter
This thing is never getting an auto
Re: A-833 4 speed racers...Setup? [Re: mshred] #1113635
11/15/11 08:42 AM
11/15/11 08:42 AM
sweden
sshemi Offline
sshemi  Offline
sweden
How do the centerforce df clutch work? does it slip and how fast does it wear out?
Re: A-833 4 speed racers...Setup? [Re: sshemi] #1113636
11/15/11 08:53 AM
11/15/11 08:53 AM
Cincinnati Oh
fasthawk6 Offline
fasthawk6  Offline
Cincinnati Oh
It does not slip. Seems to be a good clutch but depending on power level it can be hard on parts and wears seems to be good.
Re: A-833 4 speed racers...Setup? [Re: LAR_414] #1113637
11/15/11 09:05 AM
11/15/11 09:05 AM
Fairfield Maine
hemi4speed Offline
hemi4speed  Offline
Fairfield Maine
Original stock 4 speed 23 spline
Power shifting at 62-6500 RPM
Launching at 38-4000 (didnt like anything above 4500) 1.62 60ft best.
original leafs with one full leaf added and clamped
DF Centerforce the best non-ajustable street and strip clutch set up so far.
Tires spin very little.
80-90 lube non syn
best 7.52@ 93 mph 1/8 mile, should go high 11's in 1/4?
3350 with me in it
Not at the track enough to get real consistant, but a blast to drive
Re: A-833 4 speed racers...Setup? [Re: fasthawk6] #1113638
11/15/11 10:16 AM
11/15/11 10:16 AM
LAR_414 Offline OP
LAR_414  Offline OP
Great stuff guys. Glad to see my dad and I aren't the only ones out there pounding on a "stock" A-833.
I agree that they aren't the most consistent trans due to the syncros, but being that they are street cars, downshifting is a must.
We only go to the track a few times a year to have fun.
Re: A-833 4 speed racers...Setup? [Re: LAR_414] #1113639
11/15/11 12:13 PM
11/15/11 12:13 PM
Netherlands
72Challenger Offline
Netherlands
Rowing these gears is the best way to enjoy your car if you ask me. I changed to a 833 (18spline)couple of years ago resulting in breaking teeth of the gears, ruining clutches while trying different setups but all without any real luck. This all was with my street/strip challenger with 528 Hemi running 10's.
In the end bite the bullet and got myself a tubechassis car and bought a GForce 4-speed and custom AC clutch setup to put behind the same pumpgas street engine.
Results; 8,9's and it's still alive
Can't improve the funfactor
Re: A-833 4 speed racers...Setup? [Re: 72Challenger] #1113640
11/15/11 02:23 PM
11/15/11 02:23 PM
Barboursville, VA
belvedere383 Offline
Barboursville, VA
My setup is:
65 Belvedere II
65 A833 w/ ball and trunion
RXT twin Disc
Launch at 3400-3500 slipping the clutch
Goes like 1.70 60ft
Usually shift it at 7200
80w90 gear oil in Trans
All of this behind a 496 B motor, it usually runs around 11.1x at around 125-126.
When I really get after it on the launch it breaks something, last time out I put the 2 step to 5500 and it broke the spring perches clean off of the rear end.
65' Belvedere
496'' Stroker
Indy Heads
Re: A-833 4 speed racers...Setup? [Re: belvedere383] #1113641
11/15/11 03:01 PM
11/15/11 03:01 PM
LAR_414 Offline OP
LAR_414  Offline OP
Power shifting that thing with that gear oil and at 7k+rpm?
18 or 23 spline?
Re: A-833 4 speed racers...Setup? [Re: LAR_414] #1113642
11/15/11 03:06 PM
11/15/11 03:06 PM
Cleveland Ohio
10secGTX Offline
10secGTX  Offline
Cleveland Ohio
Larry look up Mike Laboda he runs a group called UMTR.United Manual Trans Racing group
They can help you with all of this
Re: A-833 4 speed racers...Setup? [Re: 10secGTX] #1113643
11/15/11 04:00 PM
11/15/11 04:00 PM
LAR_414 Offline OP
LAR_414  Offline OP
I talk to Mike when I see him at the track and I've run one UMTR event before (runner up).
Most of those guys all run "race only" setups. Crash boxes and aftermarket transmissions for racing.
I'm looking more at "Stock" A-833 racers....kind of a small exclusive group of us!
Re: A-833 4 speed racers...Setup? [Re: LAR_414] #1113644
11/15/11 04:09 PM
11/15/11 04:09 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Mine is super slow (low 14's high 13's) but it has a stock A833 with 90W, RAM clutch, and is launched off idle or very low rpm's (rock hard radial street tires)and gets really bad 60 foot times. LOL. Car weight is 3,400 pounds, and is shifted at around 5,500 RPM.
http://www.youtube.com/watch?v=2XBnEmcYS4c
Re: A-833 4 speed racers...Setup? [Re: LAR_414] #1113645
11/15/11 06:24 PM
11/15/11 06:24 PM
Barboursville, VA
Barboursville, VA
18 or 23 spline?
Its the stock 23 spline, no slick shift or anything. When I opened up the case last time it showed a little bit of brass from the synchros but nothing that scared me.
65' Belvedere
496'' Stroker
Indy Heads
Re: A-833 4 speed racers...Setup? [Re: belvedere383] #1113646
11/18/11 08:34 PM
11/18/11 08:34 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Seeing as how my son started this post I'll drop my combo for all to scrutinize.
engine 446 ci big block
car 68 Roadrunner
weight 3926 with me in the seat
Trans is stock 23 spline A833 no mods.
trans fluid ATF dextron
Launch rpm 49-5600 rpm depending on track conditions.
shift 6400 rpm
trap rpm 6300
slick pressure anywhere from 15 - 19 psi
rear gear 4.56 Dana
Clutch is Center Force Dual Friction 11" with aluminum flywheel (13 pounds)
best et and mph is signature
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: A-833 4 speed racers...Setup? [Re: 68LAR] #1113647
11/18/11 11:07 PM
11/18/11 11:07 PM
Post falls, Idaho
rgreule Offline
rgreule  Offline
Post falls, Idaho
subscribed..
Page 1 of 4 1 2 3 4
