Re: # matching roadrunner
[Re: 1965val]
#1113600
11/14/11 05:17 PM
11/14/11 05:17 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Hello and welcome. There are many definitions (or levels, if you will) when it comes to "Number's Matching". Keep in mind that in 1968, the VIN wasn't stamped on the body (rad support and trunk rail) like it was in later years so you have to match the SO number to the VIN. Do you have the fender tag and Broadcast sheet? Here's some reading for you, though I would worry primarily that the VIN and body match and it's a bonus if you still have the original motor and trans; http://andy440.com/other.htmGood luck. Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: 1965val]
#1113601
11/14/11 05:31 PM
11/14/11 05:31 PM
Posts: 75,066 U.S.S.A.
JohnRR
U.S.S.A.
There is a thread about 68 Hemi engines in the resto forum that will show you were to look for the VIN . Here is the thread showing 68 VIN stamping location , it is the same whether it's a hemi or BB . linky
[Re: 1965val]
#1113604
11/15/11 01:17 AM
11/15/11 01:17 AM
JohnRR
U.S.S.A.
Vin #rm21h8a327120 the # by the oil pan drivers side is pt383h25301276 casting # on block drivers side 2468130-11-LL below that casting#6 20 68 engine stamp behind distributorD3837-1-2 any info would be a big help thanks chris
We can't see the back of your engine from here ... well I can't ...
[Re: 1965val]
#1113605
11/15/11 03:12 AM
11/15/11 03:12 AM
Posts: 17,518 Las Vegas, NV
6bblgt
Las Vegas, NV
RM21H8A327120 would've been Scheduled for Production during the last week of June 1968. PT383H25301276 - PT = Trenton engine Plant, 383 = cu. in., H = standard 4bbl eng., 2530 = 7/1/68 short block assembly date, 1276 = unit number 2468130-11-LL = casting number 383 cu. in. block 6/20/68 = casting date D383 7 1 2 - D = 1968 model year, 383 = cu. in., 7 1 = 7/1/68 - final assembly date, 2 = 2nd shift WAG - not the assembly line original VIN stamped engine, but I'd bet it has been there since the car was new. What is stamped HERE??
[Re: 6bblgt]
#1113606
11/15/11 09:10 AM
11/15/11 09:10 AM
JohnRR
U.S.S.A.
Dan just highlighted something I missed, it's NOT an HP engine, definitely not the original engine .
[Re: JohnRR]
#1113607
11/15/11 10:14 AM
11/15/11 10:14 AM
Posts: 1,385 Az
69hemibeep
Az
If it's an A/C car I don't think it would be HP? I know in 69 they were different.
1969 Hemi Roadrunner 2nd owner
[Re: 69hemibeep]
#1113609
11/15/11 11:21 AM
11/15/11 11:21 AM
JohnRR
U.S.S.A.
I thought about that after I posted and was going to reread and ask the OP if it's an A/C car .
[Re: 1965val]
#1113610
11/15/11 11:23 AM
11/15/11 11:23 AM
JohnRR
U.S.S.A.
Thanks for the info I also have 1965 signet one has to go not sure witch one yet will post some picks thanks
Have you looked at the trans to see if it is stamped ? Does the car have A/C ?
[Re: 1965val]
#1113615
11/16/11 03:13 PM
11/16/11 03:13 PM
JohnRR
U.S.S.A.
The #7120 that is on the block by the oil pressure sender that matches the last 4 # in the serial # is this a matching # engine thanks
You need to see them all , without a picture there is no way of telling if someone else stamped them ? If it is the matching engine the number on the bottom of the pan tells one that the factory installed the WRONG engine in the car .
