Syn. trans fluid instead of power steering fluid? #1113104
11/13/11 10:24 PM
11/13/11 10:24 PM
Bristol, Va
fasteddie Offline OP
Bristol, Va
Is there any problem with substituting synthetic trans fluid for power steering fluid? I have put a steering cooler on this truck and was going to switch to synthetic fluid. I have some syn trans fluid here and thought I would use it. The truck is a carpet cleaning unit that runs off the truck engine. It runs at about 1500 rpm and the fluid smelled pretty bad. The cooler will help the pump last longer. Syn fluid will help too.
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
Re: Syn. trans fluid instead of power steering fluid? [Re: fasteddie] #1113105
11/13/11 11:33 PM
11/13/11 11:33 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Not sure what year truck, but some of the additives may not be suitable for certain seals or hoses. You may get leaks.
