My friend Stephens Car has the 306s and he wants to know what that cam will do with more compression and that camshaft or the mopar one.
11.79 compression
RHS heads flow 286 .550 and 290 @ 600
Port Matched Air gap Eddy
850 dp
and its between Mopar Performance Cam P4120655 Mechanical Flat Tappet, Adv. Duration 296/296, with 76 ABDC which would give me 8.55 DCR and 91
.594 intake and .594 exhaust
or
306s which is 260/260 with 76 ABDC lift at .555 and .555 which would give DCR of 8.29 .592 intake and Exhaust lift with 1.6 rockers
Should also mention, friend with 11.2 compression runs eddy heads and that mopar cam and made 521hp
What do you guys think?
