Got a '64-'69 NHRA Rulebook? #1112856
11/13/11 05:59 PM
11/13/11 05:59 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
I'm curious where a 426 Street Wedge (365HP) '64 Savoy 2-seat wagon would fit in Stock. It's part of the nostalgia theme for this project, and I'm thinking C or D would be about right.
I know Tritak & Morgan & some of the other early B wagon guys ran A/SA, C/SA, and also some SS classes with the same car back then, but obviously some of those classes were run in Max Wedge configuration.
Thanks for any help.
Re: Got a '64-'69 NHRA Rulebook? [Re: topside] #1112857
11/13/11 06:48 PM
11/13/11 06:48 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
Found classes on the Colesy-Junior Stock Forum; man, they bounced around a lot in different years!
All I need to know now is what NHRA had as a shipping weight, as apparently they weren't factoring the HP back then, they just used advertised HP. Wonder if they used the weight the mfrs told them as well?
Re: Got a '64-'69 NHRA Rulebook? [Re: topside] #1112858
11/13/11 07:10 PM
11/13/11 07:10 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Factory published shipping weight for a '64 Savoy with a V8 was 3205.
Re: Got a '64-'69 NHRA Rulebook? [Re: B5 Bee] #1112859
11/13/11 07:18 PM
11/13/11 07:18 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
I have every NHRA rulebook from 1959 to present with a few doubles. There's no way I can acess them today. All my stuff is packed away
home of the
Sox and Martin Hemi Duster
Re: Got a '64-'69 NHRA Rulebook? [Re: HEMIFRED] #1112860
11/13/11 08:30 PM
11/13/11 08:30 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
B5 Bee, is that weight for the 2-door sedan or a 2-seat wagon?
Re: Got a '64-'69 NHRA Rulebook? [Re: topside] #1112861
11/13/11 09:23 PM
11/13/11 09:23 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
The current NHRA classification guide shows 3654 pounds for the 1964 Plymouth Savoy 2seat wagon. I tried to attach the Excel spreadsheet, but it wouldn't attach.
http://www.nhra.net/tech_specs/classification/classfiles/1964PLY.xls
Floyd Lippencott IV
Re: Got a '64-'69 NHRA Rulebook? [Re: mr_340] #1112862
11/13/11 10:46 PM
11/13/11 10:46 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
Thanks, that seems more accurate for a wagon.
Haven't found the '64 classifications yet.
In '65, it would have been classed B/S or B/SA.
In '66 & '67, C/S - C/SA
In '68, E/S - E/SA
In '69, F/S - F/SA
In '70, G/S - G/SA
This assumes the published shipping weight never changed, which I think is a reasonable assumption.
Re: Got a '64-'69 NHRA Rulebook? [Re: topside] #1112863
11/13/11 11:11 PM
11/13/11 11:11 PM
You may also find some usuable info in the big Direct Connection book that Larry Shepherd use to put together. It had a couple of Classification Guide type chapters.
Re: Got a '64-'69 NHRA Rulebook? [Re: ] #1112864
11/14/11 01:05 AM
11/14/11 01:05 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
I've managed to save only two issues, '65 and '69
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Got a '64-'69 NHRA Rulebook? [Re: topside] #1112865
11/14/11 02:14 AM
11/14/11 02:14 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Whoops, that was 2dr sedan.
6P wagon - 3495
9P wagon - 3600
These were the factory published weights, what they supply to NHRA may be different.
