Re: Fram oil filter. Where have I been?
[Re: CompSyn]
#1112769
11/15/11 10:32 AM
11/15/11 10:32 AM
Posts: 2,177 ill
dennismopar73
ill
Well here we go again ,it's either oil filters or oil,, This question regenerates itself over and over! Ok , lets roll with it , How much oil does a oil filter actually filter? Answer not much at all! considering the amount of flow passing thru it. In HP motors, will a HP filter filter more or less oil? Answer, yes and no, why is that? because a HP filter allows for more oil to go thru it with out actually filtering the oil at all. The more filtering medium used the actual less filter gets done! So depending on the application , don't run a cheap standard filter on blown alcohol motor, or in 'disel' application don't run you cars filter on it. Change you're oil at regular intervals use the proper weight of oil for the application Now everyone can argue over it say what ever they wish , those are the facts! By the way, I don't care what filter you run , just so long as it is used in the application that reguired for it!
[Re: dennismopar73]
#1112771
11/15/11 10:58 AM
11/15/11 10:58 AM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
Fram collapsed on my step daughter's 91 Lumina a few years ago. Nice car until that happened.
I pulled the Fram off my Dart that was on there when I bought it. I see why they collapse. I pulled the Purolator apart and saw that the filter media was bonded into plastic or rubber.
The HP1 Fram is not reccomended for street. AFAIK the case is thicker. I have no need for a racing filter.
Please buy your Fram's and roll the dice. Chances are you will be OK. I am not a gambler.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: CompSyn]
#1112772
11/15/11 11:03 AM
11/15/11 11:03 AM
Posts: 2,060 Pendleton NY
terzmo
Pendleton NY
WIX, Fram, NAPA, etc... All of them utilize paper filter media. The manufacturing of paper filter media is not exact. As much as 40% of the filtering area of paper oil filters filter nothing at all, as in the filter is 40% blocked right out of the box.
Plus, how does paper respond to moisture? Right, it absorbs it. What does paper filter media do when it absorbs moisture from engine condensation and then it gets really cold outside. Yep! It freezes. Now your paper filter that was 40% blocked when new is now frozen and is really blocked. Now you have a completely worthless oil filter that's in bypass mode at cold engine start-up until it thaws out.
Do yourself a favor, do your engine a favor and throw out the paper oil filter. Then look for a micro-glass or better yet, a nano-glass oil filter. Previously only available in commercial and industrial applications, glass filter media technology has made it's way to the car and light truck market.
Seriously, research it.
Start here if you like: http://www.youtube.com/user/ckermit8
Lived in Buffalo Ny most My life (over 60 years) and NEVER heard of an engine failing because of a FROZEN oil filter. How far is this to be taken ?
[Re: dennismopar73]
#1112773
11/15/11 11:15 AM
11/15/11 11:15 AM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
Actually, the "facts" word for word:
"As example, a 3 micron beta 200 microglass element has less restriction than a 30 micron paper element. Filter paper manufacture is not an exact science. In many paper elements, as much as 40% of the filter may not pass oil at all, thus reducing contaminant holding capacity and increasing flow resistance. Conversely, a "manufactured" microglass element can flow through 100% of its area which results in considerably increased contaminant capacity along with lower DP/resistance compared with a paper filter medium."George Morrison, STLE CLS
In other words, WAY better filtering, and little or no pressure drop accross the filtering surface. It's not too good to be true, it's where modern technology takes us.
BTW, Those letters at the end of Mr. Morrison's name; he's more than just an internet expert on the subject of filtration.
[Re: terzmo]
#1112774
11/15/11 11:26 AM
11/15/11 11:26 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I agree...sounds bogus to me. unless all you do is short trip the car anyway, then it's a possibility.
said paper will also absorb oil. I've seen "paper towels" that would soak up oil, but not water. we used them in centerless grinders for cutting OD on parts, and sometimes the machines leak oil into the coolant tanks when changing the diamond wheels. but I've not seen paper that soaks up water and not oil.
if you drive a car to temp, there's no water in the oil to freeze anywhere after you shut it down and it freezes outside.
that's like saying never, ever let your tank run below 3/4 before filling up, because all that air space allows humid air into your gas tank, where it will cool down overnight, condense, and then you get all kinds of water in your tank causing nothing but problems.
and filter ability vs flow is one of those trade-offs that you'll never get rid of. the better the filter is at trapping smaller and smaller particles, the less it's going to flow.
my HVAC system at home will collapse a brand new, high dollar, "micro-allergen air filter" because it's a huge airflow restriction. Toss in a cheaper "dust filter" and the airflow is where it needs to be.
**Photobucket sucks**
[Re: terzmo]
#1112775
11/15/11 11:30 AM
11/15/11 11:30 AM
CompSyn
Pacific NW USA
Again, word for word:
"It is not simply a "full oil filter or stasis" situation. With paper pulp having so much of its chemistry composing water, when the filter medium becomes cold soaked at below even 32F, the water molecules can begin freezing and expanding, as only water does when frozen. The expansion fills voids, and thus potential significant filter medium restriction even beyond what paper normally does. With a synthetic medium, the medium is completely unaffected by cold temperatures and flows as if 85 degrees..." George Morrison, STLE CLS
So, could the valve train clatter we periodically hear at could winter start-up be partly attributed to the frozen "paper pulp" media oil filter? Kinda of makes one think a little...
[Re: 70Cuda383]
#1112777
11/15/11 12:17 PM
11/15/11 12:17 PM
CompSyn
Pacific NW USA
Actually to clarify, what George is talking about is the composition of paper naturally includes water molecules. It's these naturally occurring water molecules that freeze and expand in cold temps affecting the performance of oil filters constructed of paper media and not necessarily the paper absorbing moisture from external sources.
Okay, so what do the letters after George's name really mean?
STLE = Society of Tribologists and Lubrication Engineers
CLS = Certified Lubrication Specialist
Another quote from George:
"Regarding "seems too good to be true". Welcome to the world of microglass/synthetic filtration medium. I upgrade industrial applications every day from cellulose to microglass: go from a 30 micron paper element filter to a 6 micron microglass. Vastly improved filtration, in the 90% reduction level, as in the EaO, AND the filter generally lasts 2 to 4 times longer than the cellulose filter it was replacing. How? Generally up to 40% of a cellulose filter element passes nothing, absolutely blocked.. Whereas the microglass or nanofiber (whatever) is 100% flowable filter. So, yes, filtering much finer, flowing much easier and lasting considerably longer, even though it is capturing 90% more particulates... Indeed, it is true......" George Morrison, STLE CLS
Here's a little more about George Morrison's professional background: PetroLiance® LLC Acquired AV Lubricants - link
Read down a little, George is in there. That's why I trust what he say's about lubricant filtration and why I no longer use paper oil filters. But then again, each to his own...
[Re: Strawdawg]
#1112778
11/15/11 12:19 PM
11/15/11 12:19 PM
Rug_Trucker
One other personal experience I will add.
I installed a rebuilt engine with a Fram. Faint rod knock at cold start up. Less oil pressure. I canned it for a Purolater. 360 in my van with a HV pump.
[Re: CompSyn]
#1112779
11/15/11 12:54 PM
11/15/11 12:54 PM
Posts: 30,424 Florida STAYcation
dOrk !
The village idiot's idiot
Florida STAYcation
What ? ...NOW it is only toilet-tissue ones ? ..
[Re: CompSyn]
#1112780
11/15/11 12:55 PM
11/15/11 12:55 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I have heard plenty of valve clatter at "cold" start when the ambiant air tem is 100+ degrees outside
[Re: HotRodDave]
#1112781
11/15/11 01:09 PM
11/15/11 01:09 PM
terzmo
Pendleton NY
that clatter at startup could be a lifter blleding off oil from sitting,oil not getting to the top end fast enough or other reseans beyond a "frozen" filter. A few years back...well maybe 20+ We had a cold snap in January where the high was forecasted to be -5. It lasted about a week (cold snap) and never heard of a frozen filter.Maybe the guys in minnesota or wisconsin have input but I know they use block heaters and heated areas alot
[Re: terzmo]
#1112783
11/15/11 01:52 PM
11/15/11 01:52 PM
Posts: 183 Eden, Texas
Strawdawg
Eden, Texas
Or, it could simply be a poorly working anti-drainback filter in a poorly built oil filter
Steve
