Page 1 of 3 1 2 3
604 ci Users. #1112520
11/13/11 10:03 AM
11/13/11 10:03 AM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Hi All.
Just wondering what 4.75 stroke 4.50 bore combo's we have running here.
Interested in et's, tyre, gear, race weight, shift rpm and finish line rpm mainly but combo details would be great too.
Thanks in advance.
Tig
Re: 604 ci Users. [Re: Tig] #1112521
11/13/11 12:24 PM
11/13/11 12:24 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I have a 604 Predator engine in my dragster, but haven't run it yet. I'll know next year when we go to Las Vegas in Feb. It's a 604, 15-1, 1 1250 carb, Marcella sheet metal intake, made 1117 on gas. If it weren't for the Predator heads flowing over 500 cfm,I would have just built a 572. Everything for the raised cam block is $$$$$$. PS. I posted the dyno session on here a couple of months ago, if you wanted to do a search. And B1 Johnny had Best machine build him a 588 PSO that made over 1200, if IRC.
Re: 604 ci Users. [Re: Tig] #1112522
11/14/11 01:34 PM
11/14/11 01:34 PM
Shelton, Ct.
572_HEMI_Cuda Offline
Shelton, Ct.
I have a 604" Hemi, Stage V heads, Hogan w/ 2 small vac sec carbs. Car weighs 3210, shift at 7200 cross at 7350. 4.10 gears, bruno drive, 3 speed jeffco, 33" x 10.5" x 16" Hoosiers.
Ran 8.46 @ 161 so far. Going to send converter back to lenny this winter to tighten it up.
Re: 604 ci Users. [Re: 572_HEMI_Cuda] #1112523
11/14/11 02:19 PM
11/14/11 02:19 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Are you running 10 intake bolt heads or 16?
Re: 604 ci Users. [Re: Dragula] #1112524
11/14/11 03:37 PM
11/14/11 03:37 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Motor will be a wedge head with the bore and stroke previously stated. Rod journel will be the 2.200 size as I've heard this will work in a standard cam location block (steel rods btw)
I guess my original question would have been more to the point if I'd asked if going from 572ci to 604 was worth it.
However I'll be upgrading the heads (would like a best machine cnc port and Ti intake valve). Change rocker ratio (1.6 to 1.7) also and maybe go to a tunnel ram.
Thanks.
Re: 604 ci Users. [Re: Tig] #1112525
11/14/11 04:35 PM
11/14/11 04:35 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
What wedge head are you going with? That will decide whether you should go to 604.
Re: 604 ci Users. [Re: camastomcat] #1112526
11/14/11 04:37 PM
11/14/11 04:37 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Indy 572-13 410+ cfm IIRC, CNC ported.
Re: 604 ci Users. [Re: Tig] #1112527
11/14/11 05:22 PM
11/14/11 05:22 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Unless you plan to move up to PSO's, Predators, or B1/TS heads, I wouldn't do it. 572 will be plenty of CI for those heads, and you can run aluminum rods if you want to with 2.200 crank pin with no clearance issues. With the 4 3/4 in stroke you need a special pan, and are limited to steel rods. JMO.
Re: 604 ci Users. [Re: camastomcat] #1112528
11/14/11 06:48 PM
11/14/11 06:48 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
What he said!
Re: 604 ci Users. [Re: Diablo] #1112529
11/14/11 08:37 PM
11/14/11 08:37 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
I have considered PSO's but I've got $2500 in a set of custom headers for the -13's.
Would they fit the PSO's?
Re: 604 ci Users. [Re: Tig] #1112530
11/14/11 08:44 PM
11/14/11 08:44 PM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
Re: 604 ci Users. [Re: Tig] #1112531
11/14/11 08:45 PM
11/14/11 08:45 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Oops, not the PSO's. It's the B1 MC's that I thought might fit
Thanks for the advice, I'll probably just do everything to the 572.
Re: 604 ci Users. [Re: mopar_mark] #1112532
11/14/11 09:02 PM
11/14/11 09:02 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Nice set of predators here
http://www.yellowbullet.com/classifieds/viewlisting.php?view=1499
Maybe I should just fit an F3
Re: 604 ci Users. [Re: Tig] #1112533
11/14/11 09:23 PM
11/14/11 09:23 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
tig, my 572-13,s only flowed 388@.800". i got them from indy with their cnc work done. they claimed 410 cfm to me too.
when i called indy and talked to ken, he said to flow 410 cfm, you needed to thin the valve margins and blend the seats. he also said that would reduce reliabilty. mine is in a street car.
their claim is just a marketing ploy, to buy their heads. someone told me theese heads would'nt flow 400 cfm with the valves out...i'm doing a 588-604 myself. i will be using b-1 mc heads on this one....
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: 604 ci Users. [Re: Old School] #1112534
11/14/11 09:50 PM
11/14/11 09:50 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
tig, my 572-13,s only flowed [Email]388@.800".[/Email] i got them from indy with their cnc work done. they claimed 410 cfm to me too.
My hand ported -13's flow about the same, around 380cfm. Got them untouched from Indy back in 2001.
I think Best Machine have a cnc program for these heads that would take them to over 410 cfm with a 2.35 valve IIRC. It was these I was thinking of.
Re: 604 ci Users. [Re: Old School] #1112535
11/14/11 10:27 PM
11/14/11 10:27 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
I agree. 390 is the end of the road for that head.
A really good W8 will make the same power.
8.30's @3400 lbs
Re: 604 ci Users. [Re: Mike Swann] #1112536
11/14/11 10:37 PM
11/14/11 10:37 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
i agree w8 headed sb in 2800lb 8.20's all day.
Re: 604 ci Users. [Re: fishy340] #1112537
11/14/11 11:55 PM
11/14/11 11:55 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Tig,
You have a good set of heads there. Would the B1/MC's make more power? Yes, but I would build the 572 and if you move up to the B1/MC's later, they will work fine on the 572. If you think you would buy the PSO's or Predators later....and that's a 15-20k deal new, then build the 604. Believe me, I know, there are also 2 sweet deals for sale, Diablo's B1/TS and Pete's PSO motor. You would be money ahead even if you bought the $6000 Predators for sale. There's a lot more than the cost of some parts involved.
Re: 604 ci Users. [Re: camastomcat] #1112538
11/15/11 12:39 AM
11/15/11 12:39 AM
reynoldsburg,ohio
poppaj Offline
poppaj  Offline
reynoldsburg,ohio
You can run a 4.75 x 4.500 (604) and you can use aluminum rods, they must be the radiused Bill Miller version or equivelent. I have discussed this combo with Scott Koffel. He has built several. poppaj
AA/NSS 65'Coronet "Whompin Wedge"
Pop & Son Performance 557" B-1 power
John Holt Chassis
Re: 604 ci Users. [Re: 572_HEMI_Cuda] #1112539
11/15/11 02:13 AM
11/15/11 02:13 AM
Chesterfield Twp. Mi.
John Burdine Online work
John Burdine  Online Work
Just curious, is thier a reason for the 2 4150 carbs?
Page 1 of 3 1 2 3
