604 ci Users.
#1112520
11/13/11 10:03 AM
11/13/11 10:03 AM
Posts: 2,915 A shed in England
Tig
A shed in England
Hi All. Just wondering what 4.75 stroke 4.50 bore combo's we have running here. Interested in et's, tyre, gear, race weight, shift rpm and finish line rpm mainly but combo details would be great too. Thanks in advance. Tig
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
Re: 604 ci Users.
[Re: Tig]
#1112521
11/13/11 12:24 PM
11/13/11 12:24 PM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
I have a 604 Predator engine in my dragster, but haven't run it yet. I'll know next year when we go to Las Vegas in Feb. It's a 604, 15-1, 1 1250 carb, Marcella sheet metal intake, made 1117 on gas. If it weren't for the Predator heads flowing over 500 cfm,I would have just built a 572. Everything for the raised cam block is $$$$$$. PS. I posted the dyno session on here a couple of months ago, if you wanted to do a search. And B1 Johnny had Best machine build him a 588 PSO that made over 1200, if IRC.
Re: 604 ci Users.
[Re: 572_HEMI_Cuda]
#1112523
11/14/11 02:19 PM
11/14/11 02:19 PM
Posts: 12,383 Taxes & Virus's R-US, NY
Dragula
I have a 604" Hemi, Stage V heads, Hogan w/ 2 small vac sec carbs. Car weighs 3210, shift at 7200 cross at 7350. 4.10 gears, bruno drive, 3 speed jeffco, 33" x 10.5" x 16" Hoosiers. Ran 8.46 @ 161 so far. Going to send converter back to lenny this winter to tighten it up.
Are you running 10 intake bolt heads or 16?
Re: 604 ci Users.
[Re: Dragula]
#1112524
11/14/11 03:37 PM
11/14/11 03:37 PM
Tig
A shed in England
Motor will be a wedge head with the bore and stroke previously stated. Rod journel will be the 2.200 size as I've heard this will work in a standard cam location block (steel rods btw) I guess my original question would have been more to the point if I'd asked if going from 572ci to 604 was worth it. However I'll be upgrading the heads (would like a best machine cnc port and Ti intake valve). Change rocker ratio (1.6 to 1.7) also and maybe go to a tunnel ram. Thanks.
Re: 604 ci Users.
[Re: camastomcat]
#1112526
11/14/11 04:37 PM
11/14/11 04:37 PM
Tig
A shed in England
Indy 572-13 410+ cfm IIRC, CNC ported.
Re: 604 ci Users.
[Re: camastomcat]
#1112528
11/14/11 06:48 PM
11/14/11 06:48 PM
Posts: 1,106 Quebec, Canada
Diablo
Quebec, Canada
Unless you plan to move up to PSO's, Predators, or B1/TS heads, I wouldn't do it. 572 will be plenty of CI for those heads, and you can run aluminum rods if you want to with 2.200 crank pin with no clearance issues. With the 4 3/4 in stroke you need a special pan, and are limited to steel rods. JMO.
What he said!
Re: 604 ci Users.
[Re: Diablo]
#1112529
11/14/11 08:37 PM
11/14/11 08:37 PM
Tig
A shed in England
I have considered PSO's but I've got $2500 in a set of custom headers for the -13's. Would they fit the PSO's?
Re: 604 ci Users.
[Re: Tig]
#1112531
11/14/11 08:45 PM
11/14/11 08:45 PM
Tig
A shed in England
Oops, not the PSO's. It's the B1 MC's that I thought might fit Thanks for the advice, I'll probably just do everything to the 572.
Re: 604 ci Users.
[Re: mopar_mark]
#1112532
11/14/11 09:02 PM
11/14/11 09:02 PM
Tig
A shed in England
Re: 604 ci Users.
[Re: Tig]
#1112533
11/14/11 09:23 PM
11/14/11 09:23 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
tig, my 572-13,s only flowed 388@.800". i got them from indy with their cnc work done. they claimed 410 cfm to me too.
when i called indy and talked to ken, he said to flow 410 cfm, you needed to thin the valve margins and blend the seats. he also said that would reduce reliabilty. mine is in a street car.
their claim is just a marketing ploy, to buy their heads. someone told me theese heads would'nt flow 400 cfm with the valves out...i'm doing a 588-604 myself. i will be using b-1 mc heads on this one....
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: 604 ci Users.
[Re: Old School]
#1112534
11/14/11 09:50 PM
11/14/11 09:50 PM
Tig
A shed in England
tig, my 572-13,s only flowed [Email]388@.800".[/Email] i got them from indy with their cnc work done. they claimed 410 cfm to me too.
My hand ported -13's flow about the same, around 380cfm. Got them untouched from Indy back in 2001. I think Best Machine have a cnc program for these heads that would take them to over 410 cfm with a 2.35 valve IIRC. It was these I was thinking of.
Re: 604 ci Users.
[Re: Old School]
#1112535
11/14/11 10:27 PM
11/14/11 10:27 PM
Posts: 1,093 Long Beach, CA
Mike Swann
Long Beach, CA
I agree. 390 is the end of the road for that head.
A really good W8 will make the same power.
8.30's @3400 lbs
Re: 604 ci Users.
[Re: Mike Swann]
#1112536
11/14/11 10:37 PM
11/14/11 10:37 PM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
i agree w8 headed sb in 2800lb 8.20's all day.
Re: 604 ci Users.
[Re: 572_HEMI_Cuda]
#1112539
11/15/11 02:13 AM
11/15/11 02:13 AM
Posts: 1,403 Chesterfield Twp. Mi.
John Burdine
Just curious, is thier a reason for the 2 4150 carbs?
Re: 604 ci Users.
[Re: poppaj]
#1112540
11/15/11 03:25 AM
11/15/11 03:25 AM
Posts: 3,021 NY
B1duster
NY
You can run a 4.75 x 4.500 (604) and you can use aluminum rods, they must be the radiused Bill Miller version or equivelent. I have discussed this combo with Scott Koffel. He has built several. poppaj
I think its a pretty common combo, mine has GRP rods.
Re: 604 ci Users.
[Re: John Burdine]
#1112541
11/15/11 09:10 AM
11/15/11 09:10 AM
Posts: 298 Shelton, Ct.
572_HEMI_Cuda
Shelton, Ct.
I guess to keep it legal in NSS even though my car is a 1971. One day I'll put some big carbs on it.
So no one else runs a 604"? Wedge or Hemi? I know HemiFred has one, his motor and car build was highly documented on here. I've seen pics of the car at the track, maybe he will chime in with some performance numbers. Anyone else? Thanks...
Re: 604 ci Users.
[Re: 572_HEMI_Cuda]
#1112542
11/15/11 09:18 AM
11/15/11 09:18 AM
Posts: 3,210 robin hood country
deaks
robin hood country
Tig Have you ever thought about taking a bit of weight out of the car, i dont mean chopping it around, just bolt on stuff. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
Re: 604 ci Users.
[Re: B1duster]
#1112543
11/15/11 09:48 AM
11/15/11 09:48 AM
camastomcat
Salt Lake City
So you guys are saying you can use the 4.75 stroke crank in a standard cam location block, with aluminum rods? I don't think so. My 4.50 stroke needed clearancing on the rods with a standard cam block, 2.325 pin, with GRP's. Even at 2.200 it would only be .125 more clearance.
Re: 604 ci Users.
[Re: camastomcat]
#1112544
11/15/11 02:56 PM
11/15/11 02:56 PM
Posts: 627 IN
BIG BEAR
IN
This guy did
Re: 604 ci Users.
[Re: Fast Yeti]
#1112546
11/16/11 10:00 AM
11/16/11 10:00 AM
camastomcat
Salt Lake City
Perhaps you can make a 4.75 stroke fit with aluminum rods and a 2.200 pin size, but you would need to take a lot off in a crtical area of the rod, IMO. And the question was, is it worth it for 572-13 heads? I would say no, and it would add a lot of expense for very little gain. As I started to say, you can do anything you are willing to pay for, but the expense involved is not worth it. If you want a high horsepower 1100+ combo, contact Pete at Best or Diablo. They have proven combos for sale, and that's not as easy to do as some people try to make it sound, at least not naturally asprirated.
Re: 604 ci Users.
[Re: Tig]
#1112547
11/16/11 10:17 AM
11/16/11 10:17 AM
Posts: 428 wappinger falls new york
Jimi_Vignogna
hello tig ,i ran a cast iron head 604 hemi in my savoy a few years ago, great street strip combo, car was 3800#, 29.5 11.5 15 hoosier qtp., 4:10 gear, ultimate 9" tc 3500 stall, tti 2 1/4" headers 4"collectors, 4" x pipe exhaust to rear of car, single dominator,barton intake, cam was roller 112 lobe sep..670 lift etc.
the car would go 1.40 1.43 60' on the dot's, run 9.80'sat 137.00 all day long,once i got it in the car it needed very little maintenence,
only problem i had was after i bought the junk indy legend heads,the 510 cfm adv. was about 10% off low lift was ok although. the heads had two chambers machined out of place and the pistons hit. naturally russ did not want to make good on anything.cant understand how indy stays in business.
Re: 604 ci Users.
[Re: Jimi_Vignogna]
#1112548
11/16/11 11:35 AM
11/16/11 11:35 AM
Posts: 2,026 Trumbull,CT.
jim sciortino
Trumbull,CT.
That sounds like a fun car and.......
With Eric's Stage V heads, in multiple configurations, there is absolutely no reason to waste money on lesser products.
Re: 604 ci Users.
[Re: Tig]
#1112549
11/16/11 12:25 PM
11/16/11 12:25 PM
Posts: 9,986 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I have a very well worked over set of 440-1 heads with 2.300 intakes, which are the same casting as a 572-13 with the following exceptions. Moved exhuast valve to allow a 2.30 or 2.35 intake valve. rolled 2 degrees for a touch better breathing. Those heads have been a touch better at making power over a 440-1, but not a lot. They just don't have the port csa or volume to feed a BIG motor. My guess is they will be pretty much all done increasing power by using a 572 cube shortblock. I run 528 cubes under my 440-1s and I don't see many guys running that much faster per weight carried, and with 572 to 578 cubes.
Re: 604 ci Users.
[Re: gregsdart]
#1112550
11/16/11 03:23 PM
11/16/11 03:23 PM
Tig
A shed in England
Thanks for all the replies. I'll outline the dilemma. I want to go faster, I thought I could do it with more cubes and the block and top end I'm using now. Plan was to buy another set of -13 heads (since then I can use all the other stuff I have) and get them cnc ported. But I was going to buy another set of heads anyway, Predators are out of the question I think they'll work out too expensive for me, and I think the same for the B1 TS. Not sure about PSO's though, I've no experience. Should I keep developing the 572 or go to 604. Seems like the heads I have are holding me back Also can anyone tell me if headers that fit -13 will fit B1 MC's? (or PSO's)? I don't want a Hi RPM race gas motor. We've gone 6.1 @ 114 1/8th 9.57 @ 142 1/4 @ the weight in sig. I shift @ 6500 and motor goes to 6800 at the stripe. 4 figure HP would be nice since we think we're around 850hp given the times, MPH and weight (Cars been weighed on 4 scales now all within 40lb). Thanks again. Cheers. Tig
Re: 604 ci Users.
[Re: Tig]
#1112551
11/16/11 04:58 PM
11/16/11 04:58 PM
Posts: 698 Alberta Canada
Edge
Alberta Canada
Hard to comment without understanding what your goals are for your car. Do you have an ET or MPH goal in mind ?
76 Duster
work in progress
Re: 604 ci Users.
[Re: Edge]
#1112552
11/16/11 05:22 PM
11/16/11 05:22 PM
Tig
A shed in England
8.99 150 mph
Re: 604 ci Users.
[Re: Tig]
#1112553
11/16/11 05:39 PM
11/16/11 05:39 PM
Posts: 1,664 North Sweden
RT540
North Sweden
You also want to keep the budget down. I would get the best cnc B1 originals with 2.30 Tit. valves with PSI or equalent high quality springs with 360-400psi seat pressure. Cam with 0.850 lift, T&D rockers. Stay at 572cui square engine. Start with single intake for an possible 1000hp with the right parts compr. and cam and later upgrade to sheet metal intake for a 50hp increase ( twin domin.)
Staying with 2.30 valve at 572cui will keep the rpm lower.
Tom
Re: 604 ci Users.
[Re: Jimi_Vignogna]
#1112554
11/16/11 05:58 PM
11/16/11 05:58 PM
Old School
Virginia Beach, VA
(quote) only problem i had was after i bought the junk indy legend heads,the 510 cfm adv. was about 10% off low lift was ok although. the heads had two chambers machined out of place and the pistons hit. naturally russ did not want to make good on anything.cant understand how indy stays in business.
I have bought 5 sets of heads from Indy. The last set was SR 295 CNC'D from Indy. I paid extra to have them mill the heads for a 63CC chamber. This was approximately 4 years ago. At the same time I put a roller cam in the motor, same as my other 500" motors, this motor never performed the way it should. I always thought it was down around 75-100 hp. I tried everything, including asking for help on the site, just gave up and drove it as is. It ran fine, just low on power. I dropped a valve, a few months ago. so I had to rebuild the motor. Come to find out, the heads that I bought from Indy and paid to have milled, were never milled. I never checked the cc of the chamber when I got the heads, but did during the re-build. They were around 78CC, it made my compression about 9.5 - 1. When I called Indy and talked to Russ about this, I had the receipt, and he said there was nothing they could do about it, since it was a few years. He also took tone with me and it seemed to me he was implying I was making it up. I have purchased over $40,000 worth of Indy products directly from Indy. You would think that would mean something to them. I will never buy from Indy again. Everything I have read about them appears to be true. My next motor will have NO Indy parts. I also do not see how they stay in business.
Re: 604 ci Users.
[Re: Old School]
#1112556
11/16/11 06:16 PM
11/16/11 06:16 PM
Edge
Alberta Canada
Boost sounds like the best plan to me. I have a 572 B1 that is pretty much described above and I am not sure that it would meet your goals for your car but it might be close. I would not go to the 604 with the -13 heads, but what do I know I have not made a pass in a year and a half !
76 Duster
work in progress
Re: 604 ci Users.
[Re: Edge]
#1112557
11/16/11 07:07 PM
11/16/11 07:07 PM
Tig
A shed in England
Re: 604 ci Users.
[Re: Tig]
#1112558
11/16/11 07:14 PM
11/16/11 07:14 PM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
Tig...to go 8s and not use nitrous, I'd go w/ a procharger. That's exactly what I'd be doing if I had the money. Use your current motor, just boost it. You can make STUPID power w/ a procharger on that motor of yours. I prefer the blower over a turbo just for simplicity. Just my
Re: 604 ci Users.
[Re: Tig]
#1112560
11/16/11 08:30 PM
11/16/11 08:30 PM
gregsdart
At 3830 lbs to go 8.90s consistently, you will need close to a solid 1100 hp. That is a bunch. The smallest head I would even consider would be about the best ported B1Mc out there, or Predators. The weight is just killing you here. If you could shave some weight off the car and get it down 200 to 300 pounds, you can get by with the B1Mc heads most likely and not have to go with the predators, which would probably have to be bought new. A used set of B1Mcs with a good performance history is what I would look for.
Re: 604 ci Users.
[Re: poppaj]
#1112561
11/17/11 12:22 AM
11/17/11 12:22 AM
Posts: 627 IN
BIG BEAR
IN
I am talking a Indy or KB alloy block with stock cam location, NO small baseline cam needed, It is tight but fits.
I can't speak for the other guys but our block will except a 4.75 stroke with a standard cam location. I would assume any other aftermarket block would do the same
Re: 604 ci Users.
[Re: BIG BEAR]
#1112567
11/17/11 10:37 PM
11/17/11 10:37 PM
camastomcat
Salt Lake City
How does it run?
At 3500ft corrected altitude in Las Vegas, it ran 7.38@179....so pretty good. It should be slightly faster with a non NOS cam and pistons. It's a dragster at 1850lbs.
Re: 604 ci Users.
[Re: poppaj]
#1112568
11/17/11 10:42 PM
11/17/11 10:42 PM
camastomcat
Salt Lake City
I have the World block with the GRP pro series aluminum rods and mopar pin size. I run the 4.500 crankshaft. 4 of the rods need to be clearenced to clear the cam tunnel and pan rail.
Hi Tommy, With the Miller alloy rods with a standard ground roller in most cases you end up with a hundred thousandths cam to rod clearance. That is with a chevy 2.2 rod journal. It is close and there is block clearancing that must be done. I will say if I were going to build one and did not already have a block I would go for the .250 raised cam block, it just would make things much easier. poppaj
Well, I stand corrected. I called my engine builder this morning and he said it would fit with 2.200 pin, like you and others said. I guess I just wouldn't want to clearance my rods that much. I don't even like clearancing mine for the 4.500 stroke, and we just massage them a little. But thanks for the info, good to know.
