will 10in rim and 275/60/15 fit under 71 cuda #111222
08/27/08 03:57 PM
08/27/08 03:57 PM
Anonymous OP
Anonymous OP
Was wondering what is the widest tire I can run on a 71 cuda with a 10in rim and what back spacing???? thanks Dave.
Re: will 10in rim and 275/60/15 fit under 71 cuda #111223
08/27/08 07:01 PM
08/27/08 07:01 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
You won't get a 10 inch rim to fit in the wheelwell of a factory rear suspension on the 70-74 cuda..EDIT: What I meant to say is there is'nt enough room in the wheelwell area for a 10 inch rim and the leaf spring on a factory set-up..
