Wrapping up rebuild. Let's play "WHATS THIS???" #1112189
11/12/11 03:21 PM
11/12/11 03:21 PM
Houston Texas
PAINT IT BLACK Offline OP
Got a CHIP on my shoulder
Houston Texas
1970 Cuda.
The wire pig tail/harness is from somewhere under the dash. One end can plug into the other FYI. I have no idea where its supposed to go. Do you?
The little nylon thing came off of a wire harness I think...? I don't know what its supposed to do. I think there's a similar one on my alt. harness? What is it?
The two round things on the right look like spacers of some sort. Are they to my non ac heater box? What could they be? There are two and only two.
Step right up and be the next contestant!
Re: Wrapping up rebuild. Let's play "WHATS THIS???" [Re: PAINT IT BLACK] #1112190
11/12/11 03:32 PM
11/12/11 03:32 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
The ones on the right, are they the bumpers that touch the underside of the front of the hood when its closed?
Re: Wrapping up rebuild. Let's play "WHATS THIS???" [Re: Exit1965] #1112191
11/12/11 03:36 PM
11/12/11 03:36 PM
west palm beach, florida
modelmakerinc Offline
the wire pigtail looks like its for a radio red constant power yellow is lights or keyed power
the plastic clip is one for a wiring harness that gets taped into the harness could be one of many in dozen of places the bumpers look to be hood adjustment on the radiaor support
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: Wrapping up rebuild. Let's play "WHATS THIS???" [Re: PAINT IT BLACK] #1112192
11/12/11 05:21 PM
11/12/11 05:21 PM
PNW
Danan Offline
Danan  Offline
PNW
Are the spacers hard plastic? If so, I think they are bucket seat spacers to raise the driver's seat. I tend to recall that there should be four of them? I'm only about 10k miles away from my cars, but someone here knows for sure.
Re: Wrapping up rebuild. Let's play "WHATS THIS???" [Re: Danan] #1112193
11/12/11 05:39 PM
11/12/11 05:39 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
The spacers on the right appear to be seat spacers. My 69 Charger has them
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Wrapping up rebuild. Let's play "WHATS THIS???" [Re: 69L78Nova] #1112194
11/12/11 07:17 PM
11/12/11 07:17 PM
Houston Texas
Houston Texas
The round objects are VERY similar to the seat spacers... but they seem to be made of something fiberous like a composite, not just plastic (they are very hard though). They seem to be made of the same material as the heater box. And besides, my car didn't have the seat spacers before all this (I have some now). I know for sure that these are not hood bumpers or whatever you call them.
The wire harness clip thing.... what is it used for when it is taped into the harness? Does the square part clip onto something else?
I have an aftermarket stereo in my car, so I'll assume the harness isn't needed for now and put it in a safe place. Makes sense though. Thanks..
Re: Wrapping up rebuild. Let's play "WHATS THIS???" [Re: PAINT IT BLACK] #1112195
11/12/11 07:36 PM
11/12/11 07:36 PM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
the square part of the clip slides onto the rubber covered metal ears under the dash (and other spots on the firewall and in the trunk)that are folded over to hold the harness in place. possibly like the yellow wire is going through. dave
Re: Wrapping up rebuild. Let's play "WHATS THIS???" [Re: 3ddart] #1112196
11/12/11 07:56 PM
11/12/11 07:56 PM
Houston Texas
Houston Texas
Makes sense.
Re: Wrapping up rebuild. Let's play "WHATS THIS???" [Re: PAINT IT BLACK] #1112197
11/12/11 08:08 PM
11/12/11 08:08 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Stuff the line workers figured was unnecessary...
A common location for that harness clip is in the trunk on '68-'70 B-bodies, as stated the open rectangle goes over a tab welded to the car; the rounded part of the clip is taped into the harness.
