Re: Easy 904 question
[Re: WheelsUp73]
#1111525
11/11/11 09:21 PM
11/11/11 09:21 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
It should be set up from .060 to .070
I'm using my thinnest ring. So is .055 to tight? Will it cause problems?
[Re: DemonDust]
#1111526
11/11/11 09:28 PM
11/11/11 09:28 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I don't think you will see a problem with .055
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: DemonDust]
#1111530
11/13/11 05:40 PM
11/13/11 05:40 PM
Posts: 25,750 Rio Linda, CA
John_Kunkel
Rio Linda, CA
An easy way to pick up a little clearance is to thin the pressure plate in a lathe.
[Re: John_Kunkel]
#1111532
11/13/11 06:28 PM
11/13/11 06:28 PM
Posts: 30,424 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
An easy way to pick up a little clearance is to thin the plessure plate in a lathe.
Is that a PLEASURE plate ?.... I wood like to have one of those ...
[Re: dOc !]
#1111533
11/13/11 07:54 PM
11/13/11 07:54 PM
Posts: 20,630 in a cattle trailer down by th...
Guitar Jones
I've heard you already have one.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#1111534
11/13/11 08:12 PM
11/13/11 08:12 PM
dOc !
Florida STAYcation
You heard wrongO ... how is yours wurking ? ... even-though it is an IMport !
[Re: dOc !]
#1111536
11/14/11 04:47 PM
11/14/11 04:47 PM
Guitar Jones
Got a whammy bar too.
