Re: Engine Break In
[Re: dnd0001]
#1111495
11/11/11 09:14 PM
11/11/11 09:14 PM
RapidRobert
Yes I would cut open the filter/check the bearings and post what you find
Re: Engine Break In
[Re: RapidRobert]
#1111496
11/11/11 09:19 PM
11/11/11 09:19 PM
Posts: 15,487 Florida
scratchnfotraction
I would clearify any warrantiy with the builder or who ever left the plug out first and foremost. then you could have the 3rd party that is agreed upon by the first 2 partys to cut open the filter and have a looky see at it and move on to a tear down if need be. good luck post back results
Re: Engine Break In
[Re: scratchnfotraction]
#1111497
11/11/11 10:15 PM
11/11/11 10:15 PM
Posts: 15,887 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Scratchn's idea of third party sounds good. Did you happen to have a magnetic drain plug in it? If I had to bet on it I would bet you didn't do any damage.
Facts are stubborn things.
Re: Engine Break In
[Re: dnd0001]
#1111500
11/12/11 11:42 AM
11/12/11 11:42 AM
scratchnfotraction
the oil pump has a by-pass plunger and spring for that reason filters may have an anti-drain back valve but never seen a pressure by-pass on one. on a good note,it may not have hurt anything,but its a good idea to recheck everything before hand ..just in case good luck
