Page 1 of 3 1 2 3
Shortening a driveshaft yourself #1111408
11/11/11 06:31 PM
11/11/11 06:31 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
If I grab a C-body driveshaft would I be able to carefully cut the yoke off of one end, shorten the tube the appropriate amount and then reweld the yoke back on without worrying about balance? Any thing else I am not thinking of?
Re: Shortening a driveshaft yourself [Re: VITC_GTX] #1111409
11/11/11 06:35 PM
11/11/11 06:35 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I had a driveshaft shortened at a metal fab shop once. What you described is exactly what they did. I never had it ballanced and didn't have any problems. Obviously the proper way is to have it ballanced. I'm sure I just got lucky.
Re: Shortening a driveshaft yourself [Re: burdar] #1111410
11/11/11 06:39 PM
11/11/11 06:39 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
How fast did you drive the car wit hthat unbalanced shaft ? The only time I ever had it done the balance seemed ok at the legal speed limit , 100mph with a 3.23 gear and a 4 speed was a completely different matter .
Re: Shortening a driveshaft yourself [Re: JohnRR] #1111411
11/11/11 06:58 PM
11/11/11 06:58 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
It was in a Cordoba I raced at the drag strip. 106mph with 4.10 gears and didn't vibrate that I noticed. Again, my experience is not typical.
Re: Shortening a driveshaft yourself [Re: JohnRR] #1111412
11/11/11 07:01 PM
11/11/11 07:01 PM
scratchnfotraction Offline
this is not a place to cut corners. IMHO
ever have a shaft come out at trip diget speeds
you need a least a lathe,then mill the weld bead only to remove the yoke,make the tube cut with the lathe also,then replace the yoke and phase it back to the other end,reweld it,only way i know to get it straight..then have a high speed balance to check the run out.
my local machine shop chops them down 25$ but i have to go to the drive shaft shop for balance at another 40$
$ well spent in my book
Re: Shortening a driveshaft yourself [Re: burdar] #1111413
11/11/11 07:02 PM
11/11/11 07:02 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I would think if you put it back like it was it should still be balanced or close?
Re: Shortening a driveshaft yourself [Re: Challenger 1] #1111414
11/11/11 07:10 PM
11/11/11 07:10 PM
MI
68shifter Offline
68shifter  Offline
MI
I have done hundreds with a dial indicator, a home made jig to roll everything, and checking and rechecking. Most shafts pull loads of 250k along with multiple car shafts. Never has one come back.
The lathe makes cleaning the weld off easier but some time and a cut off wheel will work too. Quality and consistency of the weld is very important to the balance,
I have seen slot of shafts need balanced just because of how some idiot welded them.
Good luck, be safe with it.
68' Barracuda (4 speed) 64' Savoy (4 speed) 65' Satellite (girl tranny)
Re: Shortening a driveshaft yourself [Re: VITC_GTX] #1111415
11/11/11 07:10 PM
11/11/11 07:10 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
If you had a lathe you might be able to DIY everything but the balance job. W/O the lathe I wouldn't chance it.
Re: Shortening a driveshaft yourself [Re: Challenger 1] #1111416
11/11/11 07:11 PM
11/11/11 07:11 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
It was a metal fab shop so they probably did have a lathe. At first the car only went 89mph in the 1/4. When I stopped racing it was up to 106mph. That was a long time ago and the car has since been parted out.
Re: Shortening a driveshaft yourself [Re: Challenger 1] #1111417
11/11/11 07:13 PM
11/11/11 07:13 PM
doing it and getting away with it and doing it right are 2 diff things.
the yokes have to be phased
the end welds need milled not cut with a hacksaw
needs a dail indicator to make sure it straight on the run out
yes you could be close to the balance it once had,but it has now changed with the cut and reweld bead
all this will make the u-joint have a longer service life,and stay in the car at high speeds
I have hacked shafts up and even welded u-joint caps into yokes after grinding the yokes to get them to angle more with out binding on a lot of 4x4 junk.
after throwing one at 105 mph on I-75 in a 73 duster, i wont ever skimp on a shaft again.
not saying you cant do it and get away with it..but it can bite back at ya
Re: Shortening a driveshaft yourself [Re: scratchnfotraction] #1111418
11/11/11 07:24 PM
11/11/11 07:24 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
unless you have some REALLY good equipment at home, I wouldn't even chance it.
$300 to build a whole new driveshaft, or $100 to cut one down and rebalance it at just about any local clutch/driveline shop seems like small change when you're spending thousands on a car and it's drivetrain.
**Photobucket sucks**
Re: Shortening a driveshaft yourself [Re: VITC_GTX] #1111419
11/11/11 08:05 PM
11/11/11 08:05 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The reality is that most driveshaft tubing isn't all that round so dial indicating is useless and the method of separating the tubing end is irrelevant as long as the end is reinstalled in phase and equidistant with the other.
Re: Shortening a driveshaft yourself [Re: John_Kunkel] #1111420
11/11/11 08:22 PM
11/11/11 08:22 PM
thats kinda getting back to "getting away with it" no?
the tube end does need a nice straight cut to seat the yoke and help phase it I would think.
set it up,spin it,tap tap,spin,tap tap,spin,tap tap,spin,all phased and straight,now spin and weld..
Re: Shortening a driveshaft yourself [Re: VITC_GTX] #1111421
11/12/11 12:30 AM
11/12/11 12:30 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
The masses have spoken. I guess this will be one thing that I don't attempt myself.
Thanks to all.
Re: Shortening a driveshaft yourself [Re: VITC_GTX] #1111422
11/12/11 08:24 AM
11/12/11 08:24 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
We did a couple in my buddy's home shop many years ago with a small metal band saw and a stick welder, cutting the factory weld with a hack saw.
Scribe a line on the shaft and yoke and you can get it back in the right position.
Biggest problem we ran into was that some shafts had an inner tube that was a real PITA to cut down.
Never had one break, and one was in a pig block 4 speed car.
We did them ourselves mainly because there wasn't a driveline shop within 50 miles of us.
Re: Shortening a driveshaft yourself [Re: slantzilla] #1111423
11/12/11 09:50 AM
11/12/11 09:50 AM
Sterling Heights, Michigan 483...
daniel_depetro Offline
I've done a few myself and must have got lucky.
I simply scribed a lineup mark on the shaft/end and cut through the weld with a cut off tool.
I then cut the driveshaft the desired amount. On the last shaft that I cut I also had to relocate the attached weight.
I grinded down the weld smooth with a standard 4.5" hand held grinder.
Is it precise? No.
Is it perfectly balanced? No.
Can I feel any vibrations or any other adverse effects? No.
Does it work for me? Yes.
This is my personal experience and opinion. Take it for what it;s worth. It plus $1.10 will get you a cup of coffee.
1969 Dodge Super Bee A12 (440 Six Pack, 4-speed, Dana 60 4.10)
1972 Plymouth Road Runner (400, 4-speed, 8.75" 3.23)
1974 Plymouth Duster 360 (360, 4-speed, 8.75" 3.23)
Re: Shortening a driveshaft yourself [Re: daniel_depetro] #1111424
11/12/11 10:32 AM
11/12/11 10:32 AM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
Has anyone tried this driveshaft kit? I've been thinking of doing that for my small to big block conversion.
Driveshaft kit from Mancini's
Re: Shortening a driveshaft yourself [Re: Finoke] #1111425
11/12/11 10:46 AM
11/12/11 10:46 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That was never balanced to begin with so I doubt it would even be close ...
But it seems the overwhelming response is to just weld it up an go ...
I guess we can put driveline shops right up there with automotive machine shops , balancing is just another money grab ...
Re: Shortening a driveshaft yourself [Re: JohnRR] #1111426
11/12/11 10:53 AM
11/12/11 10:53 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
well then, they're grabbing my money! got a rotating assembly there now getting re-balanced...factory crank/balancer/flexplate with new rods and pistons.
Re: Shortening a driveshaft yourself [Re: JohnRR] #1111427
11/12/11 11:04 AM
11/12/11 11:04 AM
minot north dakota
ledft79 Offline
ledft79  Offline
minot north dakota
I had a welding shop cut the shaft on my 70 cuda, when I switched from a 318 to a 440. That was back when I was a kid and drove like nothing else mattered. It was topped out and close to topped out many times, and I don't remember there being any vibration at all. Lathe or no lathe, I don't know.
DRIVE EM, DONT HIDE EM.
Page 1 of 3 1 2 3
